Question about Kelty Bull Dog Walking Cane. Wood Carved replica of the mighty bull dog. Italian design with brass collar and black wood shaft.
How do you measure the diameter of a round pole
  • Frank Clarko
    Frank Clarko Dec 31, 2013
    Hi Frank Clarko, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box? I just would like to know how to measure the diameter/circumference of the pole portion of my cane, did that help?
IF A TABLE IS 90" CIRCUMFERENCE, WHAT IS THE MEASUREMENTS ACROSS
Circonference = Pi x Diameter. Hence Diameter = Circonference / Pi
Pi = 3.14
Circonference = 90"
Diameter = 90/3.14 = 28.6"
Apr 07, 2017 | The Computers & Internet
How much salt do i need for a 15ft round by 4ft deep pool
  • Calculate your gallons of the vessel.
    • On Avg. 15' x 4' pool = 5,000 - 5,500 gallons
    • Then identify current level of salt.
  • If 0 - you will need about 150 lbs to bring to minimum 3200 ppm
Apr 30, 2015 | Pool & Spa
How do I measure stove pipe?
The accepted technique for measuring stove pipe is by the inside diameter. Simply because the outside diameter of double and triple wall pipe are much larger by comparison to the inside diameter. There's no standard for outside measurement that would transfer in a logical manner.
Oct 14, 2014 | DuraVent DVL Dura-Vent DVL 8-Inch Vermont...
How many gallons of water in a 24 foot round pool that is 52 inches deep
18,600 gallons (length x width x depthx 7.51 =gallons)
Aug 23, 2014 | Pool & Spa
YES SOMEONE STOLE THE SEAT AND POLE TO MY MOONGOOSE SPIRE BIKE AND I NEED TO KNOW WHERE I CAN BUY ANOTHER ONE
measure the diameter of the hole in the frame where the seat post goes. Get online and order one. They vary in size so get a precise measurement.
Apr 03, 2013 | Mongoose Spire 26 Inch Men's Mountain Bike
I cannot install the bike seat pole into the bike
First, you need to make sure that this is the correct size seatpost. There are many different diameters of seatposts and you need to be sure this is the correct size. If you have a set of calipers or a micrometer you can measure the inside diameter of the frame and the outside diameter of the seatpost. if you don't have these tools you can take it to your local bike shop. If you are certain that this is the correct seatpost it may be that you just have some rust on the post that can be taken off with sandpaper or steel wool. Put a little anti sieze compound on the post, slip it into the frame and tighten the bolt. good luck
Apr 14, 2010 | Schwinn Sport Cruiser Women's Cruiser Bike
Westinghouse 64832 pole lantern specs
A standard lamp post is 3 inches diameter. The base of the lantern slips over the post. It's inside diameter is slightly larger than 3 inches and a screw is used to tighten the base against the post.
Nov 07, 2009 | Westinghouse Electric Westinghouse 64832...
Where to purchase a bracket
Unfortunately there are two standards for the pole diameters. Some of the smaller poles have caps to accomodate the larger brackets. First thing is to measure what you have for poles and the two sizes of mounting holes. Many of the mounting bosses are standard and available online here is an example:
http://www.amazon.com/Speaker-Cabinet-Metal-Stand-Mounts/dp/B0035AJTL8
Sep 19, 2009 | Mackie SWA1501 Subwoofer
Kelty Bull Dog Walking Cane. Wood Carved replica of the mighty bull dog. Italian design with brass collar and black wood shaft. Logo
65 people viewed this question
Top Kelty Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Kelty Toy Expert? Answer questions, earn points and help others
