Question about Apple Iphone 4s I Phone 4 S Factory Unlocked Sim Free 16gb - White
Phone will not turn on
Used phone this a.m. and then when I tried to use it again it would not turn on battery is charged
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
    Problem Solver:
  • 10 Answers
Yo bro try in dfu mode?
Posted on Dec 31, 2013
My bluetooth is not working and battery problem please solve my problem
hi there!
If you're having a problem with bluetooth then ill be advising you to powercycle your phone and you can do that by removing the battery on your phone while the phone is on.After that reinsert the battery and turn on the phone again and try turn on your bluetooth again.Kindly check as well if your phone is fully charged because bluetooth will not work that good if the battery on your phone is not fully charged.Kindly check as well if the device your pairing with through bluetooth is compatible with your phone because there are devices that are not compatible with each other.
If the battery is the problem then try doing the rebooting or powercycle process of the phone.If its still not turning on then kindly charge the battery for a maximum of 4 hrs.Please check if the battery is holding a charge.If it still not working after doing that then there might be a problem with the battery.Kindly replace the battery so that you can use your phone.
Thank you!
Apr 20, 2011 | Cell Phones
My phone completely turned off. The battery died. However, I can't talk on the phone while it is charging. The light is orange. I had other phones where the battery died and I can still talk on it...
Some phones won't work until the phone's battery has a minimum amount of charge before you can use it with a charger connected. This often due to the fact that the charger doesn't provide enough power to operate the phone by itself. It can only provide the trickle amount of power to slowly charge the battery. Let the charger stay connected long enough for a 15 - 15% charge on the battery and then try again.
Nov 12, 2010 | Computers & Internet
Does my phone have to fully charge before i can use it again?
No, try and remove the battery again. wait a few minutes.
Now replace the battery, plug the phone in, now press and hold the call button which is the on button for 10 seconds and see if it powers up.
Any more questions just ask.
Feb 07, 2010 | Motorola Mobility RAZR V3
My HTC p3300 battery not gettin charged. It works on direct power for some time and get automatically shutdown after some time..indicating no charge. Keeps shutting down often.
I too have been experiencing problems. Replaced the battery but it happened again. The battery says it is at almost 100% capacity however several times in the day, when I go to turn it on it doesn't respond. I end up taking the battery out and then have to connect it to a charger (USB) so that the charging light blinks red once and then turns off. I can then put in the battery again and it will start up again. If I don't connect it to the charger cable to drain (get the red light to flash once), and try just putting back in the battery, I've noticed that the screen has a faint glow as though it was on but the screen is completely blank. I'm starting to think that there must be a short circuit somewhere because I'm going to assume that the new battery is good.
Feb 20, 2009 | HTC P3300 Smartphone
Battery problems
You need to replace your battery.  When you do follow these steps to preserve battery life.
1.  Fully charge battery for 24 hours 2.  Make sure that you use the phone without charging it until the phone tells you the battery is low. 3. Fully charge the battery until it reaches full again.
The reason your battery is failing to hold a charge is a problem call battery memory.  The less power that you use off the battery the less capacity the battery has.
Jan 04, 2009 | Nokia 7270
My cellphone keeps turning itself off and then back on again when i try to connect to the internet
THis is all I have found so far... bear in mind that the phone will probably use more power when on the intenet
The battery doesn’t charge properly or the
phone sometimes turns itself off
• Wipe the charging contacts both on the phone
and on the battery with a clean soft cloth.
I suggest you try a WHITE pencil eraser to clean battery contacts and then clean again with alcohol, ethanol, methylated spirit etc then air dry before turning off
Jul 01, 2008 | Samsung Cell Phones
Phone Frozen
Try taking out the battery overnight and replace and try to turn on. If this doesn't help, then try updating your phone's firmware.
http://www.sonyericsson.com/cws/support/softwaredownloads/detailed/updateservice/w300i?cc=gb&lc=en
May 24, 2008 | Sony Ericsson W300 Cellular Phone
I got a signal the battery was low, and now after charging my phone doesn´t start again??
Do a search on the site http://wiki.xda-developers.com/ Try the Keywords "Bricked"
Feb 02, 2007 | O2 Xda II Smartphone
Apple Iphone 4s I Phone 4 S Factory Unlocked Sim Free 16gb - White Logo
21 people viewed this question
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
Lesley Cameron
Lesley Cameron
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
