Question about Fitbit Flex Wireless Activity and Sleep Wristband Black
My fitbit flex is not recording correctly. I was on treadmill for 80 min yet it said I only had 4 active minutes
It I recently
Steps do not reset at end of day
Try to perform a reset of the Fitbit. Follow
How do restart my tracker
When does my tracker reset and what happens to the previous day data
Your tracker resets your data to zero each night at midnight. For most trackers, your minute-to-minute data will be stored in your tracker for up to seven days without syncing. If you have a Fitbit Alta™ your minute-to-minute data is stored for up to five days. A daily summary of your activity is stored for up to 30 days.
Keep in mind that your calorie burn estimate will begin each night at midnight, so if you're up late and moving around, your tracker will adjust your calorie burn accordingly. Even if you are asleep at midnight, you will still see that you've burned some calories upon waking up in the morning. This is because you still burn calories even if you are sedentary or sleeping. Fitbit calculates your calorie burn based on information about your age, gender, height and weight.
Apr 16, 2016 | Fitbit Flex Wireless Activity Tracker...
My fitbit flex died - cannot wake it up; also it's tied to my cell phone and that doesn't respond - totally blank!
How to fix broken Fitbit - sync Fitbit with phone app - PC ...
www.pcadvisor.co.uk/how.../how-fix-broken-fitbit-sync-image-3499292...
May 15, 2015 - Fitbit Flex, Fitbit One, Fitbit Zip, Fitbit Force or Ultra not syncing with the Fitbit app ... To get the Fitbit app sync working again restart the Fitbit tracker. ... charger, has a battery charge but is not lighting up, or isn't tracking your steps. .... I've already done all the obvious stuff: turning off my phone, turning off and ...
Fitbit Flex review - The disappointment we've all been ...
blog.hyperexpert.com/fitbit-flex-review-the-disappointment-weve-all-be...
May 5, 2013 - My wife and I are both in good shape, we both wanted the Flex just to ... app, wait for the device to finish connecting and syncing to your phone, ... to sleep mode, I have to do all of this? and then again to wake it up? .... Also, doesn't the manual say "not" to wear it in the shower? ..... I appreciate any response.
Jan 06, 2016 | Fitbit Flex Wireless Activity & Sleep...
How do I delete messages from my Fibit Flex ?
http://help.fitbit.com/articles/en_US/Help_article/Can-I-delete-data
This article should help guide you in deleting data from your fitbit.
If you're trying to delete text messages, you should deactivate messages/notifications. You can find steps here
http://help.fitbit.com/articles/en_US/Help_article/How-do-I-use-call-and-text-notifications-with-my-Surge
Jul 09, 2015 | Fitbit Flex Wireless Activity & Sleep...
How to set time on my fitbit
  1. Log into your dashboard at fitbit.com and click the gear icon in the upper right corner of your dashboard.
  2. Choose Settings > Personal Info and find the Time section.
  3. Choose your timezone and select your 12-hour or 24-hour display preference.
    Once you sync you should see the correct time.
Jul 07, 2015 | Fitbit Flex Wireless Activity & Sleep...
How do I delete my info form the FitBit flex? I want to return my new flex to buy a FitBit Surge.
HOW DO I DELETE PROFILE DATA FROM MY TRACKER? Fitbit uses your height, weight, and age measurements to properly calculate your stride length (which helps determine your distance), calorie burn, and active minutes.
To delete your profile measurements from your tracker, the tracker must be set up to a different account. Once a tracker is set up to a different account, it will automatically unlink itself from the dashboard and all of the tracker's stored data will be permanently deleted from the tracker. You can find instructions on how to create a new account in the following articles:
May 14, 2015 | Fitbit Flex Wireless Activity & Sleep...
How do I setup my fitbit force
Does your Force show up on the Dashboard?
If not then
http://help.fitbit.com/articles/en_US/Help_article/How-do-I-set-up-my-Fitbit-tracker-on-a-computer/
If your having problems syncing then
http://help.fitbit.com/articles/en_US/Help_article/I-m-having-trouble-syncing-my-tracker-to-my-dashboard
Of course without knowing what you Sync through I can not be much help.
Dec 16, 2014 | Fitbit Force Wireless Activity Sleep...
Fitbit Flex Wireless Activity and Sleep Wristband Black Logo
229 people viewed this question
Top Fitbit Exercise & Fitness Experts
ray gallant
Joseph Coppeto
Joseph Coppeto
Are you a Fitbit Exercise and Fitnes Expert? Answer questions, earn points and help others
