Question about Dual XDVD8181 Car Video Player
Gettin feed baq from the subwofer output when Y splitter is attached to feed RCAs to the amp.
My dual xdvd8181 in dash reciever is sendin feedback to my subwoofers through the subwoofer single out put.. when i used a Y spliter it send feed back to the subs but when i pull out one of the rcas from the y splitter the feedback stops. how do i fix this?
    Problem Solver:
  • 11 Answers
Use a "y" adaptor on the amplifier inputs instead of the headunit output. In other words run a single rca line from the headunit to the amplifier but connect to a one female into two male y adaptor before connecting to the amplifier
Posted on May 21, 2009
How do i wire up my amp to the pld70bt there are so many pre outs and do i need a crossover not getting the bass that i should be getting
The specific unit has a mono sub woofer output. It is the Grey coulerd RCA output. Buy a male to female Y-Splitter( it is a RCA connector that has one male RCA plug on one side and two female RCAs' on the other side.Now just connect that to the rca that is going to the amplifier. As this is the dedicated sub woofer output use it.
dreamsystems.
Feb 11, 2011 | Pyle PLD70BT Car DVD Player
Jensen uv10 amp hook up
how to power on the amp on my flip out headunit
Feb 07, 2010 | Jensen Car Audio & Video
Our first tv has a booster amplifier on the coaxial cable, i have purchase a new tv and need to know what product i need to us to attached the new tv's coaxial cable too. We have used a splitter box, but...
To have good picture quality you need zero DB (decibels) for one TV without a splitter. You can use and inline amplifier for each individual TV hooked up to the cable input with a output leg connected to each TV. If your house in wired in parallel (one main input hooked up to a splitter with all of the other TV's run off of the splitter) you can use a whole house amplifier hooked up inline between the input line and the splitter. If you house is wired in series (the input goes to the first outlet, then splitter to second outlet and so forth) each splitter knocks your signal levels down 50% each splitter. Amplifier placement depends on how the home is wired and how many TV's are in the home. Splitters can be either balanced (50/50 split) or imbalanced (75/25) etc. On a two way splitter 75% of the signal goes out one leg, while 25% goes out the other (usually for FM transmissions). If you have a three way splitter the signal is divided by the number of output legs. Splitters do go bad as well (sometimes only one leg). You can also buy an amp that is multi- port (which splits the signal and amplifies in one unit/ one input and 2,3,4 outputs). Amplifiers are electric and there is no way that the splitter can interrupt the power that would take all the signal away. If you meant that it drops the signal level so the picture is unacceptable, that's different. If you have another splitter in the house try using that one, the other might be bad. All in all you can purchase most anything you need at a Radio Shack and are very inexpensive. Amps can be purchased in different gains (boost). +10db, etc. I cannot believe that your cable company is giving you such minimal signal that 1. you need an amp?, and 2. that one splitter drops your picture to nothing? Your line extenders (amps for the lines that feed your neighborhood) might have problems or need adjustment by the lazy, cheap, cable co. also. I had problems with my cable company (when I had one) my modem would not stay online. 4 months later, they diagnosed the problem and my drop (RG56 cable line that feeds my home from their tap in the cable box outside) was bad. My friend could stay online and 2 months later comcast adjusted their amps (line extenders) in the neighborhood and then he was fine. I know this is a lot to digest, but I'm just trying to draw a clear picture so you can understand it all. I hope this helps and good luck!
Nov 07, 2009 | Televison & Video
Ok I just bought a used fosgate amp belive its a T10001b could be wrong its big has fan 3 led lights and some pioneer premier 10 flat subs think there 4ohm. I bought a brand new amp install kit 6gauge...
eyp, most of the time speaker connections blow and fuses wont stop that from happening. They are there to stop the mainboard from frying and not working at all. try running rca splitters to the operational side of the amp. run the sub on 1 channel. you will start hearing a difference but both sides will work. if not, run the splitters from the head unit and bridging it. these are the cheapest solution i could provide
Jul 27, 2009 | Rockford Fosgate Punch P5002 Car Audio...
Gettin feed baq from the subwofer output still
#1 you need a ground loop isolator to put on the RCA cables. that should fix the problem... put one off the amp leading to the sub also cause that will also fix it these gorund loop isolators can be picked up at any electronic installer shop.., you might be able to find them at radio shack to but i would not buy those cause they dont work as well as the better ones, i would suggest any auto alarm radio installer shop.... hope this helps you...
Jun 20, 2009 | Dual XDVD8181 Car Video Player
How to work Dual DVD8181 7" Touch Screen without a remote
Visit this link to download your products manual/user guide: http://safemanuals.com/user-guide-instructions-owner-manual/DUAL/XDVD8181-_E
..................................................sodeep
Jun 03, 2009 | Dual XDVD8181 Car Video Player
Condition on HDMI input when Denon AVR-2807 switched off
hello if you know this spitter conduct voltage and its feed from main device and when you connect another it send it ground you have to do this chech with a voltmeter in the hdmi splitter output is not dc present if so change it cause is not blocking dc current saludos
Dec 04, 2008 | Denon AVR-2807 Receiver
4 subs and two amps
I'm not that familiar with the insignia line but If the amps have an "input" and an "output" for the RCAs then run the RCAs in one, Then hook the output of that one to the input of the other. I did this with my 2 memphis 500Ds and it worked great. It also looks better than a couple of splitters, but yes You would just get two splitters with all female connections on them so you can plug 2 sets of RCAs into the one set. Also it doesn't really matter how you hook the RCAs up unless you are going for stereo sound then you would need to make sure the rights are hooked up together and the lefts are hooked up together. I hope I could help.
-Andrew Hawkins
Jul 22, 2008 | Car Audio & Video
CAN I ADD A TV TUNER TO MY DUAL XDVD8181 HEAD UNIT
just hook up a vhs or dvd player from home that has tv outputs, but you would need a power inverter for the power supply of the vhs, then put the vhs audio and videos outputs to the dual's input: the auxiliars. make sure the vhs has channel changing.
Jan 08, 2008 | Dual XDVD8181 Car Video Player
Onkyo 605 Reciever no sound from zone 2 RCAs
did the AS amp ever work properly from the RCA's?
Dec 05, 2007 | Onkyo TX-NR801 Receiver
Dual XDVD8181 Car Video Player Logo
105 people viewed this question
Top Dual Car Audio & Video Experts
xxxxxx xxx
Jeff Turcotte
Jeff Turcotte
Are you a Dual Car Audio and Video Expert? Answer questions, earn points and help others
