Question about Chauvet Colorado 1 DMX LED Wash DJ Lighting
Unlock chauvet COLORADO 1 - Chauvet Colorado 1 DMX LED Wash DJ Lighting
How to fix chauvet CH460LS
*BUMP* I, too, have a dead channel on my Chauvet CH-460LS Controller-Dimmer.
Jun 05, 2014 | Chauvet Followspot 400g with Stand
My sound active mode is not working correctly. it goes at a fast pace even turned all the way down.
If you're sure you're in sound mode then it sounds like yet another faulty chauvet unit. Buy something from a better manufacturer and you've got a chance but in our experience Chauvet are a rule unto themselves and the kit is not worth buying. We have had nothing but trouble with them and no longer buy their kit no matter how tempting the price.
Jan 27, 2014 | Chauvet 4play Led 4 Play Dmx Moonflower...
Using 24 chauvet par 56 led and chauvet obey 40. when going to bank 5, 6 or even 11, some fixtures will remain on while some will flicker. 2 fixtures per channel on the console. DMX addess starting at 1...
Read about terminating the chain with a resistor 120 ohms. If your run has appreciable length, a termination MAY be necessary to avoid digital reflections that can corrupt the message between the control and the lights. Having separate power sources CAN subject the units to "ground bounce" that can also corrupt the digital control. You need to power all the units from a single source or conditioner if possible. Another solution might be to use one of the DMX radio links which would isolate the ground problem. Another fix you MIGHT try is to get some of the clamsheel ferrite devices that clamp around the wires. Put these around the digital cables, not the power cords:
http://www.google.com/products/catalog?hl=en&sugexp=ldymls&xhr=t&q=ferrite+core&cp=8&bav=on.2,or.r_gc.r_pw.&wrapid=tljp1304006132890014&um=1&ie=UTF-8&cid=761843538070174409&sa=X&ei=-Y25TaXFGsjYiALh_8ky&sqi=2&ved=0CFEQ8wIwAw#
Apr 28, 2011 | Chauvet (4) Chauvet Led Par 56-24c 7...
I am using 3 Chauvet colorstrips. They are hooked up perfectly to my DMX controller via master/slave. There are no problems with the DMX controller. The Chauvet colorstrips are flickering simultaneously...
Check if you may need to use a terminating resistor on the DMX chain. Sometimes digital reflections on the cable can cause random behavior.
Search "DMX termination" for explanation.
Also MAKE SURE you set the program mode to 021 (RGB).
It sounds like you might be in one of the automatic modes or sound triggered.
Mar 08, 2011 | Chauvet 6x Chauvet Colorstrip Color Strip...
Just got a Chauvet Trident and plugged it in and the moter tunrs left then right , then stops ? The LED's blink 1 time then that is it ?
The left right motion is when the motor calibrates its position. The unit is then waiting for input... try generating a loud noise... if the audio gain is up and it is configured for manual rather than DMX it should start.
Dec 24, 2010 | Chauvet Brand New Chauvet Trident Dmx-512...
Have 2 Chauvet Intimidator Spots. 1 no longer projects light and the bulb is not the issue. It powers up, goes thur its start up routine but will not light the bulb
This unit got a 24volt lamps that came from a transformer. Usually the ceramic contact of the lamp get damaged and corroded after some time and can be replace. You should test at the same time that the voltage is allright with a multimeter. Most sound shop keep such ceramic in stock because its always broken....
Aug 10, 2009 | Chauvet Followspot 400g with Stand
DMX-55 Chauvet
Try joining www.djforums.com and posting there to see if there are any Spanish speaking members who can help you.
May 22, 2009 | Chauvet Dmx 55 Dmx Controller
I am trying to connect a Chauvet Followspot 400G to an Elation Sc
Just follow the details below to set your spotlight.
The TFX-FS360 utilizes 2 DMX control channels.
Channel 1 is for the colour.
Channel 2 is the dimmer.
1) Press the FUNCTION button until the DMX Mode LED turns on.
2) Press the UP or DOWN buttons until the starting channel address you desire is located on the digital display. eg 19
Regards
Jon
Feb 28, 2009 | Chauvet Followspot 400g with Stand
Chauvet Light Color Wheel not working
I bought one of these new for our church and one of the colors would not work. I opened it up and found the control board. There was a line of diodes that were on the board. I found one of them bad. It had split into. It was a signal diode. I think you might be able to get these at radio shack. Use a small soldering iron and electronic solder( there is a difference.) Take the old one out and put the new one in and make sure you get them in the right way.(because it won't work or it will burn up) Hope this is helpful.
Feb 13, 2009 | Chauvet Followspot 400g with Stand
Chauvet Colorado 1 DMX LED Wash DJ Lighting Logo
49 people viewed this question
Top Chauvet Home Security Experts
Lawrence Oravetz
Are you a Chauvet Home Security Expert? Answer questions, earn points and help others
