Restarting, resetting, or Force quitting the apps.
Restart iPad: Press and hold the Sleep/Wake button until the red slider appears. Slide your finger across the slider to turn off iPad. To turn iPad back on, press and hold the Sleep/Wake until the Apple logo appears.
Force quit an app: Press and hold the Sleep/Wake button on top of iPad for a few seconds until a red slider appears, then press and hold the Home button until the app quits.
If you can't turn off iPad or if the problem continues, you may need to reset iPad. This should be done only if turning iPad off and on doesn't resolve the problem.
Reset iPad: Press and hold the Sleep/Wake button and the Home button at the same time for at least ten seconds, until the Apple logo appears.
Turn it off when its off connect the cable that's used to charge it to a pc or laptop making sure ipad is still off hold the home button do not let go now keep it held down until you connect the cable and see a picture symbol showing to connect to iTunes as soon as you see that on the ipad you can let go off the home button if iTunes doesn,t open itself you do it it should now see an ipad in recovery mode click on restore or restore and update please note that this will erase your whole ipad back to factory settings
- there is NO trash can on any iPad.
however you can empty some hidden cache etc. and free space by making a hard shut-off.
To turn off your iPad, first press and hold the Sleep/Wake button on the top-right corner of your iPad. After a few seconds, the red "slide to power off" slider will appear. Simply swipe it to the right and your iPad will power off.
-wait about 20seconds (until the dim-lighted spinning wheel disappears) and turn it on again How to turn off your iPad
This tutorial will explain how to force your iPad to restart if it gets stuck or freezes up.
Forcing your iPad to restart will not cause any loss of data - with the possible exception of any work you were doing at the time the iPad and/or App froze, forcing you to restart it.
Click and hold down the Sleep/Wake button (located on the upper-right corner of your iPad). While you're holding down the Sleep/Wake button, hold down the Home button as well (located on the front of your iPad at the bottom). Hold down both buttons until your iPad powers off. It will reboot and start again with a small silver Apple image on the screen. It takes about 30 seconds for the iPad completely start up.
Connect your ipad to itunes then put it in recivery mode
-1 turn on the ipad
-2 keep holding the power button and the home button till the device turns of and then turns on
-3 release the power button and keep holding the home button till u see and itunes photo on your ipad
Now open itunes and restore
