Question about LG WM2277H Front Load Washer
There is a hole in the drum of the lgf1247td leaking water- is it repairable?
How could there be a hole in the thick plastic drum that holds the water?
    New Friend:
  • 66 Answers
May be problem with the cluch assyble,,,if its making loude noice,,you have to change,it,,might water lealing from that..
Posted on Feb 22, 2014
Water leaking from outer plastic drum on beko washing machine found 2 small hole what is the best thing to stop leak
A poxy plastic sealant but you may get lucky call around get a good used drum at a repair shop.
Mar 05, 2014 | Beko Washing Machines
Hole in plastic outer drum
I have plastic welded my son's hockey skate with an automotive bumper cover welder and surprisingly it has held up-its basicly like a soldiering iron with a dime size foot on it-it came with a universal welding sticks that have kevlar fibers in it-I would back up the repair area with 3m aluminum repair tape and fill in your hole-cheers Denyy
Oct 21, 2013 | AEG Lavamat 12710 Front Load Washer /...
Why is water leaking from the bottom of the the washing machine?could the drum be to full?
It could be a bad tub seal, hole in a hose, or even the drain pump.
I would need your model number to be able to tell you how to check these parts.
Sep 27, 2011 | Frigidaire Washing Machines
We've got a Hotpoint Aquarias extra 1300 spin washer - had it for about 7 years. It has suddenly started leaking water from underneath (ie not from the pipes going in or out of the machine). Does this...
Hello, if its leaking from underneath the chances are there is a hole in the drum due to a coin damaging the plastic after getting trapped between the steel dum and the plastic outer drum. you would need a new drum only maybe try ebay for around £30 then a good diyer could do for you or expect to pay around £40 to remove old one and fit replacement
Jul 17, 2010 | Hotpoint Washing Machines
Whirlpool lsr7233dqo will not stop filling up in wash and rinse cycle, cold water does not shut off compleatly.
Check the clear plastic hose that runs from the pressure sensor to the bottom of the drum. If it is not secured away from the drum or other parts of the washer it'll rub against the metal and wear a hole in the tube. It only needs a tiny hole and the hose won't hold pressure and tell the sensor that the tub is filled. One way to test is to take the host off completely and blow into it while stoppering the other end. You'll probably hear the leak but if you don't you can drape the hose in water and the bubbles will tell you where the leak is. Either replace the hose or cut the hose at the hole and buy an coupling that you can insert between both ends. Just make sure that it is airtight. If the hose is good...the presure sensor itself may be bad.
Dec 26, 2009 | Whirlpool Washing Machines
Water leaking from bottom Sears Model
Most likely the water pump go to this web sitte to get the parts price and break down on the macine for repairing. you need to raise the washer to be able to see exactly where it's commming from I use a 2x4 to or 2x6 to raise the front of the waser up far enoght to see where the water is comming from and use a flash light. be sure to stay out of the water while it is running or unplug it altogether if it leaks plugged in or not, then use the flashlight to find the leak. be arare it could be the hose or the tub seal as well and that water travels. Use you hand to feel excatly where the wter is comming from. the web site is http://www.applinacepros.com. If you need more help just post to this answer to get more help.
Nov 16, 2009 | Washing Machines
Water still leaking
Look at and examine the door seal closely for any sign of a hole or tear in it.
If none is visible then it could be the clamp or spring that holds the seal to the drum front that is causing the prob..
Other than that , there could be a crack or hole in the container front.
Jan 08, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Maytag Atlantis Top Load MAV6250AWW Drum Leak?
It leaksYour washer can develop several types of leaks. You can track down a leak based on when it occurs:
During fill only
During drain and spin only
All the time
During fill only
If the washer leaks only during the fill cycle, check these:
Air-gap device -The air gap is a small device found on most washers that prevents the wash water from being siphoned into the household water supply. It's located either mid-way along or at the end of the black rubber hose that comes from the water-inlet valve. Often it's made of translucent plastic. If one of the air-gap components deforms or cracks, you may need to replace it.
The tube -There's a rubber tube that runs between the water-inlet valve and either the air-gap or the inlet spout. If it cracks or breaks, it can cause a leak.
Inlet spout -Most washers have a plastic spout near the top of the main clothes tub that directs the water into the tub. If the spout cracks or breaks free of its mounting, it can cause a leak.
A washer that leaks only during the spin cycle often has a leak in the main drain hose. Inspect the entire hose and correct any problem you find. Alternatively, the steel or plastic outer tubs can rust, split, or be punctured. This may be most visible during large loads and high water levels. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
All the time
If the washer leaks all the time, check these:
Hot and cold water fill hoses - Check the hot and cold water hoses from the household plumbing. If either hose is leaking, tighten it or replace it, as appropriate.
Main tub seal - The main tub seal is located between the transmission and the outer tub. It's the primary water seal in the outer tub for the transmission-shaft entry point. If this seal leaks, you can see the leak by opening up the machine's main access panel while the machine is full of water with a small amount of detergent in it. The leak appears at the underside of the outer tub, at or near the center. This seal is difficult to replace. You probably should call a qualified appliance repair technician.
Pump - If the pump leaks, you can probably spot the leak when the tub is full of water. The pump has two or more black rubber or plastic hoses attached to it and usually has a drive belt that spins the pump. If the pump is leaking, you need to replace it.
Outer tub - Over time, the steel or plastic outer tubs can rust, split, or be punctured. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
Oct 22, 2008 | Maytag Atlantis MAV7260B Top Load Washer
Leaking from bottom front
lean washer to back ..pump mounts just underneath 2 clips hold pump too motor shaft remove clips remove hose clamps ckd pump most likely suspect for leaks
Sep 02, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Repair to hole in washer plastic drum.
I had the same issue, I got some liquied fiberglass from out local car shop, striped down the washer and split the drum so I could get the the inside and out, I rubed down the hole with soem ruff sand paper to make a good key then applyed the fiberglass, waited for 3 hours to make sure it was good, put it backtogether and all is done been great now for last 3 years.
Colin
Jun 30, 2008 | Washing Machines
LG WM2277H Front Load Washer Logo
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
