Panasonic KX-NCP500 System Logo
s
sunio Posted on Dec 31, 2013
Upgrade IPCMPR Firmware
We have a IP PBX NCP500 currently on Firmware version 2. we need to upgrade firmware version on IPCMPR card to version 7. request your help please . sunil - [email protected]
5 Related Answers
Anonymous
  • 11967 Answers
  • Posted on Sep 13, 2009
SOURCE: How to check Firmware Version ofPanasonic DMC-TZ7
In the setup menu, scroll to "Ver."
electroman
  • 1039 Answers
  • Posted on Nov 22, 2009
SOURCE: TC 32LX70 firmware update .... Will a SDHC card work?
Just use SD card.
Anonymous
  • Posted on Jun 07, 2010
SOURCE: Panasonic DMR-XW350 Network enabling firmware Upgrade.
The web page seems to have a problem in its Javascript that jumps to the page for each location.
You can get around the problem by editing the support page URL, just replace index.html at the end of the URL with one of the options:
For example for New Zealand, change the index.html to nz.html: so the following
http://panasonic.jp/support/global/cs/dvd/download/xw350/index.html
is changed to:
http://panasonic.jp/support/global/cs/dvd/download/xw350/nz.html
The options in the Javascript are listed as follows:
<option value="au.html">Australia</option>
<option value="nz.html">New Zealand</option>
<option value="uk.html">UK</option>
<option value="fr.html">France</option>
Bubba0157
  • 114 Answers
  • Posted on Jul 18, 2010
SOURCE: TH-42PX25U cable card problem. Missing numerous HD & SD channels
Check your signal levels from the cable company. Sounds like they're low or marginal. You may need an amplifier, if so make sure it's a bi-directional (2-way) amp. Surprised the techs that came to the house didn't check this. It's a commonm problem.
Anonymous
  • Posted on Nov 04, 2010
SOURCE: BL-C131 died during firmware upgrade
Seems to be a common problem for these cameras even without doing firmware upgrade. The finnish importer Kaukomarkkinat Oy will not acknowledge it and will only sell new ones to customers complaining about this.
tip
How to Fix Blinking Power Light on Linksys routers......
If you have a blinking power light on the router try to turn off the router for about a minute then turn it back on again. If the power light is still blinking follow the steps below to troubleshoot the problem.
1.HARD RESET- Reset the device to factory default.
a.Press and hold the reset button for 30 sec., after that
b.Unplug the power keep holding down the reset button for another 30 sec.
c.Then, plug back the power keep holding down the reset button for 30sec., after that
d. Release the reset button.
Make sure that you have downloaded the correct firmware version for your router from the Linksys website at http://www.linksys.com/download. You would be able verify the exact version of your router from the sticker at the bottom portion of the router.
2. Connect your PC to port 1 of the router.
3. Assign a static IP to the PC:
To statically assign an IP address
Windows 2000 and XP:
1. Click start, choose Control Panel
2. Double click Network Connections
3. Right click Local Area connections then select properties
4. Select “Use the following IP address” then enter on the IP address type 192.168.1.45 Subnet mask is 255.255.255.0 then Default Gateway is 192.168.1.1
Windows 95, 98 and ME:
1. Click Start, choose Settings then Control Panel.
2. Double click network.
3. Highlight TCP/IP -> for your network adapter (Ex. TCP/IP->Linksys Etherfast 10/100 Network Adapter)
4. Click Properties
5. Select Specify an IP address then under IP address, type 192.168.1.45 Subnet mask is 255.255.255.0 then
6. Select on Gateway tab. On New Gateway type 192.168.1.1 and click Add. Click OK all the way until it prompts you to reboot the computer.
7. Reboot PC.
4. Force the Ethernet card of the PC to 10Mbps
To force the Ethernet Card to 10 Mbps:
Windows 9x and ME:
Go to Start > Settings > Control Panel>Network > Highlight the LAN card you are using with a green icon beside it > Properties > Advance Tab:
-Under Properties set the value of:
“Media Type”; “Connection Type” or “Speed and Duplex Mode” to “10mbps/half-duplex”; “10BaseT” or “10Mbps HD”.
Windows XP and 2000:
Go to Start > Control Panel > Network Connections > Right Click Local Area Network Connection that you are using > Properties > Configure > Advance Tab:
5. Ping the router
a. On WinXP/2000:
Click Start > Run. On the Open field type cmd then hit OK. On the DOS prompt type ping 192.168.1.1
If it replies 4 times, proceed to the next step
b. On Win98/Me
Click Start > Run. On the Open field type command then hit OK. On the DOS prompt type ping 192.168.1.1
If it replies 4 times, proceed to the next step.
6. Proceed in upgrading the firmware of the router.
7. After upgrading the firmware, power down the router and then power it back up and see if the power light is now steady.
To upgrade the firmware follow the steps below:
Access the router’s Web Base Utility [http://192.168.1.1]> Administration TAB > Click on Firmware Upgrade > Click on Browse > Browse or look for the *.bin file > click on OPEN > Hit UPGRADE button. (Just wait for the message “You have successfully upgraded the firmware”) > Click on the Continue.
After upgrading the firmware try to turn off the router for about 30secs then turn it back on again. Hard reset the router then reconfigure it to work on the Internet.
Hope this procedure works for everyone......
Upgrade firmware for Nikon D80
Confirming the firmware version:
  1. Turn on the D80
  2. Press the MENU button and select Firmware Version from the setup menu. The camera's firmware version will be displayed.
  3. Turn off the D80
Basic Upgrade instructions: for detailed instructions, see pdf files below.
  1. Download and expand the firmware files
  2. Format an approved SD (Secure Digital) memory card in the camera
  3. Connect Camera to computer (in MSC USB mode) or use a SD Card Reader
  4. Copy to the top level of the card the downloaded "A firmware" file
  5. Disconnect camera from computer
  6. Update the firmware from the "Setup" menu
  7. Follow the camera's on-screen menus
  8. Repeat steps 2 through 7 using the "B Firmware"
  9. Re-format Card
D80 1 11 firmware upgrade Nikon Knowledgebase
Stuck on please wait
Check your current firmware version before beginning:
  1. Turn on the camera.
  2. Tap the menu tab at the bottom of the monitor to display the setting controls and tap Setup (wrench icon)
  3. Tap Firmware Version in the Setup menu(wrench icon)
  4. The cameras firmware verison will be displayed.
  5. Turn off the camera.
Basic Download and Installation instructions: (New firmware versions contain all previous versions.)
Windows
  1. Create a new folder with an appropriate name on your computer's hard disk.
  2. Download F-S4300-V12W.exe to the folder created in step 1.
  3. Run F-S4300-V12W.exe to create the folder titled S4300Update, containing the following:
    • firmware: folder containing the firmware.bin file
    • firmware.bin : the firmware located inside the firmware folder.
  4. Insert the memory card containing the firmware folder into the camera and turn on the camera.
  5. Tap Firmware version in the Setup menu and follow the instructions displayed to upgrade the camera's firmware.
  6. After the upgrade is complete, turn the camera off and remove the memory card.
  7. Check the Firmware version item in the setup menu to confirm that the camera's firmware has been upgraded.
For detailed instructions, please see the PDF files below.
Macintosh
  1. Download F-S4300-V12M.dmg.
  2. Double-click the F-S4300-V12M.dmg icon to mount the disk image titled, F-S4300-V12M.
  3. A folder titled S4300Update, containing the following files, will be created inside the disk image:
    • firmware: folder containing the the firmware
    • firmware .bin: the firmware
COOLPIX S4300 1 2 firmware update Nikon Knowledgebase
KX-TDA Series Maintenance console
p/s i need support on kx-tda100 maintenace console gives errror
the software that can maintain the kx-tda 100/200 version is not installed to this pc
any one with ideas p/s p/s i need to configure it p/s
1helpful
How to upgrade the firmware on my Canon XS
You can go directly to the most recent version without installing the intermediate versions.
2answers
Can't see the folders after restarting SS400-e
If you check their website, you will find:
Upgrading from a previous version of the firmware (to version 1.4) is a “data destructive” process.
it is strongly recommended that you first backup your existing data to another system in your environment. It is also recommended that you understand your current configuration of users, groups and shares to be able to recreate this under the 1.4 firmware.
4helpful
2answers
How to upgrade the firmware on a BEFW11S4
Firmware upgrades may erase all previous settings to your router's configuration. Before upgrading your firmware, make sure to record your settings. 1. Unplug and disconnect all computers from the router except for one. This computer must be plugged into the router directly. There can be no other network activity (wired and wireless) on the router during the upgrade, so be sure to power off all other computers. 2. Go to http://www.linksys.com/download 3. Select the model number of the Linksys router you have. Make sure to select the correct router version as well, as firmware upgrades frequently vary by version. You can find your router version underneath your router after the model number. For example, ?BEFW11S4 ver. 2?. 4. Click the Downloads for this Product button. 5. Once you arrive on the download page, click the Firmware button. 6. After the firmware page opens, click the link that says ?Click here to download the latest firmware...? and download the firmware file to your computer. 7. Once you download the firmware Zip file, unzip it. If you do not have an unzipping program, go to http://www.winzip.com and download WinZip, which will allow you to unzip the file. 8. After unzipping the firmware files, one of them will be called TFTP.EXE. Double click on it. 9. When the ?Upgrade Firmware? window opens, you will have three prompts. The ?Server? field is for the IP address of your router; by default this would be 192.168.1.1. 10. Enter the routers password into the ?Password? field; by default the password is admin. 11. Browse for the file in the Firmware Upgrade utility program by clicking on the button next to file with the '?' symbol on it. Look for the file named 'code.bin' in the folder where the firmware files were extracted to. 12. Highlight the code.bin file and click on the Open button to direct the TFTP loader program to put that file into the "File" box. 13. The full path should be displayed [example: c:\linksys\code.bin]. 14. Click on the Upgrade button to begin the upgrade process. 15. The upgrade should take about 1 minute, and you will be prompted after the upgrade is complete and successful. If you are still having troubles, contact Linksys Technical Support.
Getting The WRE54G To Connect With The WRT54G
The WRT54G, WRT54GS, and WAP54G all must have the latest firmware versions available installed in order to connect with the WRE54G Wireless-G Range Expander. Here are the minimum firmware version requirements that you must meet: * WRT54G (all versions): at least firmware version 2.02.2 * WRT54GS: at least firmware version 2.07.1 * WAP54G (all versions) : at least firmware version 2.07 To Identify your WAP54G Version Number: To find out which version of the WAP54G you currently have, flip your Access Point over to look at its underside. Near the serial number label, near the Linksys© logo, you will see your model number and a possible version. Labels for the WAP54G version will look like one of the following: * WAP54G (no version means Version 1) * WAP54G ver. 1.1 * WAP54G v. 2 For WAP54G Version 1 and Version 1.1 Users ONLY: (if you have a WAP54G Version 2, you may proceed with the 2.07 or later firmware upgrade) NOTE: Before upgrading the WAP54G Version 1 and Version 1.1 models to firmware version 2.07 or later, make sure your Access Point?s current firmware is version 1.09.1 beforehand. The version 1.09.1 code performs an important OS upgrade for these versions of the Access Point -- it must be loaded before using later firmware.
3helpful
256 Sandisk SD card problem with an Optio 33LF
Optio 33LF Firmware Upgrade Information & Instructions: This firmware corrects "camera freezing & cannot display images" issues with Sandisk & Black's 128MB & 256MB Secure Digital Cards. This problem is occurred because Sandisk changed the manufacturing location from the Philippine's to China during production of the Optio 33LF. They also change the electronic chip used the SD Card which caused a compatibility problems with Pentax, Minolta, Palm and other digital device manufacturers. In turn this also caused a problem with Black's SD Cards as they are manufactured by Sandisk. Therefore, we had to release a Firmware Upgrade for the Optio 33LF to correct compatibility issues with these SD Cards. HOW TO CHECK WHAT THE CURRENT FIRMWARE VERSION: Confirm the current firmware version by pushing and "HOLDING DOWN" the "Right Arrow & Right Zoom" button located at the back of the Optio 33LF. While continuing to hold the "Right Arrow & Right Zoom" button turn the POWER on the Optio 33LF. The current firmware version will be displayed on the LCD. If the firmware version reads "Current Version 01.01.05.04" then your cameras firmware is up to date. If you do not have the current version, then please refer to the information listed below. Please be sure to upgrade your camera. You can download the firmware from the following link. Please be sure to follow the instructions listed below. Firmware Download: http://www.pentax.ca/support/digitalsoftware/fwdc113p.elf Firmware Update Instructions: Please refer bellow to learn how to upgrade the firmware on the Optio 33LF. Should you have any problems please contact our customer service department. I have included our contact information bellow. PLEASE NOTE: 1. It is very important that the batteries do not deplete during the firmware upgrade as this will damage your camera. Therefore, please check your battery indicator prior to the firmware upgrade. FIRMWARE UPGRADE #1. Save the attached firmware "fwdc113p.elf" to your Desktop. #2. Put a Secure Digital Card in your Camera. #3. Format the Secure Digital Card to be sure that no other information remains on the Card. (Refer to page 86 of your Operating Manual) #4. From your Desktop right click on the firmware "fwdc113p.elf" and select "COPY" #5. Double Click on "My Computer" you should see your "REMOVABLE DISK" #6. Right Click on the "Removable Disk" and select "PASTE" Once the "fwdc113p.elf" file has been copied to the Secure Digital Card, be sure to properly disconnect your USB device if you are using Windows Me, 2000 or XP. For instructions on how to disconnect a USB device with Windows 2000, please refer to the Optio 33LF Operating Manual. Now that you have the Firmware on the Secure Digital Card. #1. Be sure the Secure Digital Card containing the Firmware Upgrade "fwdc113p.elf" is in the camera. #2. Be sure that your batteries are fully charged as you do not want the
Top Panasonic Lands Phones Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
