Question about HP Photosmart C6180 All-In-One InkJet Printer
0xc18a0001 failure - HP Photosmart C6180 All-In-One InkJet Printer
    Renaissance:
    An user who is expert in 3 categories / brands.
  • HP Master
  • 544 Answers
You could try a power reset of the printer.
Press ON button to turn off printer
Unplug the power cord from the back of the printer
Remove all of the ink cartridges
Wait 3 minutes
Plug the power cord back into the printer
Press the ON button to turn on the printer
Install back all of the cartridges
If this does not work, you could try a hardware reset.
1) Press and hold LEFT ARROW and then press SETUP
Release both buttons
2) Press OK
3) Press & release RIGHT ARROW until LCD reads System Configuration Menu 2
4) Press OK
5) LCD reads Hardware Failure Status: Clear, Press OK to clear
6) Press OK, LCD now reads Cleared, Press Cancel to continue.
7) Press & release CANCEL until the Welcome or Ink System
Failure screen appears on LCD
8) DO NOT PRINT AT THIS STAGE
9) Use POWER button to turn OFF printer
10) Unplug power cord from electrical outlet and from back of printer
11) Wait 1 minute. plug power cord back into outlet first then back into the printer
12)Turn on the printer, Press OK
The printer will start to initiate, do not interrupt.
Posted on Jan 02, 2014
2 Suggested Answers
bestdarngood
  • 3037 Answers
SOURCE: Ink system has failed.
The manual will say to turn it on and off and also to unplug it and hold the ok button while doing so. If this doesn't work, then go to
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=1153494&lc=en&cc=us&dlc=en&submit.y=8&submit.x=5&lang=en&cc=us
and upgrade the firmware, you will first have to select your operating system. This should then solve the problem.
If this still doesn't work, then contact hp at www.hp.com/support and click on Contact Us and go to and sign into the chat line for 24/7 tech support assistance where they will most likely run you through the same process once again but if everything they tell you fails, they will then send you a different firmware.exe file that will definitely fix your problem. Let me know if the link works or if you run into any other problems
good luck
Posted on Jul 21, 2008
MY HP PHOTOSMART D7100 IS HAVING A PROBLEM ERR 0XC18A0001 IS IT FIXABLE?
The error means
PrintHead Failure / Ink system Failure
Hardware error
Try removing the printhead (If removable) and clean the contacts on it, if it doesn't works there are no ways to fix this error
ADCSFXworks Printing Center <3
Nov 29, 2014 | HP PhotoSmart Office Equipment & Supplies
Ink system has failed. Error:0xc18a0001 my printer is HP Photosmart 8250All-in-One System Failure) I refer to printer documentation Error:0xc18a0001 Turn power off, then on again. I dId this command but...
Try taking out the cartridges, and turning off then unplugging the printer. Leave it unplugged for about five minutes, the plug it in. Wait a few more minutes, and turn it on. Wait for it to completely start up, then put the cartridges back in (make sure you are putting them in correctly, I think this is your product here). If it still shows the error, contact HP customer service. They will probably say something similar, though.
Jul 06, 2011 | Office Equipment & Supplies
ERROR 0xc18a0001 Ink system has failed Quite new
Try the link below. This error is related to air in the lines between the print head and the cartridges. It is quite common and HP are very aware of this.
http://fix-your-printer.blogspot.com/2009/03/ink-system-failure-on-hp-photosmart.html
I hope this helps. Regards GM
Apr 16, 2011 | HP Photosmart D7360 All-In-One InkJet...
0xc18a0001
Try using these two reset instruction...these clears most of hp errors starting with 0xc...It works on different hp models.. it could work on you too.
Semi reset
1. While your printer is on.. unplug to power cable from the printer.
2. Press and hold the "OK" and "HELP" buttons while you plug the power cable at the back of the printer. Try these steps to reset your printer to default setting.
Full reset
1. Press & hold " * " key...(asterisk sign)
2. While holding the " * ", press "#" key and then release both keys..."Enter Special Key Combo" will be displayed...
3. Press "1", "2" and "3" to display Support...
4 Press ">" right arrow button and release when System Config Menu appear....then click OK
5. Press arrow key to display Hardware Failure Status...click OK....
6. When Hardware Failure Status:Clear appeared, press "OK" to clear...
7. Press "OK" again to display "Hardware Failure Status Cleared. Press Cancel To Continue".....
8. Press "CANCEL" as many times to display "Welcome To Photosmart Express" or "Ink System Failure".....
9. The last part is to turn off the printer and unplug at the back...wait for 30 sec, then plug and turn on the printer...if asked, press "OK" to continue and allow the "One Time Ink Initialization" to procede..After this try to print...
If you find the reset solutions helpful to you...Please rate this solution and vote on this on the YES below..thanks..
Jun 02, 2010 | HP Photosmart 3210 Printer
Ink system failure 0xc18a0001
Is the device still under warranty?
I hope so, because otherwise you are in the market for a new printer.
Ink feed system is faulty
Parts not available for these models
Dec 08, 2009 | HP Photosmart 3210 Printer
HP Photosmart C6180 All-In-One InkJet Printer Logo
23 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
