Question about HP Compaq 6710b Notebook Pc
6710b motherboard power ic - HP Compaq 6710b Notebook Pc
  • Dayton Computer
    Dayton Computer Jan 03, 2014
    Hi manoj , I want to help you with your problem, but I need more information from you. Can you please add details in the comment box?
Hp compaq 6710b is not powering when i put the powerpack
Does that mean it DOES power up without the battery?
Or by power pack do you mean the AC adapter?
Replace it. either way
Apr 09, 2014 | HP Compaq 6710b Notebook
My laptop hpcompaq 6710b does not power on Ac and the battery doesn't charge. But it works fine on battery. Help me please
The AC adapter is probably bad. Or I've even seen the little pin where you plug it in broken off. But my guess is the adapter is bad. Very common thing to happen to them.
Oct 23, 2012 | Computers & Internet
Battery light flashes 7 times
This is a motherboard issue, remove ram memory one at a time and power up each time, if this fails! it is the main board, the only option is to replace the motherboard or buy a new laptop.
Apr 28, 2012 | HP Hewlett Packard Compaq 6710b Notebook...
HP Compaq 6710b not charging powering up laptop
You need to check the voltage on the adaptor. If there is no votlage please check on this link to check on the adaptor.
http://www.fixya.com/support/r5164850-laptop_power_supply
If the adaptor is good then the fault can be in teh motherboard or the charging circuit within. Please check the voltage at the pins of the battery terminals in the laptop to confirm. If so you must get support from HP to estimate.
Aug 22, 2011 | HP Compaq 6710b Notebook
Hi, I have an HP Compaq Laptop 6710B which
Usually this is cause by a defective battery. Replacing the battery should fix if.
Thanks Tonm
Aug 07, 2011 | HP Compaq 6710b Notebook
A faulty charger with a kinked cable cause a short while my HP 6710b laptop was running out of battery. With a new charger the laptop shows no sign of life (no power light on), so is the system board...
Welcome to fixya
Unfortunately it seems that the system is having a no post/no power issue. Since you have a new ac adapter the system should power on with that, Please note that the dc connector is also part of the motherboard. I also believe that the motherboard was damaged due to the shor.
Apr 28, 2011 | HP Computers & Internet
My HP Compaq 6710b was fine and then just died, what happened?
First,you should check wether the connected power or Compaq business notebooke 6710b battery is OK.If There are no problem ,then there maybe some strange matter !
Sep 23, 2009 | HP Hewlett Packard Compaq 6710b Notebook...
HP Compaq 6710b
It should be the third button to the right from the top byt the power button. Here is a link to a pdf that shows where everything is on your model.
http://h20195.www2.hp.com/V2/GetDocument.aspx?docid=0900a5a5821030aa&cc=bg&lc=bg
May 23, 2008 | HP Compaq 6710b Notebook
HP Compaq 6710b Notebook Pc Logo
59 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
