Repairs to static mobile home roof/ceiling
Can anyone advise how to solve condensation/damp problems in the roof of a static mobile home please? Due to damp/mould problems, I have replaced the ceiling in my mobile home, however, I noticed damp appearing on the new ceiling and took it down again. The metal roof above and attached insulation are soaking wet with what I believe to be condensation. I don't know how to resolve the problem. I am told that a 50cm gap needs to kept between the ceiling and the roof but the original insulation is actually touching the metal roof. It is very wet and I have found some mould in here as well. There was no vapour trap when I took the original ceiling down. I have added foil backed insulation boards between the rafters and there are air vents at one edge. Can anyone tell me what I'm doing wrong please?
    New Friend:
You need a proper roof replacement and I think that you should go for it as if you dont want more damage. You can visit the link.
Home
Posted on Apr 15, 2015
    New Friend:
  • 3 Answers
Olmuyor olmuyor!!!!!!!!!!!!!!
Posted on Dec 31, 2013
pierre1811
  • 144 Answers
SOURCE: The shingled roof on my mobile home does not
You actually posted this in the wrong area but I am originally from Minnesota and can tell you. What's happening is called ice damming. They do make a drip edge type of thing that isn't very expensive for just this very thing. Go to Lowes, Homedepot, Menards etc. NOT your local trailer supply as they usually charge more. The clerk at the hardware store should be able to help you. Good luck. Please don't forget to give me a Fixya rating.
Posted on Feb 25, 2009
motor1258
  • 6674 Answers
SOURCE: Coleman 1300, condensation buildup inside unit, ceiling wet
Check for plugged drains under cover on roof, sticking out at base of unit usually. It should be running off roof.
Posted on Aug 04, 2009
  • 232 Answers
SOURCE: evaporator coil needs to be replace again.
the manufacture is only required to supply the part free of charge thru its warranty period. the installing company probably would only give a 1year labor warranty and honor the pparts thru the manufacture for 5 years but unless you paid additinal for an extended labor warranty i dont think you are going to have much luck. Make sure you change your air filters every 30 days a dirty filter is one of the biggest causes of evap coils prematurely leaking. Sorry wish i could be more help.
Posted on Sep 17, 2009
  • 117 Answers
SOURCE: I have a GMPN080 horizontal gas furnace in attic
The reason for the trap is to compensate for the negative pressure the drain line is under. Since the blower is pulling the air, if the trap wasn't there, then the drain wouldn't drain properly.
By having a trap, your blower is pulling air back through the trap while the condensate water is allowed to flow and drain.
With that being said, if you have water forming in your emergency pan, its an indication that the main drain line is clogged up. If you know where the drain line exits the home, take a small shop van and vacuum out the drain line. If its really backed up, it will sound like a golf ball through a garden hose.
If your trap has a clean-out installed, I would recommend pouring some hot water and bleach combination down the trap itself after you have cleared and flushed the drain. The bleach will assist in killing any mold/mildew that has accumulated in the drain.
Also, while your in your attic, ensure your emergency pan has a float switch and that its operating properly.
Posted on Jan 11, 2010
  • 99 Answers
SOURCE: how do find the roof rafters in a pop top.
Hi; Try using a electronic stud finder and switch to metal detection. Or maybe call or google the company that built the popup. Sometimes they can tell You exactly where to make Your cuts...alpharome416
Posted on Feb 23, 2010
Wet ceiling from my bath exhaust fan, how to stop?
Probably due to 1 0f 2 things...
1- Not enough power in the exhaust fan to take out all the mist /steam from the shower.. or
2- Condensation build up due to too much steam at one time.
(especially if fan is NOT ventilated properly)
If you have access to the fan, see if the label states the CFM 's it can remove. May not be enough for the size bathroom you have.
Both of these can be solved by installing a larger capacity fan system. Make sure to vent it to the outside of the home too, since venting to a cold attic area (in winter) can cause even more condensation to drip down.
Feb 17, 2017 | Home
Condensation dripping from ceiling in all electric home with no basement
The wall of the daughter's bedroom is NOT insulated. Moisture from normal activities (showering and cooking) within the house are causing the realtive humidity to be above 50%. When that moisture enters the wall or ceiling, the temperature drops below the dewpoint and condenses out. The moisture that condenses makes a nice environment for the growth of black mold which is highly toxic. The mold will spread by airborne spores. If you have return air ducts for your HVAC system in the room, the spores might be dispersed throughout the entire house, depending on how good you HVAC filter is. Note that if you have a swamp cooler on the roof, it could be leaking water through the ceiling and causing the problem.
You need to immediately move you daughter to another room and remediate the situation -- tear out all the drywall and anything that is damp or has signs of visible mold. Get the humidity in ther house below 50% with a dehumidifier. I would recommend the Winix 50-pint model (refer to link below). This will condition 1500 square feet, which is a lot, but you will need one on each floor.
Amazon com Home Kitchen
Jan 29, 2014 | Kirby Shampooer Shampoo Hose G3 Ultimate...
I wasn to install hampton bay ceiling model 161646 on slanted roof
Buy a longer rod at Home Depot. Should really avoid store brand fans if you want a good fan.
Jan 20, 2014 | Hampton Bay 24002 Ceiling Fan
Chat room - damp floor
Check for a clogged condensate drain line (a/c heat exchanger) which would cause it to overflow onto the floor. It could also be a windshield or sunroof leak. I've had this very same problem from the top of the windshield leaking. There was a very small gap between the windshield and the edge of the roof, Where it's mounted. I had to use a pressurized garden hose to find the leak.
Aug 24, 2013 | Jaguar 02 03 04 05 06 07 08 X Type...
Hooter
Well there is obviously a water leak somewhere. You can't just leave a car for 2 years and expect it to start. The battery must have been flat which means that the anti-theft system needs pairing with the key. This is the reason the horn sounds and it won't start. My advice is to call a mobile mechanic as there will be a number of issues that need fixing. Oil and filter change because the oil will have gone rancid. Also there will be water in the fuel tank due to condensation, and the fuel that is in it may well be bad. Adding fuel conditioner may fix that and a full top up of fresh fuel.
Dec 13, 2017 | Cars & Trucks
My 2008 Buick Lucerne Super has a roof leak. The vehicle has a sun roof. Particularly during rains of long duration, water appears along the interior face of the upholstered columns to either side of...
The roof drain hose may have come off
You may have 4,one on each corner
Or they are clogged
Open the roof & look for drain holes to blow out
If the hose is off, you have to remove the sun visor
& any overhead console, to get the head liner down
& put hose back on
Sep 20, 2011 | 2006 Buick Lucerne
Aug 04, 2009 | Heating & Cooling
Outside of fridge condensation; hissing boiling noise
under the compressor there will be rubber bushes which would have got damaged so change the rubber bush and ur problem may get solved
Jul 25, 2008 | LG LRFC25750 Refrigerator French Door
Heating & Cooling Logo
125 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
