Question about GE Spacemaker JVM1640SJ Microwave Oven
Microwave bleeps and display shows F3
Awoken at 5am to microwave bleeping, so switched it off for 10 mins. When i plugged it back in, display showed PF, then it started to bleep again and displays F3.
It will not respond if i try to use touch panel to operate it or clear it.
  • GE Master
  • 9,086 Answers
F3 on a GE / Hotpoint microwave means you have a shorted membrane keypad.
If and when an oven is coming on or doing anything by itself, this is very dangerous and can result in a fire.
So until it is repaired, please leave it unplugged or leave the door open when it's not in use, and please do not leave it running unattended.
If you (or someone you know) might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
If you would like to have us do this repair for you, we do that for $39.95 plus part costs.
But please note that for some GE models, the membrane keypad is not available as a separate part, so you would have to order the control panel frame which comes with a new keypad.
In this case, you simply move your circuit board into the new frame.
Feel free to contact us with your full model number and we can tell you if yours is one of these models, and if so, we'll also give you the part number you need to order and a link to the best priced supplier.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more information & help.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Posted on May 24, 2009
    Sergeant:
    Champion:
  • 214 Answers
The pf is power failor you may have had a power surge and caused that code to come on.Try to unplug for 5 min then plug back in.if dose not work you may have a bad door switch hope i helped:)
Posted on May 20, 2009
Display panel shows E01 and bleeps continuous
A model number would help, but one Sharp commercial manual lists these codes as close to what you typed:
"EE1" Magnetron (1) failure. (could be one of many parts in the magnetron 1 circuit)
"EE0" Fan lock judge.
"EE10" Intake thermistor is shorted.
FixYa's Web site is currently not notifying us when replies to our Clarification Requests are posted, so please post a new help request with your model numbers and precise symptoms.
William E. Miller
prototech@usa.net
May 27, 2010 | Microwave Ovens
GE Microwave displaying --F3--
F3 on a GE / Hotpoint microwave means you have a shorting keypad / controls.
There's a chance it can come on by itself and run unattended, which can result in a fire.
So until it is repaired, please leave it unplugged or leave the door open.
On this model, the keypad is not available as a separate part, so you would have to replace the entire controller assembly.
Then you disconnect the wires and install the new controller.
You can order part number WB07X10903 here for $114.37 (compare that to $174.75 direct from GE!).
Jun 24, 2009 | GE Microwave Ovens
Frigidaire F3 problem
thank you, problem resolve....bought new micro
Mar 22, 2009 | Frigidaire FMV145K Microwave Oven
F3 Error Message
the code means this.
F3 Shorted touch pad panel
Good Luck
Dec 29, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Display only shows 8888 - display buttons do not work.
try a reset. unplug for 10 mins, plug it back, see if it will work.
if not , open the housing, see a ribbon cable from the touch pad to the main pc board. remove the ribbon cable for 1 min. re install it back and test the unit.
be sure to return all cover and screws of the unit before plugging it back. microwaves are hazardous to your health.
tnx 4 using fixya,
drcool
Oct 05, 2008 | Sharp Microwave Ovens
Purchased Bosch Combination Oven/Microwave Ref: E No: HBC84K520B FD NO: 86070009 When press start on microwave it runs then bleeps and shows error message "E9" and stops.
Not sure on Bosch, since it's a non-US brand, but that may be a bad door switch.
If you or someone you know decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
Otherwise, you can get Bosch support here.
We're happy to help and we appreciate your thoughtful rating of our answer.
May 21, 2008 | Bosch Microwave Ovens
My microwave shuts down and shows F3 on the display.
On a GE microwave F3 means you have a failed keypad.
We replace these for customers nationwide with our guaranteed $39.95 service.
If you might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved. It's here.
Please feel free to contact me directly if you need more help.
prototech@usa.net
Apr 29, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
233 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
