Question about Jacuzzi DX50-959 Elara 7242 Salon Spa Whirlpool Tub with Chromatherapy 6'
Hot tub wont stay hot
Hot tub will not stayhot,it reaches temp set on thermostat then shuts off and wont come back on
  • Ernest London
    Ernest London Oct 25, 2017
    I'm sorry your hot tub won't stay hot, that sounds really frustrating. I can't imagine why it is shutting off when it reaches the set temperature, it sounds like a problem with the thermostat. Have you considered calling a professional? A hot tub service company might have the expertise to get this diagnosed and fixed ASAP. Good luck! https://hottubstore.com/free-home-consul...
  • Hannah Schroeder
    Hannah Schroeder Nov 21, 2017
    It's strange that your hot tub shuts off after it reaches the temperature on the thermostat. The trouble with mine is that it says it reaches the thermostat temp, but when I check it with a thermometer, it's several degrees colder. I'm not sure if we have the same problem, but I'm going to take mine to a hot tub repair service, and maybe you should do the same. http://www.kaupaswater.com/maintenance.h...
    Problem Solver:
  • 9 Answers
Contact Maryland Hot Tub Repair - Pool and Spa Service and set up a Diagnostic service call. Here is there contact info: Maryland Hot Tub Repair - Maryland Pool Service - Maryland Spa Repair Pool Parts - Spa Parts - Hot Tub , Pool and Spa Repair - Pool Opening - Pool Closing - Pool Service 410-304-2463 http://www.maryland-hottub-pool-spa-repa... or see them on http://marylandhottubrepair.blogspot.com...
Posted on Sep 12, 2012
  • 323 Answers
If you're sure your inline heater is ok, then try replacing the thermostat. Sounds like a short in it.
Posted on Jun 04, 2009
  • randywoloszy Sep 05, 2011
    my spa wont stay hot we did buy new temp topside controls what is f2?
"I have a White Rodgers 1F78-151 thermostat and for some reason the system keeps shutting off every few minutes and never reaches my desired temperature i constantly have to set it to off than back to
Is this a gas fired furnace? If so it may be going off because one of the safeties is tripped. There is a high temp safety that will shut the unit down when this temp is reached. The usual cause is low airflow. Check your filters, if these are OK you may have a blocked coil which should be professionally cleaned.
Feb 01, 2015 | Heating & Cooling
Model sf35f furnace wont quit heating after reaching thermostat setting
Sounds like the heat anticipator in your thermostat is either bad or out of adjustment. Turn of the furnace power. Remove the thermostat wires from the thermostat. Turn the power back on. Connect the white and red wires together. The furnace should start up. Let it run a couple of minutes. Then disconnect the wires. The burners should shut off immediately. The blower will continue to run for 60 to 360 seconds then shut off. If this happens replace your thermostat. If the burners continue to burn, then your problem is either the furnace or the thermostat wires.
Sep 12, 2014 | Heating & Cooling
The fan wont work car does not get hot shut off
cooling fan works on a temp sensor in the engine block. it only turns on when the temp reaches a set limit and shuts off when it gets below a set limit.. cooling fan components are , fans, fan relay , and temp sensor . best way to test the fans would be to let the car set running and watch the temp till it goes up to 185 -195 deg. at this time the fans should turn on and the thermostat should open and cool the engine back down. also when ever the air conditioning is on so should the cooling fans be on. if the fans do not run the check all components till you find the broken one. fan relay and air conditioning relay are separate but work the same. and will interchange
Dec 18, 2013 | 2001 Dodge Neon
I have just replaced my circuit board (balboa 53247) for my eclipse hot tub and as soon as I plugged the unit in, I got an OH reading from the top-side control. Then I noticed that if I pulled the temp....
Unfortunately, I would have started with the sensors and then escalated from there. A hot tub is one of those items that I generally recommend hiring a technician to sort out, it's just flat not worth the headache of troubleshooting without the know-how.
As for your particular problem, the OH code on a Balboa control pack is "O.ver H.eating" it means that the heat sensor detected high temp and shut down to prevent damage to the system (as well as cooking you like a pink lobster) The sensor could be bad or the control board could be malfunctioning. A new sensor is $75-85 if memory serves me and is relatively easy to replace. one sensor is in the heating tube and the other is screwed into the tub shell to monitor tub temp. I would suggest new sensors, both of them because when one goes out the other usually isn't far behind. Make sure you shut the power to the tub off at the breaker box before doing any kind of tub repair. If you have shutoff valves on your tub you can replace the internal one without draining the tub. the one in the shell you need to drain to replace (at least to the sensor hole level) I hope this helps you to get your tub working properly again, if you still experience issues after this, I suggest biting the bullet and calling in a tech. Thanks for your question =)
Oct 28, 2013 | Dream Maker Spas Dream Maker Ez Spa Hot...
Fasdfas
Does the furnace stays off?.
Furnace are ment to cycle on and off because of limits .If you set to 70 furnace would cycle several times before reaching that temperature.
Just make sure your filters are clean and you got proper return air flow because lack of air flow will cause furnace to shut off sooner than normal
Jun 08, 2017 | Heating & Cooling
Hot Tub Reaching Temperature but will not maintain
Bad thermostat is sticking.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Oct 14, 2012 | Pool & Spa
Spa thermal overheating
Turn off all power to the hot tub as soon as you realize it is overheating. The spa should have an automatic shut off when the water temperature reaches about 112 degrees fahrenheit. Call your hot tub dealer or manufacturer for service options. There are a variety of conditions that could lead to the overheating of your hot tub, but may differ in various hot tub models and brands. Check the water level of the hot tub. Low water levels could be the culprit for the over heating, so you may just need to add more water to the hot tub.
Check the shut-off valves in the hot tub. If they are closed while the hot tub heater is on, it could cause the water to reach unsafe temperatures.
Clean the hot tub filter. A dirty filter could be blocking the flow of water, causing the water to sit in the hot tub and overheat.
Turn the power back on after finding the problem and talking to the hot tub dealer. The hot tub will probably not start back up until the water reaches a safe temperature
Jan 06, 2012 | Endless Summer Pool & Spa
I have a comfort zone furnace. If it's 50 degrees in the house, and i set my thermostat to 70 or so,it takes at least 24 hours to reach 70 degrees. The furnace starts up and runs normally for about five...
When the thermostat calls for heat it should run until the room reaches the temperature setting then shut off. Is the blower motor running and can you feel air coming out of the vents? It sounds like the blower is either not running or putting out enough air to keep the furnace heating. The blower moves the heat from the heat exchanger to the room, if it can't remove enough heat from the heat exchanger there is a limit switch that will shut the burner off if it gets to hot and that's what it sounds like is happening.
Apr 25, 2009 | Heating & Cooling
Jacuzzi DX50-959 Elara 7242 Salon Spa Whirlpool Tub with Chromatherapy 6' Logo
2,111 people viewed this question
Top Jacuzzi Home Experts
Mike
john h
armylifer
Level 1 Expert
Are you a Jacuzzi Home Expert? Answer questions, earn points and help others
