Question about Poulan Wild Thing 2375 18" Gas Chain Saw 2.5 Cuin
Oil pump poulan pro 260 new pump does not contact drive on shaft
  • 9 Answers
SOURCE: poulan pro 260
Clearance from coil to flywheel should be around .010
Posted on Oct 26, 2008
steve_lima
  • 181 Answers
SOURCE: Pouulan Pro 260 chain saw - installed brand new
thake the muffle off and look inside the hole at the piston.if you see any marks on the piston,the saw will never start.you need to change the piston and cylinder assy.the cost is about $150.00 for the parts.that does not include any labor cost.most of the time it's not worth repairing.let me know if this helped or not...................................
Posted on Jun 06, 2009
  • 583 Answers
SOURCE: I have a poulan pro 260 42cc chainsaw (2001 or so)
oil pump itself is probabley clogged or u.s youdoit
Posted on Jul 26, 2009
dontbother10
  • 2220 Answers
SOURCE: how do I get to the oil pump?
You can find an IPL for your saw here:
Poulan.com
http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html
"PP220 Gas Chain Saw Type ?" - 6 choices, the LE suffix is code for a Wild Thing.
I think you’ll find it behind the clutch and it appears to be outboard (chain drive between engine and clutch) view this:
R² Drive Link Outboard Clutch by Drivelink.blogspot.com
http://www.youtube.com/watch?v=cdqkIuVNUQc
  1. Check the IPL for your saw to see if any special tools are needed.
  2. A length of starter cord or nylon rope may be used instead of the piston stop (retain 6" ± so you can remove it). Make sure the piston is near the top of the cylinder before feeding the cord or it can fall through the exhaust port and damage the piston as it rises.
  3. It is probably a left handed thread (tighten it to loosen it).
    Let us know how it worked for you.
I see an oil vent listed, and no tank assembly. The housing is probably magnesium and split in two halves. I would look at those hard as a possible source of leaks too. GL & HTH
Lou
Posted on Oct 20, 2009
  • 553 Answers
SOURCE: gas/oil ratio for fuel in a poulan pro 46cc engine
The standard mix for most chain saws is 40:1 that's about 3-1/4 oz per gallon.
Posted on Jun 12, 2010
Where can I find a thumbwheel adjustment foe a poulan chainsaw?
You can find just about any item needed to fix you chainsaw on www.ereplacementparts.com
I am not sure if you have the Poulan 260 pro, but I have attached the link from e replacement parts for that saw.
http://www.ereplacementparts.com/poulan-260-pro-chainsaw-parts-c-16962_17133_202439.html
Good luck in fixing your saw.
Aug 13, 2014 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Auto oil does not work on poulan pro 260 saw cleaned bararea
need to replace the oil pump
have to take the clutch pulley off the shaft.
Feb 27, 2011 | Poulan Garden
Chain oiler does not seem to be putting out enough oil,what can i do to increase the flow?
This model does not have an adjustable oiler. If the ports are clean and the pickup is clean, you may need to replace the pump. This is generally an inexpensive repair.
Feb 20, 2011 | Poulan Pro PP4620AVX 46cc Gas Chainsaw...
Were can i get a diagrame for a polan pro 260 chainsaw
You can find diagrams for the Poulan Pro 260 here - http://www.searspartsdirect.com/partsdirect/part-model/Poulan-Parts/Chainsaw-Parts/Model-260TYPE13/1324/1503220?blt=05.
Please note that there a few different "Types" of 260, so if this isn't the one you've got, try selecting "Poulan" from the Brands list at the top of the page and then looking through the available models until you find the "Type #" you have.
Sep 24, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
My Poulan E300 Electric Chainsaw stop oiling the chain and bar
Hello JK; I am hesitant to answer this, these are all Poulan electric chainsaws that appear when the parts source is searched for Poulan Electric Chain Saws:
400E Poulan Pro Electric Saw
http://www.ordertree.com/modelinfo/PWE/400E-Poulan-Pro-Electric-Saw/75.400E-Poulan-Pro-Electric-Saw.1.59.1.html
400EX Poulan Pro Electric Saw
http://www.ordertree.com/modelinfo/PWE/400EX-Poulan-Pro-Electric-Saw/75.400EX-Poulan-Pro-Electric-Saw.1.59.1.html
ES400 Electric Saw
http://www.ordertree.com/modelinfo/PWE/ES400-Electric-Saw/75.ES400-Electric-Saw.1.59.1.html
PP250E Electric Saw
http://www.ordertree.com/modelinfo/PWE/PP250E-Electric-Saw/75.PP250E-Electric-Saw.1.59.1.html
PP300E Electric Saw
http://www.ordertree.com/modelinfo/PWE/PP300E-Electric-Saw/75.PP300E-Electric-Saw.1.59.1.html
All are plumbed the same to my eye. I assume you cleaned and tested the oil pick-up within the tank. If everything you say is true if the pump is driven it should oil.
1. What causes the pump to pump? I cannot tell from the IPLs. If gas and not gear driven, an impulse line (pressure/vacuum) from the crankcase drives it. There can be no impulse line on an electric and I see no gear. Does it rotate to pump oil? What imparts the rotation?
2. What purpose does item 27 (pinion) serve? Is it supposed to drive the pump? Is it missing teeth?
3. What is the purpose of item 44 (check valve). If it is an oil tank vent, and not opening, you are creating a vacuum in the tank if the pump is operating. Loosen the oil cap and see if it oils. If yes replace the check valve.
I think Joe Schmoe is saying Poulan redesigned the oil system to eliminate all the hose couplings. It makes sense, one hose from oil pickup (filter on hose end in tank) to bar is much less likely to leak, also no restrictions for any particles in the hose to form a clot on. I see nothing on my research to support Poulan doing that. There are a couple of new models that I cannot find an IPL for so it is possible. I have headache JK. If this does not solve it is not because I did not give it my all. Please post back (below) with success or failure. If successful what was the cause. TIA
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Mar 29, 2010 | Poulan Pro Chain Saw 46cc 20"
OILER NOT WORKING
Poulan Pro 260 LE chain saw chain bar lube system is not working.
Mar 17, 2009 | Garden
Poulan pro 260
Oct 25, 2008 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Poulan Wild Thing 2375 18" Gas Chain Saw 2.5 Cuin Logo
18 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
