Question about ZVOX Z-BASE 420
Zvox will not pick up sound from toshiba 40"
All it keeps showing is noAS or AS whenever I press a button on the remote
I need setup code for my zvox sound bar for a Comcast remote?
I am the same boat. Just bought a bigger tv and my zvox doesNOT work now
Jan 26, 2015 | ZVOX 4002201 Audio Z-Base 220 Low-Profile...
ZVOX v-series 320 no sound
Check whether the audio is muted by accidental press at remote control button. Enter its sound menu, and check it. If muted, as you know there will be no audio output. If not muted, check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
Dec 11, 2014 | Televison & Video
Zvox remote not working
Place the unit in learn mode: http://www.zvoxaudio.com/mas_assets/theme/zvoxnew/documents/ZVOX580_LearnRemote_Guide.pdf
Nov 08, 2013 | ZVOX ZBase 580
My Tv not respond with remot control any more
Dear fleeper63,
  • First, make your the batteries in your remote have not run down. To do this,point your phone's camera(after starting the camera app,obviously) towards the transmitter on the top of the remote (a small,transparent bulb like thing). Then, press any button on the remote and at the same time look at your phone screen.If you can see a flash whenever you press the button on your remote,then the batteries are working fine and it is probably a fault in your TV. Take the TV to the nearest service center and get it checked by qualified personnel.
If you can't see any flash,then simply change the batteries in your remote or request a replacement from your local agent.
Oct 19, 2012 | Toshiba 40RV525R 40 in. HDTV
Need remote code for samsung 5.1 home theater surround sound model#HWC560S
Welcome to Fixya. I would like to know who is the provider of the remote so we can provide you with the code. example: AT&T, Comcast or etc.
Please provide the information needed to be able to fix the issue.
Thanks
Sep 03, 2011 | Samsung Audio Players & Recorders
What could be wrong if i have everything hooked up right i have it connected to the back of my directv box with audio coming out and going into input 1 on zvox box and is the blue light suppose to always...
1. Make sure it's connect to "Audio Out" on your DirecTV box.
2. Yes, the blue light should be on while unit is on an received a signal.
3. Check a second set of audio cables, just to be sure.
4. Toggle the Auto On/Off button on the ZVOX remote.
5. Make sure you've turned up the volume via the ZVOX remote.
If all these fail, contact us at zvoxaudio.com.
Tom
Jan 30, 2011 | ZVOX ZBase 550 HSD Lowprofile SoundBase...
Sony Bravia 40inch LCD Digital TV
Its very easy, pick TV original remote and press " i " (info) button on remote and on-screen display will disappear.
Have a great day.
Apr 03, 2009 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Toshiba Regza 32C3000A tv sound keeps droping out, the mute button when pressed on and then off brings it back on. seems as if the tv is auto muting itself?
Could be a contact piece of the MUTE button from your remote that is causing it.
Go out and Big Lots or Radio Shack to get a cheap universal remote control(big lots would be between $5-$10) Pick up the code for it,and when the tv happens again,your the OLD remote MUTE button to turn it back on and then put away this remote control and use the new universal remote control.
However,if the problem is coming from the manual MUTE button on the TV,you need a repair tech, to fix it!
solutiondoct
Nov 10, 2008 | Toshiba Televison & Video
Theatre View Toshiba Rear Projection TV 50 Inch with no sound or picture and a red light keeps blinking
I have the sames t.v you have to go in the back flip the power cord switch...then reboot the t.v.
Jun 27, 2008 | Televison & Video
Not Available
unplug and replug in, does remote work?
Sep 23, 2007 | Toshiba 43A61 43" Rear Projection...
ZVOX Z-BASE 420 Logo
Top ZVOX Televison & Video Experts
Electro Med Services...
Tom Chichester
Are you a ZVOX Televison and Video Expert? Answer questions, earn points and help others
