Question about Cobra 148 GTL 120-Channels Base CB Radio
Voltage regulator Blowing a. Fuse
  • Dean Dishman Feb 07, 2014
    Hi Mike Torbett, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box?
    Habit-Forming:
    Scholar:
  • 69 Answers
It is very likely that the reverse polarity diode inside the radio is shorted, usually because the radio was connected up incorrectly.
Posted on Jan 12, 2019
Ignition fuse keeps blowing
why did you replace the voltage regulator ?
Jul 02, 2018 | Motorcycles
I just replaced my battery and alternator and my main fuse keeps blowing. Why is that? Also, my tail light fuse keeps blowing.
Check the voltage regulator. If it is giving a to high voltage, it can cost you its of bulbs and in the end the electronics in the car. There voltage should be under 13,6 volt.
Mar 31, 2015 | Cars & Trucks
Why my headlight fuse keeps blowing out on my 2001 sportster. i have a brand new regulator. what else should i try?
Regulator should not affect headlight fuse blowing. You could do a voltage drop test otherwise look for a short circuit in the headlight wiring. IS it shorting and blowing the fuse on both low and high beam? Look for chaffed, broken wireing insulation on wires in headlight assembly and wherever the wires might be crushed by steering stops or mighth be rubbed through from vibration etc.
Jun 05, 2014 | 2006 Harley Davidson XL 1200 C Sportster...
Voltage regulator fuse keeps blowing on my 98 ford explorer
Well I looked at the wiring diagram and I did not see a 30amp fuse.
There is a 15amp, a 7.5 amp, and the two fuseable links between the battery and the alternator. Thats not to say a 30amp fuse for the charging system does not exist, but its not in the standard diagram.
Do you have battery power on the large alternator post when the key switch is off ? And do you have power on the lite green and red wire when the key switch is on ?
Jul 11, 2013 | 1987 Ford F 150
I keep blowing a 30 amp fuse on a 2002, 1200 S Suzuki bandit
Have your voltage regulator checked a bad regulator will blow big fuses like a 30amp, hope this helps.
Sep 08, 2012 | Suzuki GSF 1200 Bandit S Motorcycles
MY 95 ford ranger keeps blowing the voltage regulator fuse. the battery and alternator checks good
Well... If there is a fuse for a Voltage Regulator...then it stands that is the fuse is blowing, then the output from the voltage regulator is exceeding specs. The fuse is protecting the circuits the receive power in that circuit. Replace the voltage regulator. You should be good to go.
Jun 20, 2011 | Ford Ranger Cars & Trucks
If the alternator is plugged up it blows a fuse in fuse panel. Also turn signals
alternators have built-in voltage regulators. if the voltage regulator goes bad, it could over-volt, resulting in blown fuses or blowing the cap off the battery. you can use a voltometer/multitester to test the power at the battery. a running engine should put out about 14-15 volts (14.6 is quite average) at the battery terminals. if your voltage is higher, the alternator needs replaced.
Mar 26, 2011 | 1988 Toyota Pickup
It keeps blowing the ECM Fuse, checked wiring but
My friend;
Try this;
  1. Did you insert same valued fuse i.e. { fuse rated 15APS with same fuse}.
  2. Check OP'S & voltage of the Alternator = 13.7 V DC - 14.8 V DC MAX.
  3. are you sure NO internal shorttings inside the ECM.
How to Test a Car's Alternator
http://www.youtube.com/watch?v=uI0SBtmSjHg&feature =related
Diagnosing an Alternator Problem:
http://www.youtube.com/watch?v=w5TkStVWNvA
how car alternators work
How to Install the Voltage Regulator on an Alternator
How to Rebuild an Alternator
How to Test a Car Voltage Regulator
Try it, & let me know if I add any benefits to you.
I hope I add some thing valuable to you.
Regards;
MAR;
soer2@yahoo.com
Nov 06, 2009 | 1987 Chevrolet V30
My jvc receiver has blown fuse if i replace the fuse and it blows again what else could be blowing the fuse
blowing fuse only indicates that there is power surges in your area. in order to avoid blowing your fuse again. you may need to a have a surge supressor and auto voltage regulator used for your receiver and any appliance that may need it.
Mar 24, 2008 | Audio Players & Recorders
Cobra 148 GTL 120-Channels Base CB Radio Logo
102 people viewed this question
Top Cobra Radio Communications Experts
Steve Allison
Steve Allison
Ernest Taylor
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
