Bose av3 2 1
Bad disk
Bose system plays disk one beautifully,but when changing to disk 2 it says reading disk and then "disk error"....difficult to remove disk...
hi,
There is some problem with the timing of the changer mechanisum of the player. As it is very complicated mechanisum you should need a good reparing experence to rectify the same.The mechanisum is not properly selecting the disk 2. Try to consult the bose autorised servicing center or any trusted electronics reparing shope near you.
ok
Sep 04, 2011 | Bose Wave music system Multi-CD Changer...
My bose life style system 38 had a an hard disk error, i check the disk and it was broken so i boy another disk from impact computers spare part but i having the same error 801 and 802 call bose
I am sorry but it is dead in the water. You have to call Bose.
http://www.fixya.com/support/t326707-life_style_error_codes_801_802
Many people having the same problem. Sorry
Jun 24, 2011 | Computers & Internet
It won't play disks and just makes a lot of mechanical noises as it goes from disk to disk trying to play one.
The mechanical parts are working but the laser pickup assembly is not reading the disc. The possible causes are, dirty laser pickup lens, bad pladder motor, or no b+ to the motor, or worn out laser assembly system. Because of the expense of buying the Bose units I highly recommend a professional service man to work on the item.
Dec 28, 2010 | Bose Acoustic Wave (32022) 5-Disc CD...
BOSE Companion 5 speakers connected to an Apple but no sound.
if you have a bose disk then you will need to run the install disk firsthope this helps if it does please rate this answer
May 12, 2010 | Computers & Internet
I have a Bose 321, 5 years old. It has started dropping the dialogue track on DVDs but the music track still plays. It is tempremental about the DVDs it plays, often reads bad disk or the DVD freezes. ...
BOSE offered a software upgrade to address the issue of freezing and not playing certain disks. You can get that right from BOSE by calling tech support. I am not sure that that will help with the newest symptom though (the humming).
Sep 07, 2009 | Bose 3 2 1 GSX System
I have an older 3 2 1 system that will not play any dvd's. Says "Bad Disk". Always has been a little particular when it comes to playing dvd's but now it won't play any- new or rented. Any ideas?
Have you ever done a software upgrade? I have the same system and I had issues with certain disks. After a call to the BOSE tech support line, they sent me a software upgrade disk that took care of the issue. Worth a try.
Aug 14, 2009 | Bose 3 2 1 GSX System
Bose 3-2-1 JUNK - Cannot Read Disk problems
You can get a bose update if you contact customer service
Jun 26, 2009 | Bose 321GS Series II System
DVD won't play
had the same issue, Bose 18 played no problem for 2.5 years and then started acting up.
sometimes power reset helped sometimes not.
finaly go tired of it and took the system apart.
Inside is little customized toshiba dvd ide drive set as master.
Same as in normal computer but with different front so works in Bose.
Took apart DVD and cleaned with the laser lens with windex.
Works perfectly now.
I took the long run. If somebody has dentist mirror and some precise tools maybe you can reach the lens without taking everything apart.
maybe somebody sells special disc for cleaning lenses?
I hope this helps.
Oct 28, 2008 | Bose 3·2·1 II System
I have a Bose acoustic wave muti-disc changer.i have 5 disk in changer,i cannot eject any disk,& it looks like its hung up on # 5.non of the disk will play. Thank You-
I called Bose service. Jason said to unplug for 1minute then plug back in. If the changer does not reboot and operate properly....you call Bose service. They will exchange your cd changer for a new one.
$75 plus tax and return your cd's to you. They will give instructions for the exchange when you call.
Aug 22, 2008 | Bose Acoustic Wave (32022) 5-Disc CD...
 Grubhead
Grubhead
