Question about Avaya 1608 IP Phone Black
Flashing display only , dead
Have some of them with all same problem , tried external power supply and power over lan same result
My 23" Apple cinema display (2002) has black screen and code flashes three short flashes. How do I find out if the monitor is dead or the power supply?
The only way to test is to use a known working power supply or known working cinema display with the parts you already have.
Dec 11, 2012 | Apple Cinema Display 23" HD Monitor
Can't start HD, I can hear only biping sound
a biping sound is usually indicative of either a dead drive, or not enough power on the USB bus (for unpowered external drives).
If the drive will take an external power supply, but is not connected to one, try connecting a power supply to it.
If the drive is out of warranty, try removing it from the external enclosure and hook it up internally to the PC. Sometimes the enclosure interface fails. If the drive makes the same noise inside the PC, it's likely dead.
May 17, 2012 | Seagate Expansion 1.5 TB USB 2.0 Portable...
Power light flashing green. No other light or sound. Per directions I found here, I bought a new power supply board. No change at all. Any other ideas?
Ur tv still having the same result a flashing LED power light indication,after u change the tv power supply board.Mean only one thing the main logic Tuner signal board it is also dead too.The Tuner signal board that the board where the tv incomming broadcasting signal wire plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole new refurbish main logic Tuner signal board for the replacement.Tries out the old power supply board with the new refurbish main logic Tuner signal board too 50/50 the old power supply could be still functioning.If ur old power supply board still good and functioning,than return ur new bought refurbish power supply to the vendor u bought it from to get some money back.
Sep 14, 2011 | Televison & Video
Vizeo light was flashing orange then green, now its dead?
Check ur power outlet source?Yes.Tries tv unplug,replug it back like about an hour later for a resetting of the tv it back to the factory setting.Now the tv should be working again,if the tv still have the same result.Mean the tv power supply board it is dead,that the board where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Apr 27, 2011 | Vizio L32 32 in. LCD HDTV
My Acer ASpire M1641 desktop isn't booting, not even to the BIOS screen. It was running & I was on the internet when it flashed a blue screen too fast to read, then stopped dead. I get no display on...
Even though the fan on the graphics card spins, it may still be the power supply. Try another power supply before anything else, its your cheapest option as well as a new motherboard will cost more
if this helped you please vote
Feb 25, 2011 | Acer Computers & Internet
My computer wont turn on
I FPOWER IS NOT COMING CHANGE POWERS UPPLY OTHERWISE REMOVE AND REINSTALL MEMORY MODULES
Mar 24, 2010 | Computers & Internet
Monitor displays for less than second, then goes black.
If that model has no external power supply then the supply is internal and some capacitors have failed. It's a fairly common problem with that type of monitor. The capacitors are cheap, and not too difficult to desolder and replace. The hardest part sometimes is getting the darned thing open.
Hope this helps.
This is also a test, I have been having issues getting notices of replies through e-mail. Your input therefore is desirable.
Thank you.
Jul 16, 2009 | Dell E172FP 17" LCD Flat Panel Monitor
Display flashes DELL logo on power up and then goes black.
Try pressing Fn + Monitor. It sounds like you have it set to pipe video out to an external monitor.
Hope this helps.
Dec 12, 2008 | Dell Inspiron 6000 Notebook
Avaya 1608 IP Phone Black Logo
32 people viewed this question
Top Avaya Lands Phones Experts
Oloyede Monsuru
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you an Avaya Lands Phone Expert? Answer questions, earn points and help others
