Question about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
Cannot initialize renderer cause d3derr not available
D3DERR-not available help to fix
Hi Simiyu Oscar,
There is a possibility that this issue might be related to DirectX. Try following the below steps which might help:
    (1)Click start and select run.
    (2)Type regedit, click ok and select yes.
    (3)Goto HKEY_LOCAL_MACHINE?SOFTWARE..> MICROSOFT..> DIRECTX
    (4)Now right click on DirectX and delete it.
    (5)Restart the computer.
    (6)Download the latest direct X
    This should help.
    Thanks and Regards.
    Kiran Kumar.
    #iworkfordell.
Jun 17, 2015 | Dell Inspiron Computers & Internet
MPC-HC massage D3DERR _ Not available and then the video play and was open as revers pictures (Video) from beginning up to end of video how can fix this problem? i need to see the video as normal...
What do you mean by "reverse picture"? is it a negative or is the picture show left as right? And have you tried to set the image in the options menu?
Aug 10, 2013 | Intel Computers & Internet
Video card or driver doesn't support the required fixed-function texture blend operations. DirectX 7 rendering path will not be available. Video card or driver doesn't support direction lights in...
Hello, the problem seem to be related to the video card you're currently using, See if you have an integrated video card: a hint to find out is to see behind your computer if the monitor connection is on a side of the back panel is probable you have an incompatible integrated video system, you can solve this problem by buying and installing a compatible video card as any Nvidia or ATI card, Call an IT professional and ask for some advice on what card you should buy and install to make these problems disappear, also ask him/her to install it for you.
Have a nice day, and If you have any other questions you can come back and reply.
PD: If you still want to buy and install it yourself ask me again and I'll help you.
Jun 03, 2011 | Microsoft Windows XP Professional
When i start igi2 then the error show me that d3derr not available.
when i start igi 2 there is written that directx error d3derr
Dec 06, 2010 | Computers & Internet
I get an error when loading directs. It say That d3derr is not avaliable. What does that means.
Are you trying to play any games? Check the configuration required to play that game. you can try to upgrade the directx.If it works,
However the error D3DERR NOT AVAILABLE means This device does not support the queried technique.
Sep 30, 2010 | Microsoft Windows XP Professional With...
I tried to play a butter fly game but I failed because D3DERR is found in my PC
You can try downloading this fix from this site to fix the D3DERR error you have... http://tinyurl.com/22sssr7
Aug 09, 2010 | Microsoft Windows XP Professional With...
Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
