Question about Cutter Tools
Nibbler will not work
Brand new never used
What spare parts should i get
The rotary unit inside the head ,, the small gear set with transfers power through the head
Apr 16, 2014 | Metabo Kn6875 14 Gauge, 5.2 AMP 550 Watt...
Powermate nibbler won't work
Put some air motor lube oil in the air inlet and then hook up air supply. If that doesn't do it then open the motor to see if there is a stuck vane.
Dec 31, 2013 | Powermate Air Nibbler
Does Ace sell nibblers?
Sure. Check out the nibblers available on the Ace site: http://www.acetoolonline.com/Electric-Nibblers-s/1101.htm
Apr 24, 2013 | Cutter Tools
Where can I buy nibblers online?
Try this model from Amazon
http://www.amazon.com/Hitachi-CN16SA-16-Gauge-Nibbler/dp/B00005Q7BR/ref=sr_1_1?s=hi&ie=UTF8&qid=1358332173&sr=1-1&keywords=nibbler
Jan 16, 2013 | Cutter Tools
I don't own an air compressor. Is there another kind of power nibbler that isn't pneumatic?
Yes, there are electrical nibblers that work just as good as the pneumatic ones. of course, there are also handheld manual nibblers too
What is the thickest sheet metal that manual nibblers can effectively cut through?
they should be effective up to about 1/2" thickness. However, on softer metals you can probably go a little thicker, and on harder metals you might have to go a little under 1/2"
What is a nibbler?
A nibbler is a small tool used for cutting sheet metal without distortion.
Cutter Tools Logo
519 people viewed this question
Top Cutter Tools Experts
JOHN LAPIER
Are you a Cutter Tool Expert? Answer questions, earn points and help others
