Sony tv troubleshooting
Model kdl-405300 pixels on screen break up, more so when watching live sports
    Top Expert:
  • Televison & ... Master
  • 74,666 Answers
If you wish to get some details, check the site linked here. http://electronicshelponline.blogspot.com/ Pull up older posts. It has troubleshooting tips.
Posted on Jan 01, 2014
mistersony
  • 320 Answers
SOURCE: green pixel lines
It sounds like a bad LCD panel but you would have to post a picture of the problem for me to be sure
Posted on Oct 18, 2008
mistersony
  • 320 Answers
SOURCE: Sony KDL-32ML130 lcd tv
Not really that tough. Sounds as though the backlight is shutting down, either from a power supply failure, or a failure of the backlight circuit itself. You can verify this by holding a flashlight to the screen in the area where the menu usually appears to see if it displayed on the LCD panel with no backlight. If you can faintly see the menu displayed, your backlight has shut down and the most likely cause is the backlight inverter board, followed by the power supply and the backlights themselves which are part of the LCD panel. If you found this information answered your questions, please be sure to rate it. Thanks!
Posted on Oct 25, 2008
lebones337
  • 152 Answers
SOURCE: We were watching tv on
sounds like the lcd control board malfuntioned. call sony and im sure they will have you bring it to a repair shop at no charge
Posted on Jan 01, 2009
SOURCE: Sony TV KDL-32L4000 Turns Pink
My Sony tech says it's most likely a bad cable box. Try a DVD and if the DVD is fine then it's for sure your cable box. Needs to be replaced by the cable company.
Posted on Aug 10, 2009
  • 53 Answers
SOURCE: 40xbr2 bravia kdl sony LCD tv. The screen shuts
Problems relating to the automatic turn on and turn off of a set like this usually point to the main board being an issue. For this set, I believe Sony refers to that board as the "AU" board.
It's probably not the G/Power Supply board, especially if it turns itself on. Power supplies will turn a set off, but rarely--rarely--turn itself on.
If there's no kind of extended warranty involved here,
you could be looking at $500.00 for parts and labor to repair this kind of problem.
As always, try any software/firmware updates Sony might have available on their website prior to pursuing a repair visit.
Posted on Jan 22, 2010
Sony Bravia KDL-60EX500 no longer turns on.
Refer to Sony KDL 55EX500 Troubleshooting Manual Protection Mode Symptom...
5X Blink - TCON & HFR Failure
The 5X blink protection mode indicates a communications error between the TCON/HFR board and the MT5388 microprocessor on the A-Board.
First replace the TCON/HFR Board if the 5X protection mode blink pattern occurs. If the TCON/HFR Board does not repair the problem then replace the A-Board.
see schematics in Sony KDL 55EX500 Troubleshooting Manual Page 23
Sep 15, 2016 | Sony Bravia Kdl-60ex500 60" Inch 120hz...
We have sound but no picture
LCD Easy Fix (sound but no picture) - YouTube
? 4:52
https://www.youtube.com/watch?v=IBRE1Dcyxp4
Jan 13, 2012 - Uploaded by Clay Whitehead
TV Has Sound But No Picture Troubleshooting Guide - Duration: 2:30. by Repair.com 467,264 views. 2:30. LCD & LED TV Repair - No Image ...
How to fix sony bravia has black screen - Digital TV - Streaming ...
www.tomsguide.com/forum/56867-4-sony-bravia-black-screen
Aug 19, 2014 - 12 posts - ‎11 authors
Hello, My Sony Bravia TV screen has gone all black. The green on/off light comes on,but no picture appears. The model ... Your solution solved the non picture for live tvbut still no picture (just sound) fir OnDemand. Score. 0. No picture on LCD TV with HDMI cable plugged into ...
Aug 4, 2014
Tv problems picture ok but no sound - HDTV
Sep 8, 2011
More results from www.tomsguide.com
Dec 14, 2015 | Sony BRAVIA KDL-55XBR8 55 in. HDTV LCD TV
Why does my Sony Bravia LCD KDL-40BX421 TV spontaneously reboots itself?
Great that its under warranty!
Without troubleshooting inside the TV guess is not easy, there are only two boards in this model PowerBoard and Main Board, if the screen is bad its a automatic replacement. If purchased locally stores usually have a customer satisfaction 30 day return policy, good luck
May 02, 2012 | Sony BRAVIA Televison & Video
I have a Sony BRAVIA KDL-52W3000 that has horizontal lines and ghosting on the left side. In the beginning it would go away after a while now it's pretty much always there.here's a video of it:...
unfortunately it sounds like the electrical signal component of the tv is beginning to fail or was subject to a power surge, usually if you get dead pixels you will only get dots on the screen, if you get a dead inverter, it simply loses its backlight, so i would suggest it may have to go to a repairer.
Jun 11, 2011 | Sony BRAVIA KDL-52W3000 52 in. LCD...
There is one pixel out on our TV. Is there anything we can do to fix that black pixel?
In 99.9% of the cases there isn't anything you can do except replace the panel. That last 0.01% are not dead pixels but "stuck" pixels and can sometimes be fixed by lightly rubbing the screen with your finger.
Apr 04, 2011 | Sony Bravia KDL-46V4100 46 in. LCD HDTV
Model# kdl-40w4100 Serial # 8051767 2 years old Horizontal lines in 4.5 inch blocks at the top of the screen
I have the same tv model KDL-40W4100 and around the same age. At the moment I have 16 of
these horizontal lines over the entire screen and they seem to be grouped into 2 lines per row. They are also around 4 inches and two pixel rows high. I have been looking over the Internet for months and found nothing to troubleshooting this issues. In the last few weeks more and more of these groups of lines have been showing up and now i am up to 16 of them and it is becoming unwatchable. Any help from anyone would be greatly appreciated. I also attached a picture to describe it better. Thanks!
Nov 06, 2010 | Sony Bravia KDL-40W4100 40 in. LCD HDTV
Sony Bravia KDL-46Z4100
if the line is in the same place all the time im afraid to say that is a pixel problem on your display contact sony they may offer you a replacement display or altleast a way of changing the set.
Mar 10, 2009 | Sony BRAVIA XBR KDL-V26XBR1 26 in. LCD...
Sony Bravia XBR 40" LCD
First, HORIZONTAL CENTER.
1) Press MENU.
2) Scroll to SETTINGS.
3) Scroll to SCREEN.
4) Go to HORIZONTAL CENTER. Move the picture to the right. Hopefully, the line will go away. Otherwise, there is a problem with the pixels or the signal processor. Call 1-800-222-SONY. Or, http://eservice.sony.com. Have a high-limit credit card handy for out of warranty repairs. Sorry about that.
Aug 27, 2007 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Televison & Video Logo
22 people viewed this question
Top Televison & Video Experts
Electro Med Services...
