Question about GE Profile WPRE6100G Top Load Washer
I am trying to fill the washer to do a load of laundry but the water is coming out the back of the washer instead what should I do
  • agibson69 May 20, 2009
    the water is leaking from the bottom where the drain hose is is it pissible that there is somthing else wrong I was just told that when It was moved it was dropped
    Sergeant:
    Champion:
  • 214 Answers
Open the washer and make sure the tube is not sitting forward .If not then you will have to lift the top of washer up and cheak for leaking hose.Also when washer is filling look with flashlight behind it to see if there is a leak there.
Posted on May 20, 2009
  • tom wright
    tom wright May 20, 2009
    you may need a pump to drain hose assembly.Give your local parts depot your model# and part discription.But make sure by tilting the washer on its back and look at the hose for any cracks.If it is not the drain then you may have a cracked outer tube witch is a big job to fix hope i helped:)
One piece agitator wraps cloths
When loading the machine, load towels, sheets or jeans with an accordion fold instead of putting the laundry in a circle around the agitator. It helps to put the clothes in at the twelve o'clock position, then six o'clock, then nine o'clock and then three o'clock. Repeat this sequence until the washer is full.
The laundry can circulate much better and get cleaner too.
Feb 08, 2014 | Washing Machines
LG WN1832CW does not fill with water
The fill valve may be defective or there may be a controller malfunction that prevents the fill valve from operating.
Nov 22, 2013 | LG WM-1832C Front Load Washer
Tried to do a load of laundry and the water doesn't seem to come. The machine beeps and flashes F and then H or vice versa
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Apr 03, 2011 | Kenmore Elite 45986 Front Load Washer
Maytag Auto Load-Sensing Washer does not fill with enough water to wash the clothes. How do I get around this?
Did you ever get an answer - all I see are ads :-(
We have the same problem. Not enough water to rinse - even with extra rinse selected. Even our laundry comes out the color of the laundry detergent. I'm sure this is a result of government regulations to reduce water usage. We'll contact Maytag tomorrow.
Sep 07, 2010 | Maytag PAV2300 Top Load Washer
Drum is leaking how do I GET to it?
How do you know it is the drum? It could be your water inlet hose ( where the water fills the drum) My wife loaded up some laundry in our washer and moved that fill hose slightly. The pump fitting could also be loose. I assume you already checked the fittings on the back of the washer.
Dec 24, 2009 | GE WBSE2090A Top Load Washer
Washer will not fill to appropiate levels
If " Washer will not fill to appropiate levels " this has nothing to do with drain pump and control board is unlikely.
That sounds like a water level switch that is malfunctioning, or a badly connected control board, call back the technician and tell him to double check the job done on control board.
Jan 13, 2009 | Fisher and Paykel GWL11 Top Load Washer
Washer keeps filling with water...
you hae a stuck float switch, it shuts water off when it reaches a certain height, fixing it involes removing the top of the washer (not easily done)
Jan 11, 2009 | Kenmore 22422 Top Load Washer
Started a new load of wash and water never shut off flooding room
you can check for a broken/cracked/ dettached plastic hose leading from the back left side of tub to the pressure switch under the main console. usuall problem is it dry rots and cracks, or comes loose after shaking/vibrating,
Nov 15, 2008 | Kenmore 22422 Top Load Washer
GE Profile WPRE6100G Top Load Washer Logo
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
