Question about Minn Kota Fortrex 80 Bow-Mount Trolling Motor - 24v-80lb.-52 (Minn Kota)
Minn kota fortrex 80 cutting off - Minn Kota Fortrex 80 Bow-Mount Trolling Motor - 24v-80lb.-52 (Minn Kota)
Editor925
  • 285 Answers
SOURCE: Removing Prop
There should be a retainer nut accessible at the rear of the prop (in the center of the prop. Remove this and the prop should slide off.
Posted on Mar 15, 2009
  • 10 Answers
SOURCE: Where can i get a circuit board for my minn kota
http://www.northlandmarine.com/MinnKotaQuickRef.htm
You need your serial number of the trolling motor, length of shaft, and thrust poundage.
or you could call Minn Kota direct and give them the same information at 800-227-6433.
Posted on May 02, 2009
SOURCE: How do you program extra Minn Kota® CoPilot Replacement Transmitters?
According to my user manual
To learn the ID number of additional remotes, follow these steps:
1.) Press and hold the LEARN button located on the side of the receiver (receiver will emit a continuous tone). A small blunt object must be used to depress the LEARN button (pen or screwdriver).
1.) Press any button on the remote (receiver will beep 4 times confirming that it has "learned" the ID number of the remote and that the programming is valid and complete).
Posted on Jun 04, 2009
  • 3 Answers
SOURCE: year made MKAD2674059 minn kota
According to: http://www.northlandmarine.com/MinnKotaMotorControlBoardAssm.htm
*Note: Newer model trolling motors have serial numbers beginning with the two-letter prefix MK (Minn Kota), followed by a two-letter year code. MKAB .......... 2001
MKAC .......... 2002
MKAD .......... 2003
MKAE .......... 2004
MKAF .......... 2005 MKAG .......... 2006
MKAH .......... 2007
MKAI ............ 2008
MKAJ ........... 2009
MKBA .......... 2010 A serial number with the designation MKAB denotes a
2001-motor and MKBA would be a 2010-year model
Posted on Jun 13, 2009
SOURCE: I need Minn Kota Power Drive operators Manual
I'm installing a Minn Kota Power Drive 70# on my Crestliner Fishhawk. I understand the 24 volt system. however the boat has 2 black, an orange and a red wire running to the batteries. I know black to neg. but where do the orange and red wires go.
Posted on Jun 28, 2009
I need to find an owner's manual for a 2005 minn kota riptide weedless wedge 2 80 lb thrust
Have you inquired with a local dealer? Iam sure you can get one off internet.
Sep 14, 2017 | Minn Kota Boating
MINN KOTA MAXXUM FOOT CONTROL PROBLEMS
it has an electrical connection problem... check all the connections on the pedal control. your loosing connection making it die and when you kick it it connects again... look for a frayed wire. or a corroded connnection.
Sep 21, 2008 | Minn Kota Maxxum 80 Freshwater Bow Mount...
Only have a model number and need to order a Minn Kota electric motor propellor
Minn Kota go by the thrust which is mentioned on the top plate. I got mine off Craigs List as well.
  • Minn Kota Prop Compatibility Chart - TrollingMotors.net https://www.trollingmotors.net/blogs/selection/86967623-minn-kota... Minn Kota Prop Compatibility Chart Minn Kota Prop Charts. ... Minn Kota with a serial number and they can recommend a compatible prop for your older Minn Kota motor. ...
  • Minn Kota Motors www.minnkotamotors.com Prop Selection & Part ... Electric Anchor Winches; Shop All; APPAREL. ... A combination of a Minn Kota motor and foot controlled rudder steering allow you truly ...
  • Trolling Motor Replacement Props - Minn Kota www.minnkotamotors.com/Accessories/Trolling-Motor-Accessories/... Minn Kota builds the world's toughest ... Electric Anchor Winches; Shop All; APPAREL. Mens; Ladies; Youth; Shop All; WHAT MOTOR DO I NEED? LET US HELP YOU ...
  • Minn Kota Replacement Propellers - www.fishntech https://www.fishntech.com/minn_kota_propellers.html ... Minn Kota Electric Trolling Motor Replacement Propellers & Nut Kits, ... Minn Kota Replacement Propellers . ... Minn Kota Electric Trolling Motor Replacement ...
  • Minn Kota props replacement props for Minn Kota www.minn-kota.com/minn-kota/minn-kota-propellor/page/2 Minn Kota Replacement Props for propellor Weedless Wedge 2 Props ... Minn Kota MKP 3 Prop 2061151 ... MinnKota Trolling Motor Power Center $57.58; DeckHand Electric ...
  • MINNKOTA MKP 37 2091170 TROLLING MOTOR PROPELLER ' ... www.ebay.ca/sch/...nkw=MINNKOTA+MKP+37+2091170+TROLLING+MOTOR+P... Find best value and selection for your MINNKOTA MKP 37 2091170 TROLLING MOTOR PROPELLER ... MINNKOTA MKP 37 2091170 TROLLING ... MINN KOTA ...
  • Jun 08, 2016 | Minn Kota Endura 30 Freshwater Transom...
    I have a Minn Kota Fortrex 80" Shaft 24volt motor. The shaft appears to have a lot of play where it connects to the top of the aluminium bracket at the head. How can I repair this?
    what do you consider a lot of play
    1/2 inch, 1", .02",040" or what
    talk with a service agent for the equipment to get the exact amount of end play permissible or down load a workshop manual for the equipment
    Mar 10, 2016 | Minn Kota Fortrex 80 Bow-Mount Trolling...
    How do i release 101 fortrex motor from mounting bracket
    There is a pin that goes through the shaft, a small circle clip that holds it in place. Remove the clip and pull out the pin. This may require a hammer and drift as they tend to corrode in the aluminum. don't forget to pull the rope and release the catch.
    Jun 02, 2014 | Minn Kota Maxxum 101/BG/Hand Freshwater...
    Broken plastic on minn kota steering cable
    Hi!
    Here's a schematic:
    Edge 40
    My guess is you need key# 80 (part# 2232360 cable drum pulley)
    Good luck in your repair!
    Mike
    Sep 19, 2009 | Minn Kota Edge 40 Freshwater Bow Mount...
    Looking for parts.
    You nearest Minn Kota service centre is
    G/M Industries
    9502w 800s
    Swayzee
    , IN
    46986
    Phone: 765-922-4816
    8am-10pm Monday - Sunday
    Jul 11, 2009 | Minn Kota Riptide St Saltwater 80 Bow...
    Minn Kota Fortrex 80 Bow-Mount Trolling Motor - 24v-80lb.-52 (Minn Kota) Logo
    22 people viewed this question
    Top Minn Kota Boating Experts
    Mike Marcotte
    Mike Marcotte
    Andrew Taylor
    Andrew Taylor
    Colin Stickland
    Colin Stickland
    Are you a Minn Kota Boating Expert? Answer questions, earn points and help others
