Question about Eltax AVR-200 5.1 Channels Receiver
Error 1 on my eltax AVR-200
Every time i trn on my eltax avr-200, it always says error 1, how can i fix this or is it pernement
Eltax Atomic A-8 A8 Active Subwoofer i have a burnt out power transformer
Power transformers are safety parts and should only be replaced by the same type or one specified by Eltax the maker. You should contact them for the spare parts department or the place that stocks them.
Jun 01, 2013 | Audio Players & Recorders
I just purchased a used Denon AVR-3200 and have nothing hooked up yet but plugged it in on my kitchen counter and upon turning the unit on, noticed the error overload button was lit up but the unit did not...
Hi
I've had an AVR 3200 for about 10 years - occasionally (maybe once every 6 months), the error overload button comes on... for no real reason than i can detect (ghosts in the machine, maybe)... rebooting has always fixed it for me.
Aug 21, 2010 | Denon AVR-3200 Receiver
Denon avr 2308 no subwoofer operation
is the sub in speaker set A and sub in set B?
that was my problem on Denon DRA-455 with Eltax Linear 6.5
May 29, 2009 | Denon AVR-2308CI
I have a Denon AVR-488..Can you help?
Denon has released a Technical Service Bulitin about this problem. To fix it, an authorized service center will solder a jumper wire to bypass a connector, which has been shown to fail. It has nothing to do with the settings, or setup of this unit as described in Solution #1. It has to do with faulty parts within the unit. Just call Denon for an authorized service center and it is a quick fix. I have a AVR-488 that had the same problem and was fixed with the help of this bulliten and fix. No problems since.
Feb 21, 2009 | Denon AVR-3805 Receiver
Cofactor matrix
the cofactor (C) of Matrix (A) = (det(a) times (A)^-1)t
Cof A=(detAxA^1)t
Enter a matrix for (MatA) AC
shift 4 7 gives det(_
shift 4 3 shows det(a )<-end Paren
= x shows ansx
shift 4 3 shows ansxMatA -1x
= you'll see a Matrix AC to get out
shift 4 8 gives Trn(
shift 4 6 shows Trn(MatAns) =
The Matrix graph shows all the Cofactors
Jan 27, 2009 | Casio FX-115ES Scientific Calculator
Eltax speaker problems
I agree, NE Speaker is the BEST repair speaker shop in the eastern half of the USA. I have an EV 12" speaker re-built there and its better than it was before it was blown. Great job NE Speaker!!!
Leo B.
Jun 23, 2008 | Eltax Audio Players & Recorders
Eltax avr-200 no sound
Eltax AVR-200 will start up in protection mode if the amplifer went into protection mode due to high volume before it was turned OFF and it will start at the same volume level as it had before power OFF.
To correct this you must shift to another input without signal, then turn the volume down before it goes into protection mode again.
Jan 12, 2008 | Audio Players & Recorders
Arcam AVR 200 OSD
Hi
Think you might have to use composite video out for the OSD menu to appear. Think I heard somewhere S-Video out doesn't work for.
Haven't tried yet on my own, but I will in time :)
Cheers,
Simon
Jan 11, 2008 | Arcam AVR-200 Receiver
DKT2020 Conference Call
1) Make your first call. 2) Press the cnf/trn button. 3) Press one of your open line buttons on the right. 4) Dial europe number. 5) Let it ring a couple of times then press the cnf/trn button again. Remember your carrier or your phone system might have international calls blocked.
Aug 15, 2007 | Toshiba DKT-2020 Corded Phone
Eltax AVR-200 5.1 Channels Receiver Logo
48 people viewed this question
Top Eltax Audio Players & Recorders Experts
Trippy Tripp
Tom Chichester
Bill Willard
Bill Willard
Are you an Eltax Audio Player and Recorder Expert? Answer questions, earn points and help others
