Question about Frigidaire ATF6000ES Front Load Washer
Clean drain pump filter - Frigidaire ATF6000ES Front Load Washer
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 102 Answers
If you want to clean the filter check the big hose between the tub and water pump
Posted on Feb 17, 2014
Pump won't drain water and keeps faulting for pump cleaning. Have turned it off, unplugged pump filter, cleaned it and restarted it several times with no luck. What else could be wrong??
Check to see if there is a drain filter. My GE has a small "door" at the bottom of the machine that has a filter behind it. If so ALL of the water will drain when you open it so be prepared. Then clean all of the junk from inside the filter or "trap"
Apr 15, 2013 | Washing Machines
Can I get to the drain pump or does the washer need to be torn apart? I cleaned out the drain plug- full of sand, filter clean, but I can't see the actual drain pump to see if something might be
Hi.
You can get to the drain filter without need for disassembling.The filter access is located behind the protective trim at the lower front side of the machine. Remove the trim and rotate the filter cap anticlockwise. Be prepared to collect the water that will flow through the filter. After cleaning the filter perform operations in reverse order to reassemble. Disconnect power before starting.
The pump is located at the bottom of the machine, behind the filter. Accessing the pump requires disassembling.
Diagrams for WM-2077 are available here.
Apr 21, 2012 | LG WM-2077C Front Load Washer
Oe code. Will not drain. Steps to fix?
Hi
OE in your dishwasher is a drain error and dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Also, check for any food pieces stuck near the pump impeller & clean the chopper assembly. If the issue returns after cleaning then the drain pump assembly should be replaced. Hope this helps...please post back for further assistance.
Daniel
Aug 30, 2011 | LG LDS4821 24 in. Built-in Dishwasher
I have the Kenmore Elite HE3t and the control panel lets me change the settings but the door stays locked and the drain pump (off the filter) keeps going but there is no water to drain...cleaned drain out...
Hi
If the washer is not draining then it is due to a clogged drain pump or a drain filter or a kinked drain hose. To resolve the issue you'll need to clean the drain hose, inspect if the drain hose is plugged. If the hose is fine, then remove the front kick panel and access the drain pump and filter, if you are unable to find the pump and filter remove the back panel as well and trace the drain hose to the bottom of the tub. There is a drain filter connected with the drain pump. It usually gets clogged, and needs to be cleaned every 6-8 months or so. The drain filter is a small white filter connected to drain pump with a hose. If it still doesn't work then you'll need to check the connections of the drain pump, check the electrical connections with a multimeter. If it still doesn't work then you would need to replace the drain pump. Please check this video for cleaning:
Hope this helps... Please post back if you need more information.
Daniel
Mar 31, 2011 | Kenmore Elite 45986 Front Load Washer
Washer will not drain water frigidaire
Hi
If the washer is not draining then it is due to a clogged drain pump or a drain filter or a kinked drain hose. To resolve the issue you'll need to clean the drain hose, inspect if the drain hose is plugged. If the hose is fine, then remove the front kick panel and access the drain pump and filter, if you are unable to find the pump and filter remove the back panel as well and trace the drain hose to the bottom of the tub. There is a drain filter connected with the drain pump. It usually gets clogged, and needs to be cleaned every 6-8 months or so. The drain filter is a small white filter connected to drain pump with a hose. If it still doesn't work then you'll need to check the connections of the drain pump, check the electrical connections with a multimeter. If it still doesn't work then you would need to replace the drain pump. Please revert for any further assistance.
Hope this helps...
Daniel
Feb 17, 2011 | Washing Machines
My lg washer and dryer wm3431hs isn't draining. I took of the hoses in the back, cleaned the filters and still nothing please help!
Hi
If the washer is not draining then it is due to a clogged drain pump or a drain filter or a kinked drain hose. To resolve the issue you'll need to clean the drain hose, inspect if the drain hose is plugged. If the hose is fine, then remove the front kick panel and access the drain pump and filter, if you are unable to find the pump and filter remove the back panel as well and trace the drain hose to the bottom of the tub. There is a drain filter connected with the drain pump. It usually gets clogged, and needs to be cleaned every 6-8 months or so. The drain filter is a small white filter connected to drain pump with a hose. If it still doesn't work then you'll need to check the connections of the drain pump, check the electrical connections with a multimeter. If it still doesn't work then you would need to replace the drain pump. Hope this helps...
Daniel
Jan 10, 2011 | LG WM3431H Washer and Dryer
Will not drain before spin
Hi
If the washer is not draining then it is due to a clogged drain pump or a drain filter or a kinked drain hose. To resolve the issue you’ll need to clean the drain hose, inspect if the drain hose is plugged. If the hose is fine, then remove the front kick panel and access the drain pump and filter, if you are unable to find the pump and filter remove the back panel as well and trace the drain hose to the bottom of the tub. There is a drain filter connected with the drain pump. It usually gets clogged, and needs to be cleaned every 6-8 months or so. The drain filter is a small white filter connected to drain pump with a hose. If it still doesn’t work then you’ll need to check the connections of the drain pump, check the connections with a multimeter. If it still doesn’t work then you would need to replace the drain pump. Please revert for any further assistance.
Daniel
Aug 30, 2010 | Washing Machines
Wont drain
Hi
Daniel
Aug 28, 2010 | Whirlpool Washing Machines
0E error
Product Laundry Washer
Symptom Error Codes
Sub Symptom OE error
Question Drain Problem Error.
Answer
Make sure that drain hose and drain filter are not bent or clogged. In case of there are objects in the drain filter, It might drain to slow or not at all. HOW TO CLEAN THE DRAIN FILTER 1. Allow the washer to cool down before cleaning the drain pump filter. 2. Open the lower cover cap with a tool such as coin. 3. At this time use a catch pan to prevent water from flowing onto the floor. Unplug the drain plug, allowing the water to flow out. When water does not flow any more, turn the pump filter open to the left. 4. Remove any foreign objects from the pump filter. After cleaning, turn the pump filter clockwise and insert the drain plug to the original place. Close the lower cover cap. If the drain filter is not clogged, you will need to call LG Customer Service at 800-243-0000.
Aug 18, 2008 | LG Washing Machines
Frigidaire ATF6000ES Front Load Washer Logo
54 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
