Question about Soehnle Health & Beauty
Soehnle 2755 calibration - Soehnle Health & Beauty
I just installed a new CR243 battery in my Soehnle bathroom scale, A red light came on inside, but nothing happens on the screen. Can you help?
Sometimes a CR2340 battery is still in it's package, but it may be very weak, even though it tests OK. Try another good battery.
Jun 15, 2017 | Soehnle Health & Beauty
REPLACEMENT BATTERY
Thats a fairly common battery, you should be able to find that battery at Walmart or Walgreens, Amazon has them too.
2 Pack Energizer ECR2430BP Lithium 3 Volt Coin Cell Battery
May 16, 2017 | Soehnle Health & Beauty
Programming soehnle volga
If battery replacement did not help, the scale may have failed.
Sep 19, 2016 | Soehnle 63691 Volga WhiteGrey Body Balance...
After inserting new batteries (CR2430) the display flashes E then alternates between 0.0 and 79.9
Had same and after short cirquit two contacts under silver sticker it started to calibrate, show 40 80 120 kg ...
Feb 08, 2011 | Soehnle Slim F5 Scale 63721
I replaced the 9 volt battery on my Soehnle scale and the display on the front reads 8888888 and stays that way, never going to 00. Please advise.
mcdevito75 here, You can try to disconnect the battery, then step on the scale then step off, Now re-install the battery and see how it works. If same contact scale manufacturer.
Jun 29, 2010 | Soehnle Linea Quattrotronic Digital...
My Soehnle scale shows an out2 error - how do I fix?
How to calibrate when "out2" is shown.
With the power off andthe scale on a stable surface, hold "g" and press "on". Some number will show up, probably a negative number. Press the "on" button again and the scale should display "Zero". Wait until it says "200.0". Gently place a 200 gram weight on the scale and wait a few seconds. If your successful it will say "Pass" and your scale will work again, yay!
May 14, 2010 | Salter 2001 electronic kitchen scale
My weighing scale is not working
try checking the battery and installing a new one
Jan 12, 2010 | Soehnle Linea Quattrotronic Digital...
Why when i download itunes i get the 2755 error?
i found this at microsoft site about 2755 error code it might help you on solveing your problem go to the link bellow
http://support.microsoft.com/kb/q251274/
Aug 12, 2009 | Apple iTunes
Instruction manual soehnle scale I need to rest the scale so it shows the bmi, hydration and weight.
I have looked and maybe you have the model number wrong the scale you are talking about 63700 Calando Quattrotronic scale is a simple digital scale and does not provide bmi, and hydration.
here is a link to the manual, http://www.leifheitusa.com/manual/63700.pdfit is in several languages including english as the company is european and sells to many countries. If you look english is there it is a very simple manual as the scale is only desinged to weight in either lbs or kgs nothing more. Sorry. If you would like a bmi chart you can get that here http://www.healthdiscovery.net/links/calculators/body_massindex_chart.htm and figure out your bmi based on height and weight in the chart.
Apr 23, 2009 | Soehnle 63700 Calando Quattrotronic Scale
Health & Beauty Logo
430 people viewed this question
Top Soehnle Health & Beauty Experts
Tom Chichester
Michelle Balcom
Greg P
Greg P
Are you a Soehnle Health and Beauty Expert? Answer questions, earn points and help others
