Question about Myryad Z Series Z160 Amplifier
No out put on right channel
Connected r c a cables left channel ok right channel, amp just clicks, switching trying to turn on with no out put
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 108 Answers
Check output transistors and drivers change emitter resistors
Posted on Jan 09, 2014
No volume on all left side speakers
Determining the Cause of the Problem Let's assume our system has a head unit, a crossover, a two channel amplifier and two door speakers with only the right speaker working (the left speaker is not working). If the door speakers are behind the door panels then we want to make sure the speaker is the problem before removing the panel. We'll work backwards starting with the amplifier and ending at the head unit. Testing for a Speaker Problem With the vehicle and the stereo turned off disconnect the speaker wires for both the left and right speakers at the amplifier. Now connect the left speaker to the right amplifier output (which we know works). Turn on the stereo system and make sure the balance is set to the middle position.If the speaker still doesn't work then the problem is somewhere between the amplifier and the speaker Testing for an Amplifier Problem Now we'll need to see if the amplifier channel is bad. Put the left speaker back on the left amplifier channel and the right speaker on the right amplifier channel. This returns the speaker wiring to its original configuration. Again, with the vehicle and stereo off unplug the RCA cables from the amplifier's input and switch them so the left cable is in the right input and vice versa. Turn on the stereo system. Testing for an RCA Cable Problem For any intermediate components between the amplifier and the head unit follow these steps for each one. We only have a crossover so we'll just do this once. Begin by testing the RCA cables between the intermediate component and the amplifier. Unplug both RCA cables from the intermediate component's output. Now plug the working channel's RCA cable into the non-working side of the crossover. In our case the working channel is the right so plug the right RCA cable from the amplifier into the left side of the crossover. Turn on the stereo system.
If the right channel continues to work then you know the problem is in the RCA cables between the amp and the crossover. esting for a Crossover or Equalizer Problem At the input of the intermediate component (in our case the crossover) flip the RCA cables around (left to right input and vice versa). Turn on the stereo system.
If the right channel continues to work and the left channel continues to not work then you know the problem is in the intermediate component. Replace or repair this component.
If the problem is now in the right speaker and the left speaker works then the problem lies before the crossover. Turn off the stereo system and return the RCA cables to their normal places.
Testing for a Head Unit or RCA Cable Problem Pull out the head unit from the dash so you can access the RCA cables. Unplug both RCA cables from the head unit. Do not disconnect any other wiring. Plug the right RCA cable into the left channel of the head unit. Turn on the stereo system.
Sep 29, 2016 | Cars & Trucks
NAD C320. Only one channel sounds. Problem with the volume control?
Did you try to switch the loudspeakers? Before changing anything always lover the volume and switch off the amplifier.
Assuming you tested already different inputs, you can be sure no cable from signal source is out or defect. (or did you nit check that first?).
When the amp is switched off, disconnect the speakers and switch left to right and right to the left output.. If the other speaker is quiet now, you are sure it is in the amp. Still his can be anything.
You can check the connections between the pre and main amplifier on the back side. When you have an extra set of interlink cables, perhaps you can cross the in and output there too. Take care every time you change something, lower the voltage and switch off the amplifier. Sudden clicks when switching on or changing anything can damage the amp and or the speakers.
Perhaps when you checked this you can locate where the problem is? Speaker, speaker cable, power amp, pre amp, (only a part of the pre amp.
Nov 12, 2013 | NAD C320 2-Channel Amplifier
Protect Light On Amp Being Weird
Could try switching right and left subs. If the problem moves to the other side pull the wiring and redo.
Then if the wiring is ok check the sub.
May 15, 2013 | Jensen JPA600D - 600 Watts Digital Mono...
Su v8 down on one channel
it would be either:
a) amp or speaker , try to turned off unit, interchange the speaker wire,
the speaker wire on the right channel try to connect it on the left channel,
the right speaker wire to the the left channel .
b) say if the same channel produce weak audio, then the problem is on the SU v8 amp.
c) inside the amp, there are main amp and preamp with selector
switches.
d) try to test , if all inputs , produce the same symptoms.
e) say same symptoms, now try to interchange cables if using
external sources produce the same symptoms.
f) if still have, then inside the unit , it would be either left main amp
or preamp.
g) you can try for a test, connecting direct to "IN" at the back to test
if the main amp is having problem.
Apr 24, 2012 | Audio Players & Recorders
Channels out of balance - remote will only change left channel.
switch input cables and try this will confirm if the amp has a problem or the input signal
Jun 19, 2010 | Krell KAV400Xi Amplifier
Is there a wiring diagram for the nikkai EAPA450 Amp
Hi, if you still need a photocopy of instructions email me mail@srands.co.uk
If you want instructions in brief this involves POWER CONNECTIONS, PHONO LEAD & SPEAKER CONNECTIONS:
POWER (At the same time when routing these wires, I would connect the PHONO LEADS from the car cd player to the amp, if your car cd player only has 1 preout (1red & 1 white) then you will need two phono splitters, a female to 2 males. Phono leads carry the unamplified sound from cd player to the amp):
~ Permanent 12V+ (Thick lead that is fused direct from battery all the way to the amp, wire must be 20a to 30a +, hence 1cm diameter wire, known as AWG8, Maplin sell cheaper kits then most)
~ Amp REMOTE (A thin insulated cable (5a is OK) from car cd player amp remote wire, this turns the amp on when the cd player is on, if your car doesn't have an amp remote wire, suggest nearest ignition supply or seperate switch that you turn on when you want to turn on the amp)
~ GrouND 12V- (Insulated lead (20a to 30a) to nearest part of unpainted car chassis such as interior panel screw hole, instead of an insulated cable all the way from the batery, this is common practise.
SPEAKER:
Each speaker has a - negative & + positive, these must connected correctly. The amp has 4 channel, 2 channel labeled as front, 2 channels labeled as rear. Using speaker wire, connect cable from amp to speakers. Note: Ensure the speakers being connected only receive sound from the amp (Not cd player as well, as would damage players or at the very least impair sound)
The amp has a feature called bridgeable this means a sub 8" or 10" sub can be powered by 'bridging' two channels. For example there are 2 ways to bridge power a Sub on the NIKKAI EAPA450:
i) Sub speaker wire positive + to channel RL and Sub speaker wire negative - to channel RR.
OR
ii) Sub speaker wire positive + to channel FL and Sub speaker wire negative - to channel FR.
Switches:
~ Bass boost, meant to be on for a channel if using sub, otherwise off.
~ X-over mode adjust hi/lo frequencies, only work if both x-over switches are on! Then adjust switch frequency knob, until it sounds right.
~ Gain (Volume knob) adjust volume knob up or down, until it sounds right!
NOTE:
You will need patience! many hand tools and parts such as: Wiring kit, fuse holder 20a/30a, Phono leads, speaker cable, Fork/ring connectors, wire strippers, wire cutters, set of screw drivers, also ueful to have zip ties to tdy excess cable and 'P' cable clips to tidy speaker wire to shelf, etc.
OK
Any more questions just email me mail@srands.co.uk
Dec 01, 2009 | Car Audio & Video
Left channel will not play
Firstly try swopping over the left speaker to the right channel . If still no sound then either the speaker cable will have a break in it & need replaced or the actual speaker will be open circuit. If you get sound from the speaker on this channel then the the speaker is ok. Check your PC's audio set up... Go to Control Panel/ Sounds & Audio devices/ In volume Tab, click in Device volume area... Advanced & then check the Balance settings are not set to one end.
Jul 22, 2009 | Dell A525 Computer Speakers
How do I connect a Polkaudio powered subwoofer (psw 125)
Connect a set of stereo RCA cables from the 'Output 2' on the Hafler to the line imputs on the Sub.Turn on the '1+2' output switch on the Hafler and rock out!
Dec 16, 2008 | Marantz PM7200 2-Channel Amplifier
RCA cable use
You can plug into the left channel and it will feed both the left and right channels.
To confirm that it's feeding both channels, connect the speaker to one channel at a time. With signal fed into the left channel only, you should get sound when you connect the speaker to either channel.
Apr 18, 2008 | Sony XM-754HX Car Audio Amplifier
Help
I recommend you swap your left and right input cables to make sure it's not a source issue.
So from your headunit, plug the left channel output into your amps right input and your right channel output into your amps left input.
If the same side is still not working then disconnect both (or single speaker if it bridged) the speakers from the not working side at the amp. Connect the front and then the rear speakers individually and retest to see if one of them works.
If one does work then check the cabling and speaker connections on the one that doesn't. If it's shorting out anywhere it will stop your amp from powering that channel.
Failing that, it could just be that your amp has partly failed.
Feb 15, 2008 | Boss Riot 1500D Car Audio Amplifier
Myryad Z Series Z160 Amplifier Logo
51 people viewed this question
Top Myryad Audio Players & Recorders Experts
 Grubhead
Grubhead
Gary Dumers
Gary Dumers
Are you a Myryad Audio Player and Recorder Expert? Answer questions, earn points and help others
