Question about Gaggenau Freezers
Fault finding fault F43
F1471 vi Miele freezer showing fault code 01 21 _F
From a previous post for a different Miele freezer: "I emailed Miele and this is what they reply: Thank you for your interest in Miele products. That message is a ice fault. If the ice has stopped production, please turn the toggle switch off under the electronic touch panel. To find this please reference the owners manual on pages 7 and 9. I have included the owners manual in case yours is missing. If your machine still produces ice fine just shake the cubes around making sure none are built up along the back wall of the ice drawer. If this continues please contact our service department. Please reference incident number 2698767 should you need to call in. For more detailed information, please visit our web site at www.miele.com or to speak with one of our representative call 800-999-1360." Haven't tried yet, but will post again if it didn't work, otherwise should be the answer"
Nov 17, 2013 | Miele Freezers
Bosch
please describe the fault in detail. with make and model number
Jan 06, 2008 | Freezers
I have a Norge 3H9TZ-EV stove. The oven & broil elements stopped working suddenly & there are no fault codes. Power to the stove is good, there are no blown fuses and nothing visibly wrong with the...
I had a similar situation happen to my GE Stove. I tested the incoming wires and found power on both. I couldn't find anything wrong either.. What I did find though was that the Circuit breaker itself had "half died", meaning that only one pole of the dual circuit breaker was working. I tried resetting it over and over only to find that it was completely fried. I went to the hardware store and got a new circuit breaker. I first looked for any loose wires on the elements and the burners of the stove that could have provided a ground fault, and after finding none, I installed the new breaker and flipped it on after plugging the oven back into the wall. Voila! everything worked fine! Installing a new breaker can be scary at first. you may want to consult a professional to check the breaker for you. Or if you are comfortable doing it yourself, then go for it. At least you'll know if the breaker is good or not. Once I had the breaker off of the circuit panel I checked it for continuity with a voltmeter and found only one side working. The panel I have allows you to just "pull" the breaker straight off of the panel. Some are screwed in, some are popped in, it just depends on the manufacturer. So, based on my experience, that is what I would do. Perhaps it's the wall outlet, but I doubt it. If you want to check that, use a voltmeter to check each incoming wire for proper voltage. Some symptoms I had with my oven were the panel would be on and would "click" like it was turning on the oven, but nothing would happen. Or the Burners would work, but only heat up halfway. The Broiler wouldn't even come on at all. Let us know how it goes!
Oct 25, 2013 | Freezers
Where is the defrost timer on a Frigidaire #FFU1461FWO
If it has a digital setting display unit it will usually be an integral part of that. If it's not defrosting properly it could be a probe fault or heater fault, not necessarily timer.
May 12, 2012 | Frigidaire Freezers
Have american style fridge freezer, model S25B RSB31. Seems to be tripping the electricity supply. When power restored, find that the freezer has two bars where you would see -18c. After putting in and...
Your defrost heat element is shorting, resetting will make it work till defrost cycle kicks in and HEY PRESTO""shorts again...very common fault and bugs the hell out of all of us, check it and I am pretty sure that is the fault. Or you are getting water or condensation in the control panel but very rare.
Regards and hope that sorts the issue...Please dont forget to Vote, I do this for free, Russ
Mar 28, 2011 | Whirlpool Freezers
Our LG American style fridge freezer not reaching required temp. Model no. GWB227YVQA - had engineer to look who could find no fault and thinks compressor has gone or system fault. It is only just 3 years...
try to check refrigerant charge if in correct according to its labelled. try to relocate your unit maybe the location near to heating appliance or the circulation of air on condenser is not good try to clean condenser if dusty.
Feb 04, 2011 | Freezers
The freezer is fully defrosted and will not resume a cold temp.
find thermostat. if open its bad, set to max cold and see if it comes on. if it doesn't gently tap it ,if it comes on its bad and sticking open. replace it. if the compressor doesn't run with stat bypassed the compressor or start components are bad. re[plce start components and if still no run the compressor is bad. usually not worth expense of new parts.if compressor is at fault. good luck.
Dec 06, 2008 | Frigidaire Freezers
I require a wiring dia for kelvinator N395BGWH no frost model
What is the fault you are trying to eliminate? There is a possibility that the fault is other than in the wiring. Check on the back of the unit as wiring diagrams are sometimes attached to the back wall of the refrigerator.
May 16, 2008 | Freezers
UNIT NOT COOLING(IS RUNNING WHEN PLUGGED)
only reason refrigerent may be needed is that there is a leak so adding more will achieve nothing. unlikely to be needed. i assume compressor is running. probable causes of no cooling are compressor fault or a blockage in the pipe sysyem. not diy
Jun 30, 2007 | Avanti 1.4 cu. ft. Chest Freezer...
Blows fusebox trip - all the time
good place to start is the starting device for the compressor.slip the cover off the compressor electrics on lhs of compressor usually and you may find the relay burnt out.tyhis is the mostly area but if elsewhere, look at the defrost element and check wiring loom
Apr 12, 2007 | AEG 7.59 cu. ft. / 215 liter Upright...
Freezers Logo
Top Gaggenau Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Gaggenau Freezer Expert? Answer questions, earn points and help others
