Question about Toshiba Computers & Internet
Pressing the power button results in the power light flashing 5 times and nothing else happens
Satelite Pro c850-10U
    Top Expert:
  • Toshiba Master
  • 23,737 Answers
I would firstly remove the power source and battery, then remove the RAM and hard drive. Plug in the power source without the battery and press power. If it springs into life, remove the power, refit RAM and try again. If OK remove power and fit hard drive.
Posted on Dec 31, 2013
IB4G2008
  • 3587 Answers
SOURCE: Dell D600 latitude will not power up
you can try to replace the motherboard, which is apparently totally UnHappy
Posted on Mar 16, 2008
Exidous
  • 63 Answers
SOURCE: Fujitsu Siemens Amilo Pro V2055 laptop power on problem
Check to see if the ram is securely in place. (that will cause a pc to not boot, usually there is a beep code tho)
Posted on Oct 06, 2008
mahjid
  • 202 Answers
SOURCE: Doesn't turn on, Mute and 2 volume lights constantly flashing
Your Pc motherboard is faulty, have a system engr look at it for possible reapirs." it won't boot ecept it is work on. Good luck
Posted on Feb 07, 2009
  • 3 Answers
SOURCE: C500 Laptop won't come on power button just flashes
Have you tried attaching an external monitor when the LCD screen is disconnected from the motherboard? this connector is located under the keyboard strip – a piece of plastic just above the keyboard.
If it works, this way, then the video cable isn’t seated properly in the connector on the back of the screen. Plugging the video cable back in should fix the problem.
I don’t know how comfortable you are with taking apart laptops but I think that this information could be useful for you.
Source: http://www.asklaptopfreak.com/laptop-notebook-help/2006/08/08/laptop-powers-on-and-shuts-off-immediately/
Posted on Sep 28, 2009
rylee_smith
  • 8619 Answers
SOURCE: My acer aspire 5920 will not power on!
Hi
Thanks for using FixYa. You will need to reset the Laptop if it is not starting up. Follow the procedure as under to reset it---
Remove all connections to and from the laptop. Now remove the battery and press and hold the power on button for 2 minutes. Release the power on button. Slip in the battery pack. Plug in the power to the laptop and to the wall. Please do not plug in any other devices and now try the Laptop powering it on to resolve the issue.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Posted on Nov 25, 2009
Sharp aquos tv, model no. lc-70c-6500u, no audio, visual at power up, standby/power light flashes 2 times long, 5 times short, nothing else happens, what is this mean?
Sounds like main board fault. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Jul 28, 2015 | Sharp Televison & Video
Keeps switching inputs
WD82837: Mitsubishi 82" Rear Projection
Problem: The "status" light flashes yellow while no picture display. Nothing happens when pressing the power button. The light keeps flashing if plugged in. I cannot test for codes by holding for 5 seconds as there is no place to check the code problem due to no display. HELP!
Feb 07, 2014 | Mitsubishi WD-82837 82 in. HDTV DLP TV
Pressing power button results in power light and hard disk light coming on for a couple of seconds cpu fan spins for same length of time then fan stops lights go off few seconds later lights come back fan...
it seems that you have damage memory card replacing may fix a problem but its better for it that you bring it to a technician in order to check much better because the motehrboard may possible be the problem.
Jun 30, 2011 | Acer Aspire 4315 Notebook
When I turn on my Canon i560 printer the light blinks orange and green and will not print anything. I've tried to turn it off and on, unplug it and nothing seems to be working. What can I do to fix it?
try this. It is the reset for the waste ink error (8 flashes)
1) With the printer power OFF, while pressing the Resume button, press the Power button. (Do not release the
power button.)
2) While pressing the Power button, release the Resume button, press the Resume button again twice, and then
release the Resume button and Power button.
3) The green indicator flashes during initialization.
When the indicator stops flashing and remains on, press the Resume button 4 times to clear waste ink message.
(The indicator toggles between orange and green each time the Resume button is pressed.)
4) Next, press the Power button, and the green indicator will light, and the function will be executed.
5) Turn off the printer then back on and error should clear.
Aug 04, 2010 | Canon BubbleJet i560 InkJet Printer
Controllers will not connect to playstation console.
connect controller to ps3 using the chragin wire then lick the ps button on the controler
if nothing happens turn on ps3 manually with the controller still connected and it should recognise it again
Dec 13, 2009 | Sony Playstation 3 (PS3) Console
I am so confused because i can´t turn on my iPhone the screen is still black This is what i tried... 1. Pressing the Power Button (Result: Nothing happens.) 2. Pressing the Power Button and the Home...
we need more info on the phone itself, has it recently been subjected to abuse water or physical? if so maybe the battery itself is damages also try to bull the battery and leave it out for a full minute! if you can get power and just not on the screen then maybe the lcd digitizer is damaged and needs replaced! (please write back with any result or questions)
Jun 12, 2009 | Apple iPhone Smartphone
Unresponsive buttons
First, try unplugging the unit for a couple of hours. That should reset the internal microprocessor. If that fails, try pushing all of the buttons one at a time. If one of them is stuck, nothing will work properly. You should be able to feel the button working. Report back here with your results.
Dan
Mar 12, 2008 | Sharp XL-MP130 CD Shelf System
Won't turn on
Your Mainboard is faulty. I had an Eten M600 like that before and ended up it die totally. Eten had many problem with their board. If you still have warranty, contact them for a replacement. Nothing you can do about it since the board is failed to boost due to Power failure.
Feb 16, 2008 | Eten Glofiish X500 GPS Pocket PC
Computers & Internet Logo
90 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
