Question about Magic Chef CAV4000AWW Top Load Washer
Washer won't drain ....
I know I made a mistake by washing a large mattress pad. It over-loaded my washing machine (top loader), and I had to take out the pad, with the water still in the machine. It didn't ever spin, probably because of the weight. Then, after getting the mattress pad out, I tried completing the wash cycle so it would drain (without any clothes in it), and it won't drain. It will agitate, and act like it's rinsing, but won't drain. Any ideas for what I can do?
Thanks so much.
Charlotte (in Houston, TX) ;-)
  • 975 Answers
Have to open the washer and look at the bottom side for a small DRAIN MOTOR PUMP , thats where the DRAIN HOSE is connected , need to take out the motor pump , inspect inside for any debri or lint thats clogging the motor , clean it , replace it , and try again , it should work , thanks
AJ
Posted on May 20, 2009
Pad keeps ripping in center when i wash it
most likely its the size of washing machine making it rip , something this large should be washed in a large commercial washer ,its too small a diameter in the drum to bend a large sheet around without pulling it (ripping ) on a home size washer
Feb 10, 2016 | Perfect Fit White Magic Loft Mattress Pad...
Whirlpool top loader model LSQ9010pw6 won't spin but does drain.
Sounds like you need to replace the Clutch Assembly- Complete clutch assembly for direct drive washing machines. Comes with brake cam driver. Includes blue spring for large capacity washers and black for compact washers.
this video should help
http://www.youtube.com/watch?v=tVc6SZ2DD4U
Aug 13, 2011 | Washing Machines
Front loader won't spin and is filled up with water. Won't drain.
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
May 15, 2011 | Kenmore Energy Star 44092 Front Load...
My washing machine will not drain? Is there a way you can force drain the washing machine. It is a top loader Fisher and Paykel large washing machine? Thank you
If the pump is out then no. Try this. With the power off, while holding the wash temp down button, press the power button. This will put it in diognostic mode. If your pump is not totally shot, you should be able to toggle it on and off with the regular button.
Jan 30, 2011 | Fisher and Paykel GWL11 Top Load Washer
My ge front end loader washer won`t spin water or pump water out
heatman101
Jan 29, 2011 | GE WSXH208A Front Load Washer
It is not spinning now.
Depending on the make and model top loader or front loader, the most common issues are the lid switch or door lock safety interlock, or the pump filter is clogged and need cleaned. Let me know what machine you have and I can go from there.
Jan 27, 2011 | Washing Machines
My top washer loader would not drain?
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
If you are having problems with your front load washing machine then checkoutthis tip...
heatman101
Nov 04, 2010 | Frigidaire ATF6000ES Front Load Washer
Washer not finishing it's rinse/spin cycle
Run any load - large or the least bit bulky (like sheets) on the "BULKY" cycle. It takes longer, but the machine completes the wash. This shouldn't be the way it works. I love the Neptune TL for its retro look and lack of Maytag's classic big cranky knob. Too bad it runs like ****.
Feb 04, 2009 | Maytag Neptune FAV6800AW Top Load Washer
28+ year old- Speed Queen Heavy Duty top loader
It sound like you drain hose is siphoning off the rinse water, It needs a standpipe make sure the drain hose is at about the height of the top of the washer, Make sure the drain hose isnt stuck in the drain it also needs an air cap. the drain hose should not lay on the floor to run to the drain
Please let me know if this doesnt solve your problems
Aug 31, 2008 | Speed Queen AWS52NW Top Load Washer
Whirlpool LSC9355DQO won't spin and makes grinding noise
grinding noises are never a good sign. My best guess is that the motor coupling is shot. Very inexpensive repair if you're handy. unplug and tip the machine back. locate the motor and remove the clips holding the motor/pump assembly to the transmission. carefully remove the motor and if the coupling is shot, replace. put it back together and should be good to go.
Aug 22, 2007 | Whirlpool LSB6200KQ Top Load Washer
Magic Chef CAV4000AWW Top Load Washer Logo
243 people viewed this question
Top Magic Chef Washing Machines Experts
Robert Smith
Robert Smith
Craig Hill
Are you a Magic Chef Washing Machine Expert? Answer questions, earn points and help others
