Question about West Bend (58036) 36-Cup Coffee Maker
Disconnected pipe The pipe has come off of the top part of the damper system, how can I reconnect it, or what part of machine do I have to take off to do this
Rudd achiever 90 plus. does not ignight with top cover on...without cover it works fine
Most likely a venting issue, does this have 1 pipe or 2 pipes? if it has 2 you can try it with the inlet pipe disconnected to see if there is a restriction somewhere in the pipe. It may also be in the exhaust pipe, although you don't need to run it with this pipe disconnected because you can vent the flue gases into the home. How old is this system? Has it worked fine prior to this issue?
Nov 02, 2010 | Heating & Cooling
Tub spins as if over-loaded but, is not. Machine
broken missing or just disconnected damper spring / ******** top of outer drum. that would cause the symptoms you describe. look up washing machine parts and go to an E-parts store like repairclinic.com or something, enter your model number and go from there. good luck and I hope this helps.
Jan 31, 2010 | Amana Washing Machines
Our Kenmore 417 48102701 goes through the drain and spin cycle however the spin cycle does not go fast enough to spin all the water out. Any suggestions?
After I move to a new home I have same problem, spin cycle was slow, I remove back panel, clean up the pump (found a quarter) also remove the top cover, I found due to the movement one pipe get disconnected, after reconnecting, everthing is fine.. also take a look inside there is a manual with service code....need a liitle bit of logic to decode it.. thanks..
Jan 01, 2010 | Kenmore 44102 Front Load Washer
Spin cycle has become out of balance
The vibration damper(s) may be broken, disconnected, or worn out. Remove the top so that you can see the sides of the outer tub (assuming a top-loader machine), and shake the outer tub in various directions while watching the damper positions. There should be at least three such dampers, maybe more, and they can be several types from friction pads to tiny automotive-looking shock absorbers. If the tub seems offset to one side, look for one of the absorbers that may be out of place or disconnected. Hope this helps.
Sep 27, 2009 | Washing Machines
Hose disconnected inside. How do I get inside to reconnect?
Look for a removable back sub-panel that has the exhaust pipe running through it or near it.
Aug 01, 2009 | Dryers
I need to replace the seal round the door but cannot remove the old one
Take the top panel off by removing the two screws underneath the lid at the rear and look down inside towards the front door edge of the drum you will see a very large metal hose clips holds the door seal on. A screwdriver will loosen the clip then the clip will slip off and then the seal can be removed and replaced
May 29, 2009 | Indesit WA 125 Front Load Washer
There is no water going into my washer on either side (hot or cold). i disconected the hoses from the taps and them tourned them on and no water . it was just working fine yesterday. please help. thank you
If you disconnected both hoses and there is no water flow, remove the sediment filters at the feed end of the hoses and clean them out. Before you reconnect them, flush about 2-3 cups of water through the pipes to clean out the junk.
Dec 18, 2008 | GE WBSE2090A Top Load Washer
West Bend (58036) 36-Cup Coffee Maker Logo
18 people viewed this question
Top West Bend Coffee Makers & Espresso Machines Experts
Douglas Dinnebeil
Douglas Dinnebeil
Are you a West Bend Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
