Question about Kitchen Ranges
Install instructions Installing wb24t10063 on ge range
How can I get a copy of the manufacturer's installation instructions for a Hotpoint JX-81J over the range microwave oven?
JX-81J is the microwave recirculating charcoal filter for several models of GE and Hotpoint microwaves. The installation instructions will be available from the manufacturer with the model number of the microwave itself.
One microwave that uses this filter is the RVM1535MMSA . See http://products.geappliances.com/ApplProducts/Dispatcher?REQUEST=HPSPECPAGE&Sku=RVM1535MMSA#tab1_ for all of the details on this microwave. The owner's manual, http://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=39-40541-1.pdf , shows the installation of the filter on page 34. The guide for installing the microwave above the range is http://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=39-40425.pdf .
If you have a different microwave, add a comment with that model number. I hope this helps.
Feb 13, 2017 | Hotpoint Microwave Ovens
Installing lower oven door on GE profile gas oven`
Removing or Reseating Oven Door To remove most oven doors:
  1. Open door to the BROIL POSITION, where you feel hinge catch slightly.
  2. Place your hands on both sides of the door near the handle.
  3. Lift the door up and away from hinges.
  4. If the door does not readily lift off, there may be 2 phillips head screws on the inside of the door down near the hinges that are holding it on.
To replace the door:
  1. Place your hands on both sides of the door near the handle.
  2. Resting door against knee, line up door with hinges and slip into place.
For instructions specific to your model, check your Owner's Manual or Installation Instructions. Download a copy of your Owner's Manual and/or Installation Instructions
Aug 11, 2016 | GE Profile 30" Self-Cleaning Freestanding...
How can I tell if the touchpad is bad or the ERC is bad?
Ge JSP47 Manuals
www.manualslib.com > Brands > GE Manuals > Cooktop
... User Manuals. View online or download Ge JSP47 Owner's Manual. ... Self-CleaningElectric Ranges. Brand: GE .... Special Features Of Your Oven Control18.
Oct 01, 2015 | GE JSP47 Electric Kitchen Range
Does the replacement (GE infinite switch WB24T10026 for model JSP42SK4SS) come with installation instructions for taking the bad unit out?
No, when you buy a part there is no instructions . Manufacturers want you to call an authorized technician these days so they will not provide you with any instructions
Mar 14, 2011 | GE JSP42 Electric Kitchen Range
What is the clearence for installing a GE microhood Model # jvm1540dm2ww
That will be in the installation instructions.
You can download GE owner's manuals and installation instructions here.
Feb 09, 2010 | GE Microwave Ovens
Hotpoint RVM1535DMCC OTR micro-has NO stove top draft.
Did you check the installation instructions and the owner's manual?
here.
If you still have a probme, I would call the GE Answer Center:
GE Answer Center®
1-800-626-2005
Monday - Friday: 8 a.m. - 10 p.m. ET
Saturday: 8 a.m. - 7 p.m. ET
Closed Sunday.
Mar 05, 2009 | GE Hotpoint Over-the-Range Microwave
What is the required amps for a JSp46 range
if the range you have is just like a regular 4 burner & oven all you will need is a30amp breaker
Jan 03, 2009 | GE JSP46 Electric Kitchen Range
GE XL44 and soot from burners
propane burns very dirty.you need to remove the burners and orfices and clean them good with oven cleaner.make sure their rinsed and dried well before installing,this should solve your problem.
Nov 08, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Black soot on pans
You could be correct in your assumptions. There should be a set of small brass nozzles included wirh your installation instructions. these are for the burners and will have to be changed. There is also a gas regulator that attaches between the gas line and your range, there should be a large brass hut on one side. the nut is removed and a peg on the underside has to be flipped over to convert the regulator to LP. There should be instructions included in your installation manual or contact GE for the parts and instructions if you do not have them.
Apr 27, 2007 | GE Spectra JGBP35 Gas Kitchen Range
Kitchen Ranges Logo
14 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
