Question about Craftsman 25cc Gas Line Trimmer
No spark,craftsman string trimmer
It is getting fuel ,changed spark plug and fuel. any advise will help .thank you
  • fplqnewc
    fplqnewc May 11, 2010
    Does it have an ON-OFF switch?
    Problem Solver:
  • 9 Answers
  1. Remove the flywheel cover and pull the ground wire off of the off of the coil...
  2. Check for spark...
  • If you now have spark you have a "short to ground" some where in the in the wiring
  • If you still don't have any spark you'll need to replace the coil
Posted on May 21, 2009
Husqvarna weed eater starts , but blows alot of smoke & then stalls out
Rod, Carb. may need adjusted, try loosening gas cap and start to see if cap vent plugged, there is a in tank fuel filter that you could fish out and remove to see if it is plugged. If still not running remove muffler and clean spark arrester screen, if screen plugged the trimmer will do this.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
String Trimmer Starts Then Stalls
My String Trimmer Starts But Won Stay Running
Craftsman Trimmer starts then dies
How to Clean Spark Arrestor Screen on Small 2 Cycle Engine Quick Fix
How to Clean Two Cycle Two Stroke Engine Carburetor
Sep 06, 2012 | Husqvarna 128 LD Weedeater
I rebuilt the carb as you advised. It took me a long time to get a kit because no one had one around here. I have new gas, new plug and still no go. I removed the plug and it was dry, so I put alittle gas...
Check to see if you have spark. This is done by removing the spark plug, connecting the wire to it placing it plug against the metal on the motor and pulling the starter cord. It is best to do this where the light is not bright because what you will be looking for is a spark on the spark plug. If there is a strong spark then that is good and will start it if the fuel/air ration is right. I hope this helps.
Aug 15, 2011 | Poulan 25cc 2-Cycle Gas Powered String...
I have a craftsman 32cc weedwhacker trimmer and its brand new and it hasnt started from day one it isnt getting any spark at all
If you have spark problems, remove the wire and then remove the plug, reattach the wire and ground the plug to the engine and pull the string, you should see arc and hear it pop, if not, take the plug to another piece of equipment and remove that equipment's plug wire and attach it to the plug from the weed ******* and then ground it and test it. If still no spark, then plug bad, if plug then the weed ******* has a problem with the spark plug wire or the ignition coil.
If you have spark at first test, then the problem with the weed ******* is somewhere else.
Aug 09, 2011 | Craftsman 25cc Gas Line Trimmer
Craftsman 32cc gas trimmer ran a couple times this season, then will not start. Changed plug, new gas mix, cleaned filter and spark arrestor. No luck. Pull cord is hard to pull in the first foot or so,...
Pull the spark plug and hold the side against the engine while pulling the string. check to see if there is a spark you may need another person to help. Was the air filter oily when you cleaned it? If so you might need to remove and clean the carburetor.
Jun 07, 2011 | Craftsman Garden
Craftsman hedge trimmer won't start.
Have you changed the H T lead and then check the cut of swicth for faulty wireing
Jul 19, 2010 | Craftsman 22" Gas Hedge Trimmer
Weed eater starts but won't stay running
just bought a new Poulan 25cc 2cycle gas power weed eater . I can start it with the choke on but as soon as put on run it dies.
Jul 08, 2010 | Poulan 25cc 2-Cycle Gas Powered String...
I'm having problems figuring out how to change or repair the string pull on a craftsman 22 inch gas hedge trimmer. It looks to me like you have to remove the clutch. How do you do that?
remove screws on both sides of plastic housings, remove spark plug, pull off plactic cap on the bottom side of the clutch plate. stick a wooden stick in that hole to keep the crank shaft from turning when you put an adjustabloe wrench on the clutch, unscrew clutch to get other half of housing off to get to the pull rope.
Jun 06, 2010 | Craftsman 22" Gas Hedge Trimmer
Craftsman flipover head string trimmer. Will not start. No spark.
could be coil also could be a fouled,dirty flywheel,check coil wire
Aug 25, 2009 | Craftsman 25cc Gas Line Trimmer
Change feed fuel feed line craftsman string trimmer
no should be fairly straight forward! you can find the tubing at ace lowes home depot! good luck & happy trimming!!
May 31, 2009 | Craftsman 25cc Gas Line Trimmer
Craftsman 25cc Gas Line Trimmer Logo
537 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
