Question about RCA 20F510TD 20 in. TV/DVD Combo
VHS tape will not eject
After rewinding the tape, it will not play nor eject.
Could you tell me how to remove the tape?
Thank you.
    Problem Solver:
  • 7 Answers
Ida oh won"t be you that removes the tape!
 It should be the Technician you offer $25 to do it for you. It can usually be done with the right gear and often without major damage to the tape itself particularly if what is on it is very important to you!
At the same time you may learn if the repair is worth it.
good luck
Posted on Oct 19, 2007
Our Toshiba VCR won't play tape. It ejects tape after a few seconds.
If you are trying to play older VHS tapes, you may have to run them through some fast forward-rewind cycles to condition them and relieve stress
Jul 20, 2013 | Toshiba D-VR4 DVD Recorder/VCR
Stuck VHS Tape in Samsung TV/VCR Combo
Only easy way is to unplug tv / vcr from AC outlet and plug it again, now try to eject.
Oct 09, 2008 | Samsung CXJ1352 13 in. TV/VCR Combo
VHS tape is stuck in the VCR. Tape will not eject, will not play or foward/rewind. The unit has been working just fine with no problems. The VHS tape has been inserted into the machine to record daily...
assuming you have power to the machine , i would suggest the ejection drive belt has stretched , 2 choices here , take it somewhere and get it fixed or unplug it from power supply and remove the top casing yourself and have a look.
Jan 29, 2018 | Toshiba SD-V291 DVD Player/VCR
Tape ejects after playing for about 30 minutes
it could be dirty pinch rollers causing the tapes to tighten and be ejected. try fast forarding the tape to the end and rewinding. if this does not cure the problem, run a wet cleaner tape through.
Mar 05, 2010 | Emerson EWV403 VHS VCR
Tape would not come out.
Not sure on the removal, but if you replace the mode switch the machine might come back to life.
Jul 31, 2009 | Panasonic PV-7400 VHS VCR
Panasonic VHS Won't eject Tape
unplug then remove the top cover press down on the cassette release and remove the tape then rewind the part of the tape still sticking out by hand push in the button on the side of the cassette to open the cassette cover
May 21, 2009 | Panasonic PV-7400 VHS VCR
Vhs eject will not release tape.
I had a suggestion that did work. Reach into the VHS compartment with left hand and press down toward the back of the tape. With the right hand press the eject button a few times and the tape did come out. I would not buy a Samsung product again. No help from their 800 tech support. No more playing the VHS side of the player. Lynn
Jul 12, 2008 | Samsung DVD-V8600 DVD Player/VCR
VHS tape won't play or rewind
I work at the History Channel and have  a VHS that had the same troubles. I need it desperately for the show I am working on. I tapped it on a table fast forwarded it and presto! Tape fixed, crisis averted. Thank you, Thank you, thank you.
Feb 28, 2008 | Televison & Video
VHS tape was playing . After stoping does not play. Other tape will play
The idler wheel (that only drives the tape in play or scan modes) is slipping too much (very common problem). Try verify this by putting the tape in play then immediately press the fast fwd or rewind buttons to scan the tape. On older machines, the idlers used rubber friction tires - on newer ones, a clutch. Either replace the tire or increase the spring tension on the clutch.
Hope Ya Fix It.
Jan 20, 2008 | Televison & Video
RCA 20F510TD 20 in. TV/DVD Combo Logo
161 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
