Question about EXP Systems PDF ReDirect
Error code 100
I get an error code 100 when converting Page maker documents to PDF
  • EXP Systems Master
  • 1,087 Answers
How to convert a Page maker file into PDF formate. I am using Page Maker 7.0 and Adobe Acrobat Distiller 6.0. And I am using Samsung Printer drivers to convert page maker to post script.
Go to print, select the printer as ADOBE PDF on my document\*.pdf, then the PPD as ACROBAT DISTILLER ****.***, and set the paper size, etc final go to print, then give file name for the pdf.
Mar 30, 2015 | Adobe PageMaker 7.0 for PC
Tip
How to Convert PDF to Word?
Want to edit PDF files? Tenorshare PDF converter helps you convert PDF to Word that can be editable as you like. It not only supports .doc output format, but .rtf as well. Only three steps, you can synonymous convert PDF files to Word documents with format 100% retained.
Step 1: Import PDF files
Download Tenorshare PDF Converter and install it on your PC. Run the program, you can see the following interface. Select "Convert from PDF", Click "Add Files" button to add PDF files you want to convert. Tenorshare PDF Converter allows you to add unlimited files one time for conversion.
NOTE : If you want to know more about conversion settings parameters, please click "Settings" to review. You can set format, language, etc. there.
Step 2: Specify output options and folder
You can customize all pages or any one as you like to convert. And there are two output formats for you to choose. Then click "Browse" to locate your output folder for your destination files.
Note : To customize pages to be converted, use commas (,) and dash (-) only between page numbers. For example, enter 22, 12-15 means converting the 22th page, page 12 to 15.
Step 3: Convert PDF files with one click
Click "Convert" button to start conversion. After successfully completed, the finish dialogue window will appear. Click "Open File" button to view the converted file or click "Close" button to close the screen.
on Feb 25, 2011 | Computers & Internet
Tip
How to convert PDF to word best
Do you have some PDF file or you have downloaded some PDF file that you want convert to Word file? Then this article may be useful to you.As we all know,most PDF documents are not editable and copy and paste text manually can be a tedious process.What is worse, after the process the text file may mess up.
What should you do ? There are many free and online PDF to Word Converters on the market. Most of them are free and has the ability to convert PDF to Word. Some of them even support convert PDF files in batch to reduce time uploading PDF files one by one. However there are some questions that not all the free PDF to Word Converter can give the proper answers. After search up in Google, here I find the best free way of converting PDF to Text, that is using Advanced PDF To Word 5.0.
Advanced PDF To Word 5.0 offers the easiest way to Convert PDF To word. You don't even bother to launch the program. Just right-click the PDF file then select Convert with Advanced PDF To Word. Then you can gain Word file within seconds with non-need elements like logos, fonts, layouts and graphics disappeared.
Remove PDF Password
What is more amazing, Advanced PDF To Word has the function of removing PDF password- the owner password. If you can not copy or edit an urgent PDF file, you don't need to do the exhaunsting typing job or hire some freelancers to do it. If the PDF has been set an owner password, besides right-click conversion, you may just follow 3 steps: (1)Add the PDF files(supporting batch and partial conversion), (2)Specify the output folder, (3)Click Convert. Then you will have the desirable content in plain Text.
Multi-language Conversion
Some users may have non-english PDF files like Chinese, Korean and need to extract Text to translate into english. Most of PDF to Word Converters don't support multi-language conversion. However,Advanced PDF to Word Converter can do this perfectly. Just convert PDF to Word and translate it using Google Translate. Then you can convert it back to PDF by using PDF creator or free office save as PDF function.
Partical Conversion
If you don't need all the content within the document, the software expands your control during the conversion process. There’s no need to bother with reformatting and deleting the converted content afterwards. Select the pages you need to create the Word file the way you want. You may select a single page or set a page range like from page 1 to page 17. There is a page number at the end of each page to indicate you, so you can find the content easier.
Advanced PDF To word 5.0 is really the best solution to Convert PDF To Word.It recognizes rotated pages and its contents and preserves text, formatting, tables and images in the converted Word document as in the original PDF document. Text fonts and style, image placement, text columns, and overall document layout is preserved 100%.What is more, can convert PDF file which was restricted by author to prevent others from copying, editing or even printing. There's no need to waste time opening and converting each individual document, when you can drag and drop all of the files you need into Advanced PDF To Word, and with one click process multiple files at once to maximize time savings.
on May 10, 2010 | Computers & Internet
I want to change my pmd file into word file please help me
Go to the Adobe website, Click Here and download Acrobat Distiller and Adobe PostScript. These add-ons are necessary to convert PMD files to PDF files. Follow the onscreen instructions to install them on your computer.
Open Adobe Page Maker from your program menu, which can be accessed by clicking the start button on the bottom left-hand side of your screen.
Click on "File" and "Open" in Adobe Page Maker. Navigate to the PMD file that you want to convert. Double-click the file to open it.
Click on "File" in your PMD document. Click on "Export" and choose "PDF." This will open a new window. Page maker will give you the option to choose between "print" or "onscreen" PDF. Choose onscreen if you just want to share your PDF over the Internet. If you want to print it out, choose print. The latter option generates a larger file which will take up more space on your computer.
Select settings for your file. For example, you can select "security settings," "Doc info" or "Hyperlinks." Each option will give you various settings from which to choose. Once finished, click on "Export." Choose the location where you want your document to be saved. Click on "Save."
I hope that this assisted you, thanks for using FixYa! John
Mar 07, 2011 | Computers & Internet
How can I convert my pdf files to Microsoft Word format?
You certainly can convert an adobe file to editable word file but if you think that all OCRs convert the document 100% into editable format then you are about to make a costly mistake. Your converted document is bound to have errors which you need to remove ( unless of course your original is a picture perfect document). No OCR on this planet guarantees 100% correct conversion in all documents all the time.
Therefore it is extremely important that you must proof read your editable format document before you start to edit. If you don't do that it can be a very expensive mistake you made in life.
Some people (including me ) pay $2.0 per+ per page and get it edited by experienced staff on a paid site like http://www.onlinedocumentconversion.com.
Jul 31, 2010 | Epson Online Experience - Print Academy...
How do I add text to a scanned document?
Below instruction might be helpful to you.
With the PDF document open in Acrobat 7 Standard or Professional, choose File > Save As. In the Save As dialog box, choose Microsoft Word Document from the Format (Mac) or Type (Windows) pop-up menu. Then simply click the Save button, and open the document in Word for editing. The conversion may not be perfect, depending on factors such as the complexity of the layout, and whether you have the document's fonts on your system. For simple business documents, Acrobat's Save As command does a decent job of converting to Word.
Thank you.
Jul 31, 2010 | Online Double Conversion 1500VA 1050 Watt...
Need to scan a multiple page document into a pdf. Every time i attempt to do so, it scans each page and creates an individual file per page.
You must get an Adobe program to do that... OR combine them later. Adobe Professional 8 will allow scanning multiple pages into a document I use it all the time. There are also other PDF makers/converters too, to download. Another way is to scan into Word, or similar, and then "Print" as a PDF.
Mar 03, 2010 | Brother MFC-7420 Printer
Can't save multiple page scan to multiple page pdf document
that should be because you scanned the pages separately, did you notice if the PDF document converted was the very last page of the 13paged document which you wanted to make a document from? if that's right, then you just only converted the last scanned page into PDF, to stick all the pages together, i recoment you treating them as images and using word to stick them all together with the "insert>image> from archive" adjusting the size of the image at 1 page and with each 13 pages do the same until you have a full document of 13 images in 13 pages then you can convert it into PDF
Sep 14, 2009 | Brother Multi-Function Center MFC-240C...
I can not use unicode font in my lamguage with page maker
Sir, I use Adobe page maker 7.0, I collected some documents from website. All that documents are Arial Unicode MS. I cannot edit the scripts in Page make, I copy the document and paste in the page maker, but all letter convert to other font, so please tell me how can edit the documents in same fonts in page maker.
Feb 21, 2009 | Adobe PageMaker 7.0 for PC
Flash paper won't convert to PDF anymore
Jul 07, 2008 | Macromedia Contribute 3 And FlashPaper 2...
Computers & Internet Logo
253 people viewed this question
Top EXP Systems Computers & Internet Experts
David Payne
David Payne
Are you an EXP Systems Computer and Internet Expert? Answer questions, earn points and help others
