Question about Cobra 148 GTL 120-Channels Base CB Radio
Blowing a fuse - Cobra 148 GTL 120-Channels Base CB Radio
    Genius:
  • Cobra Master
  • 1,795 Answers
You have somthing backwards but there is a cure.
Posted on May 18, 2014
What size fuse and WY is it blowing fuses
blowing fuses indicates a dead short after the fuse
check wiring and any relays for faults
May 26, 2016 | Garden
Abs fuse keep blowing what should I look for
30A main fuse keeps blowing up on my 2001 thunderbird - Triumph ...
www.triumphrat.net > ... > Hinckley Classic Triples
Nov 13, 2014 - Posts: 33. 30A main fuse keeps blowing up on my 2001 thunderbird ...Have a close look where the loom passes the headstock & inside the headlight shell..... Battery can't reach out and fry a fuse if it isn't attached somehow. ... main fuseblowing (06 Sprint ST ABS), Lumpy, Maintenance & Workshop Talk, 7 ... Fuse 8 keeps blowing? - Wont start...
Apr 4, 2015
Blowing ignition fuse in the rain
Jul 7, 2013
Main 30A battery fuse blowing
Aug 3, 2008
Legend headlight fuse keeps blowing
Jun 10, 2007
More results from www.triumphrat.net
15a fuse keeps blowing ANY IDEA"S ???? - ApriliaForum
www.apriliaforum.com > ... > Aprilia 650cc - 50cc Motorcycles > RS250
Jun 19, 2009 - 13 posts - ‎9 authors
Ive had my bike at a workshop for the last 4weeks getting a freshn up . ... If the fuse isblowing that quick you should be able to find it quickly , probably .... eliminated the dash and reduced the amount of things you need to look at. .... SL750 / Dorsoduro 750 · 2008-2014 Mana 850 and Mana 850 GT-ABS.
Fuse Keeps Blowing - Electrical - VFR Discussion
www.vfrdiscussion.com > ... > Motorcycle Maintenance > Electrical
Dec 29, 2015 | Motorcycles
88 toyota pick up v6 keeps blowing efi fuse
you may have a short of some kind, when a fuse blows repeatedly it is no good just replacing, you are being told that something is wrong with the equipment.
You will almost certainly have to visit a technician for a diagnosis. It is unlikely to be something that an inexperienced end user can sort out I am afraid.
GOOD LUCK
Oct 26, 2015 | 1988 Toyota Pickup
94 Jeep Grand Cherokee 4x4 with the 4.0 Keeps blowing the fuse that controls the fuse box inside the jeep, its blowing a 40 amp fuse. I believe there is a short. but i don't where to look.
Get yourself a set of factory wiring diagrams,
otherwise your wasting your time
You have no idea what you working on, without
reference material
Helm.Com
Jun 20, 2012 | 1994 Jeep Grand Cherokee
My lumina starts but only stays running for a minute or so before it cuts off and 1 of the fuses keeps blowing under the hood the cover for the fuse box is missing so i dont know what fuse it is
I sounds like it may be your fuel pump fuse or relay blowing, if this happens to be the case, I would go to your local salvage yard and obtain a fuse box cover to see what fuse is blowing, if it is the fuel pump fuse you have a short in the wiring or the pump causing an overdraw of amperage blowing the fuse, you will have to find where the short is, it could be the pump itself or a bare wire going from the fuse box to the pump, if its an ignition fuse you could have a bad coil or igition module that has an internal short, i would first find a cover to see what fuse actually keeps blowing before you can start a better diagnosis of whats going on.....
Dec 11, 2010 | 1995 Chevrolet Lumina
1993 pasco blowing am2 fuse
a wire is shorting to earth so blowing fuse or what ever is on the fuse blowing circuit is drawing excessive current
Jul 05, 2010 | 1993 Toyota Paseo
Kia 2000 sportage auto keep blowing fuse when starting can you tell me what is wrong
well, blowing fuses is caused by a short, has the vehicle had anything done to it before the fuses started blowing ??? and what fuses are blowing, if it is the main fuses that are 200 amp, then it could be caused by faulty wiring, or bad earth.......trust me if it is the 200 A fuse that is blowing, you will be very happy that it is, because if the manufacturer did not put that fuse there, you would be facing a vehicle fire.....i would trace the fault, or have an auto-electrician diagnose for you
Jun 11, 2010 | 1999 Kia Sportage
It keeps blowing fuses - two 12 inch cls subs 1
sounds like the audio stage riving the channel has a short circuit on it.need to go through the amp stage
Jul 16, 2009 | Cerwin Vega CLSC-12S Subwoofer
Starter fuse under the hood keeps blowing....the factory deck was replaced by a new deck...every since then the ignition fuse keeps blowing..
the new radio install is causing this if the power was taped into the starter system. rec. removing wires then try to see if you can blow your starter fuse
Jun 01, 2009 | Car Audio & Video
Keep blowing fuses
hi, make sure you are using a time delay fuse and not a regular fuse. this may be the reason why the fuse keeps blowing out on your dryer.
Mar 09, 2009 | Whirlpool LGV4634JQ Gas Dryer
Cobra 148 GTL 120-Channels Base CB Radio Logo
Top Cobra Radio Communications Experts
AnyMHz.com
AnyMHz.com
Steve
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
