Question about Krups Coffee Makers & Espresso Machines
Lungo not 110ml
Lungo button does not dispense 110ml, only 50ml.
  • Krups Master
  • 1,238 Answers
Try holding the lungo button continuously down while it brews the whole 110ml then release. Try it again normally and it should be reprogrammed.
Posted on Mar 01, 2014
When I press the espresso button instead of esspreso makes a long coffe .I must ad I descaled it yesterday .
You may have accidentally changed the amount setting for your espresso shot when resetting the descale counter.
If you lost the manual you can find one here.
http://www.gaggia-usa.com/support_docs/Gaggia_Brera_Quickstart_Guide.pdf
On page 11 (with the printed number 31) you find how to change these settings:
• Place a cup under the dispensing spout.
• Hold the "espresso size" button pressed for 5 seconds to enter the programming mode; the "coffee" icon will blink quickly and the coffee will start to be brewed; the icon will flash during the whole coffee brewing cycle.
• Press the same "espresso size" button again when the amount of coffee in the cup reaches the desired level.
At this point the button "espresso size" is programmed; each time it is pressed and released, the machine will brew the same amount of coffee that was just programmed.
The same operation can be repeated for the "Lungo size" button.
Jun 15, 2015 | Gaggia Brera Coffee Maker
HOW TO ADJUST WATER QUANTITY AS THE LONGER BUTTON WILL NOT ADJUST, SHORT CUP IS OK
Try resetting to factory settings by holding both buttons down while turning the machine on - hold till lights stop flashing. Then programme both espresso and lungo buttons again in the usual way.
Hope this helps!
Mar 13, 2015 | Nespresso CitiZ & Milk Espresso Maker
Why too little coffee
The machine is calibrated to produce a certain amount of water depending on which button is pressed (Lungo or expresso - larger or smaller cup). This can be altered by holding down the relevant button - check this manual..
http://www-media.nespresso.com/ecom/websites/manuals/inissia/inissia_C_krups.pdf
Aug 23, 2014 | Nespresso Inissia
Nespresso descaling
Make sure the machine is ON and you have power, then proceed as per instructions.
Jan 12, 2014 | DeLonghi Coffee Makers & Espresso Machines
New machine but water does not dispense
I have the same issue except sound comes but the water level in the tank is still the same
Dec 06, 2012 | Nespresso Citizmilk D120
My Nespresso citiz lungo button will only give expresso amount of water
Ok, what you have done is programmed your machine. If you hold down the button for 3 secs you get 3 secs of coffee, so turn on your machine wait for it to warm up then without using a capsule press and hold the button until you get 110mls for a lungo and this will be stored in the memory. If this doesn't work there is a on/off switch on the right handside turn it on with your finger down on the lungo button for 5 secs and then release the button and this will take it back to factory settings.
Jan 13, 2011 | Nespresso Citiz D110
How do I reset the machine to the 50ml/cup factory setting?
I have a similar problem that the 1 cup (50ml) setting now produces about 150ml and the two cup setting just keeps going until the machine is empty.
The manual says press and hold the 1 cup button until it starts flashing together with the power light and the coffee starts flowing, then press the 1 cup button again when you want it to stop and the machine will memorise the new setting. I tried this on mine and it didn't work - I'm guessing something has worn out but dunno what...
Jul 17, 2010 | Krups XP 4050 Espresso Machine
Non si vede niente dal monitor
tre bip lunghi potrebbe essere un problema della tastiera.
Nessun bip = difetto di alimentazione, problema alla CPU o alla scheda madre, periferiche in blocco.
* Un bip = tutto funziona normalmente.
* Due bip = errore POST/CMOS.
* Un bip lungo ed uno breve = problema con la scheda madre.
* Un bip lungo e due brevi = problema video.
* Un bip lungo e tre brevi = problema video.
* Tre bip lunghi = errore tastiera.
* Lunghi bip ripetuti = errore di memoria.
* Brevi bip ripetuti = difetto di alimentazione, problema alla scheda madre.
* Continui alti e bassi bip = surriscaldamento CPU.
guarda anche questo sito
http://www.sergiogandrus.it/index.php/2007/08/22/hardware-significato-dei-bip-beep-del-pc-allavvio/
Dec 31, 2008 | Intel D945GCCR Motherboard
Nespresso C1OOB not sucking water out of the tank anymore
I had the same issue and spoke to Nespresso this morning.  To solve this you need to reprogram-put a capsule in the slot and place a cup on the drip tray-press and hold the lungo button until the coffee has reached the desired height in the cup and then release the button.  That should work and every time you make a lungo cup it should be that amount. Hope this was helpful.
Oct 19, 2008 | Nespresso C100B Essenza Single-Serve...
Coffee Makers & Espresso Machines Logo
52 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
cyfred
Level 1 Expert
Ross Keen
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
