Question about HP LaserJet 4345mfp Printer
Red light start button
My hp laserjet 4345mfp cannot photocopy because the start button has a red light but it can print.what might be the problem
    Novelist:
  • HP Expert
  • 175 Answers
The problem may be the scanner are you able to scan to pc or email/fax from the machine glass/
when the machine initializes are there any faults displayed ( the printer will continue to function even if the scanner fails) usually the error code 30.01.02 or something like that will be displayed-
the scanner is connected via 1 large connector found to the rear of the machine - does the cable look damaged in any way- is the connection 'good' has the grounding wire worked loose, if after these have been checked there is still no scanner then you may need either a scanner or main PCA/formatter fot the printer.
Belmonte business are able to help with the repair of this unit should it be required and would be subject to the usual costs.
available on 0161 480 5556
Posted on Jan 30, 2014
pastorm
  • 98 Answers
SOURCE: Pale print on PDF files
It sounds like a driver problem. Try replacing the driver for this printer on the printers folder, using the HP LaserJet Series II. With this driver, try again the PDF file and see if it prints correctly.
Posted on Jul 27, 2007
checkitright
  • 1362 Answers
SOURCE: hp laserjet 4 plus printer, message window "Ready", off line button shows red
You can try to do a "Cold reset"
turn off the printer hold down  the Menu/reset button and turn it back on.
Do you hear the machine go into rotation? the 4 plus has a high pitch sound follwed by the fuser turning ( you'll know when it does it) if it doesn't go into rotation then there is another problem.
Posted on Oct 15, 2007
Nikhil Gedam
  • 87 Answers
SOURCE: hp laserjet must manually push button to print
Please print a configuration page from the control panel of the printer
- Menu > Information menu > print configuration.
- Check for paper handling details.
Following setting should reflect.
Tray 1: Any size / Any Type
Tray 2: A4 size / Plain Type
If the above settings are not reflecting in the configuration page, please change accordingly by browsing on the control panel of the printer to:
Paper Handling Menu >
Tray 1 Size: Any
Tray 1 Type: Any
Tray 2 Size: A4
Tray 2 Type: Plain
Let me know if that helps to solve the issue.
Regards,
Nikhil.
Posted on Jun 17, 2009
  • 9 Answers
SOURCE: HP LaserJet 4345mfp won't scan, but it wil fax.
This may be related to 3 problems . 1st as with all 49.xxx errors update your firmware first. 2nd it may be related to a memory problem internal to the printer. Last it may be a problem with the email server you are sending to. To troubleshoot update firmware, then remove network cable and try to scan docs is as if you were going to email. If problem does not show check email gate way. If problem does shw up replacing your memory may be the next step.
Posted on Nov 11, 2009
  • 224 Answers
SOURCE: How do I reset the page count on a HP Laserjet
the total page count cannot be reset, if you wish to reset consumable counts replace relevant consumable. thanks
Posted on Mar 31, 2010
Slow print come out with hp laserjet 4345 printer
dear friend,
for slow print many reasons:
1- check tray adjuster
2- check tray customs or standard lock( it will be right side tray lock)
3- check your printer driver
4- check printer firmware
5-check printer fuser
these are the reasons printer work slove
Mar 28, 2014 | HP LaserJet 4345mfp Printer
Hp laserjet 4345 mfp cannot photocopy anything because the startup button has a red light
Hi Bridgette.
The red light on the startup-button indicates that the machine is not ready for a photocopy. Usally there is something stuck in automated document feeder (ADF). Take a close look and see if can see something in the paperpath. If no luck, try pushing a A4 sheet manually through the ADF and see if something comes out with the sheet. Usally there is a small piece of paper, a paper clip or a staple stuck in the ADF. If nothing found in the ADF, the Scanner Controller Board is probably broke, and needs to be replaced. Good luck.
Dec 31, 2013 | HP LaserJet 4730mfp All-In-One Printer
HP Laserjet keeps printing the same print job over and over again with nothing else, and hte pages are not complete.
It is ghost image, check with another cartridge if not resolved, replace fuser assm..(if its available replace teflon sleeve in fuser)
Sep 14, 2011 | HP LaserJet 4345mfp Printer
HP Laserjet 4345MFP Backlight on printer display does not light. Counts up the 256MB memory then HP logo (3 sizes) appears (just visible) The 3 lights keep cycling on the display. Thats it, does nothing...
HP Laserjet 4345MFP
The 3 lights keep cycling on the display. Thats it, does nothing else.
It has been left overnight and continues to display the logo and cycling 3 lights.
Rear DC Cont Fan is turning. No other fans or activity with machine.
When ADF/scanner/mfp or hard disk are disconnected it does recognise this and throws an error and asks for reboot.
I have tried cold reset, nvram init. and hard disk init. but no difference.
Your thoughts?
Aug 27, 2010 | HP LaserJet 4345mfp Printer
My HP 4345 mfp will not boot up, the HP logo keeps flashing on the screen
When the memory counts up when turning mfp on, hold down the 6 button until all three lights on left of panel light up, then using the 3 button to scroll go to COLD RESET and touch 6 button to select. If that doesnt fix ya then you may need a hard disk drive
Jan 25, 2010 | HP LaserJet 4345mfp Printer
HP Laserjet 4345MFP scan to folder is too light.
make sure that you close the cover of the scanner so the original color of the image will apear on it.if you are looking the image on your computer.if the copy when you print will is light, try to change the resolution into picture quality.
Nov 15, 2009 | Office Equipment & Supplies
Jul 25, 2007 | HP LaserJet 4345mfp Printer
HP LaserJet 4345mfp Printer Logo
304 people viewed this question
Seeker5211
Seeker5211
