Question about Roland GX-24 Vinyl Cutter
Roland cx-24 reset button - Roland GX-24 Vinyl Cutter
Roland Camm-1 CX-24 Error Er15:RS-232Err How do I fix this? Thanks John
Could you let us know when this error pops up. and what all you have tried
Thanks
proton
Aug 02, 2008 | Computers & Internet
How do I fix a Roland Digital Piano FP-8 that has refused to play sounds despite the fact that it displays lights?
If everything lights up and responds to button pushes like normal, and you've done a hard reset as described in the manual, check to see if you have sound out of the headphone jack. It's most likely not a user serviceable problem and will need to go to the shop, but it will probably be the output amp rather than the main board.
Mar 07, 2015 | Roland Fp-8 Digital Piano Email Us For A...
Convert igp to pcl for kyocera printers
Motor Voltage error displays on my Roland cx 24 vinyl cutter.
Sep 28, 2013 | Kyocera FS-C5015N Laser Printer
When I switch on the power in the roland HPD 15 handsonic, the number screen in the centre has the light but is blank, and the semicircle which has the numbers for different percussions has two lights on...
I had this problem and was about to send it back to Roland but tried a Factory Reset . It managed to fix it self but it has happened again so I woul dbe interested in finding a more perminnat solution .
Did you fix the probolem?
robin
Jan 23, 2012 | Roland Elektronische Musikinstrumente...
How do you reset a Roland R-70 drum machine?
Reset Roland R-70 -- While holding MIDI and ASSIGN buttons down, Switch the Roland R-70 On. PRESS YES TWICE AT the PROMPTS
Lawrence Williams
Jan 07, 2012 | Music
I have a Roland Camm-1 CX-24 cutting machine that has a parallel connection. I have recently bought a Dell Inspiron 1720 with a Windows Vista OS. I have a USB to Parallel cable to connect the two. I have...
connect the printer and the comp. and boot up....windows should recognize the new device.
did you add the plotter to "add printers" and its driver and to the correct port?
make sure your plotter is on and loaded and function key pressed.
also some cable manufacturers supply a driver...so download one if need be.
what software are you using? is the software cutter driver set to the correct printer and port?
(by default it never is)!!
Aug 03, 2008 | Computers & Internet
Roland GX-24 Vinyl Cutter Logo
257 people viewed this question
Top Roland Crafts & Hobbies Experts
R.A. Ellis
R.A. Ellis
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Roland Craft and Hobby Expert? Answer questions, earn points and help others
