Question about Brady TLS 2200 Label Printer
Whenever printer is turned on it feeds a blank label
Printer TLP2824 thermal printer prints too many labels. Prints one and then spits two more out(blank).
Clean media sensors. The blank labels are a result of the printer trying to calibrate label length.
Aug 12, 2013 | Zebra TLP 2824 Printer
Prints lable every 5 labels the rest are blank
Troubleshoot to see if the problem is with the printer or the software. Turn the printer off and back on again for fresh start. After the POST (power on self test) press the FEED key and see if the printer feeds just 1 label. If it does then you know the optic sensor in the printer has a good read on label size. If it feeds more than one, then it needs to be recalibrated for label size.
If it feeds 1 label, then print a format. Now if it prints 1 label and then feeds blank labels, you know the problem is in the label software you're using or in the printer driver. The printer will only do what it's told to do.
At least this way you can narrow the problem down to the printer or the software.
Hope that helps....
Jun 19, 2011 | Zebra Stripe S600 Thermal Label Printer
When I print one label, it dispenses two labels, the second one is blank.
You may need to calibrate the printer for size of the label installed in the printer. To do that follow the instructions below but, before you do that MAKE SURE that the labels loaded in the printer match the size you expect to print.
Make sure that printer power is off. Press and hold the feed button and then turn the printer on. When the status light blinks, release the feed button.
The printer advances the media to measure and verify the length of individual labels or tags. The printer then prints a status summary and remains in diagnostic mode.
To begin normal operation, tap the feed button.
Regards
mikeo@acebarcode.com
Feb 11, 2011 | Zebra LP 2844 Thermal Printer
Blank labels being fed
Re-calibrate the printer by switching the printer off, press and hold the feed button whilst turning the power on. Release the button when the light flashes red. Once calibrated try again, if no joy then try a different driver
Oct 08, 2009 | Zebra LP 2844 Thermal Printer
Blank labels keep feeding out
Disable start up calibration maybe?
May 09, 2009 | Zebra 105SL Thermal Label Printer
Balster advantage label printer form feed
Hello David,
You have to make sure that the printer is not running out of ink.
Try to uninstall/re-install the printer driver. This often resolves the issue about printing problem.
Apr 16, 2009 | ATSI Holdings BD422003 Thermal Label...
Printing in page mode feeds extra blanc labels
Make sure,
you firmware is right one for that printer because in most of cases it happens due to wrong firmware and bad ADF kits. so check your ADF kids and if you find them fine the install updated firmware on in.
once you done with these all then turn your printer off and turn it back on.
post back if any thing changes and rate all answers.
Good luck
Feb 24, 2009 | Epson TM-L90
Tlp 2844 printing first page ok then prints another blank
First thing to try is a reset of the printer.
1) Turn printer off.
2) Hold down feed button whilst turning printer on.
3) Let go of the feed button as soon as it starts to flash and then wait.
4) Printer will measure out 4 labels then print out a Hex dump ending with a not to "Push Feed to Exit"
5) Push feed
Follow the above instructions, if you mess around tapping the feed button (not following the above) you can change the printer between line mode and page mode. To swap that back is another storey.
David
Jan 03, 2009 | Zebra LP 2844 Thermal Printer
Datamax M-4206 - error light whenever load or print labels
Perhaps the sensor is out of position, you must move to the left. Also check that the hole senser is not blocked. Also verified that the sensor type (gap or black mark) in the software is correct.
Sep 09, 2008 | Datamax M-Class M-4206 Thermal Label...
Zebra LP 2844 prints blanks
If the printer is printing nothing but blanks, try another roll of labels.
If the printer is printing blanks in between labels, it probably needs to be gap sensed. You can do this by:
1. turn the printer off.
2. hold the feed button down and then power the printer back on while still holding the feed button down.
3. release the feed button when the light flashes.
4. the printer will then regap itself
5. when the regapping is done, press the feed button once. It will print on the label that it is 'out of dump'
6. the printer should then be ready to go.
May 03, 2008 | Zebra LP 2844 Thermal Printer
Brady TLS 2200 Label Printer Logo
41 people viewed this question
Top Brady Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Bob Rambo
Level 1 Expert
NOEL
NOEL
Are you a Brady Office Equipment and Supply Expert? Answer questions, earn points and help others
