Savin 5002 error code sc899 - Computers & Internet
How can i clear error sc899-00 on mpc4502. i have updated all he firm and changed I/O BUFFER TO 256KB still it keeps coming up even with out being on network
SC899 codes typically are when people are printing web pages. Make sure all firmware is the most current revision. If it still occurs then there is a special firmware revision on the Ricoh website to remedy that.
Oct 31, 2014 | Ricoh Office Equipment & Supplies
Sc899 00
You must clear the print cue. SC899 is from printing from the Internet (typically). With the paper trays open, turn on the machine. Push the Printer button and reset all the print jobs.
You need to update all the firmware on your machine.
Sep 08, 2014 | Ricoh Aficio Office Equipment & Supplies
How do I clear error code SC899?
service tech needs to update the firmware. sc 899 cause by printing of the internet.
Jun 26, 2014 | Ricoh Aficio Sp 4310N Monochrome Laser...
Error code sc396
Drum motor bind. mechanical bind or defective motor. Hard to tell without a model #
Mar 05, 2012 | Savin Office Equipment & Supplies
SAVIN 2055 WITH AN SC301 CODE
SC301 error code description:
Charge Corona Output Error 2
Charge Current Leak
Charge would need to change number of pieces corona wire A166 9516 (to confirm with the service repair center) Charge Corona Wire.
Hope helps (remember to rate this)
Sep 30, 2010 | Savin Office Equipment & Supplies
Savin error code E-547 error code?
Fusing unit trouble.Clean the thermofuse and thermistors,check the heater lamp.After ,enter in the service mode turn the power switch OFF unplugged the crd.Wait 10 sec. plugg the cords and turn ON the machine.I think the Savin is based the Ricoh copiers machine.The service enter code is : Press the toral clear key - 1 - 0 - 7 -hold down the C key more 3 sec.
Aug 17, 2009 | Savin Office Equipment & Supplies
Savin 2522 sc542 error code
It's a fusing warm up error. The temperature isn't reaching the right rate within 20 seconds.
There isn't a reset procedure due to safety reasons. If you replace the thermistor, it should go away.
Mar 16, 2009 | Office Equipment & Supplies
Copier reset procedure.
hi fixya180,
It seems that the error code 541 (which indicates a problem with the heating unit thermistor in the machine), cannot be reset by the user for safety reasons, ref;
http://savin.custhelp.com/cgi-bin/savin.cfg/php/enduser/std_adp.php?p_faqid=7081&p_created=1102093227&p_sid=9TrLDc-i&p_accessibility=0&p_lva=&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PWRmbHQmcF9ncmlkc29ydD0mcF9yb3dfY250PTQzNiZwX3Byb2RzPTI1MTAsMjUxNCZwX2NhdHM9MCZwX3B2PTIuMjUxNCZwX2N2PSZwX3NlYXJjaF90eXBlPWFuc3dlcnMuc2VhcmNoX25sJnBfcGFnZT0xJnBfc2VhcmNoX3RleHQ9ZXJyb3IgY29kZQ**&p_li=&p_topview=1
This error requires service support from your local authorized dealer or original point of purchase. You say that you've verified the functionality of your fuser unit; then a authorized Savin printer technician will probably just have to reset the error code of your copier.
Hope you find this info helpful in solving the problem and thanks for using the FixYa service
Kind regards
Mar 07, 2008 | Computers & Internet
Computers & Internet Logo
35 people viewed this question
David Payne
David Payne
