Question about Sony Dual Shock 3 Controller for PlayStation 3
Dualshock3 dead controller dead tried to reset nothing then unplugged everything from usb ports then turned off ps3 unplugged power cord counted to 10 plugged power cord back in turned on ps3 put usb cord in port reset controller nothing by usb port there amber light flicking just a bit then nothing whats strange both sony dualshock went dead with 1 hr of each other tried new usb cords nothing are the battery packs dead bought controllers different times so got any thoughts
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 65 Answers
You might need to change the battery, you can order them. here is amazons http://www.amazon.com/s?ie=UTF8&page=1&rh=i%3Aaps%2Ck%3Aps3%20controller%20battery
Posted on Jan 27, 2014
SOURCE: All lights on Dualshock 3 blink 5 times, then do nothing.
On the back of you dualshock pad next to the L2 button there is a tiny small hole witch looks like it could be a screw hole ! well this is the reset button once you have pushed this you will be able to conect your pad to your usb cable and it work on your console again
Posted on Oct 05, 2009
SOURCE: My Dualshock 3 controller will not work. When I
playstation 3 controller will not work all the lights are on but no go
Posted on Jan 07, 2010
SOURCE: dualshock 3 sixaxis why does it always need to be plugged in
Once the controller is plugged in and connected to the console, hold down the PS button to select "turn off the system." Once the system has completed shutting down, unplug the controller and press the PS button. The console should turn on. If so, the controller will connect wirelessly. Unfortunately you'll have to do this with each controller but it works every time.
Posted on Sep 23, 2010
SOURCE: My ps3 Sony dualshock controller
plug the charging usb cable in to the controller, then unplug it , this sould stop it from vibarting.
Posted on Feb 04, 2011
seanpatrick3
SOURCE: PS3 Controller will not turn on, even when plugged in. It flashes but will not turn on. help please
idk. i have the same problem!
Posted on Oct 14, 2012
My ps3 controller isn't charging what should I do ?
First, you need to troubleshoot if it's your system, wire, or controller.
Testing the controller:
Try plugging the wire into another port on the PS3, or into something else to charge it. Try charging it on a friend's system, with his wire, to see if it's your system. If it doesn't work, your controller or battery is bad.
Testing the battery:
Put your battery into another controller, see if it will charge on your friend's PS3 to test it. DO NOT put another battery in your controller: If the controller is shorted, it could ruin your battery!
Testing the Console:
If your controller charges on your friend's PS3 with his wire, try to use their wire on your system. If that works, it's probably your wire. If not, try other ports as I said. If none of the ports charge it (but it charges on your friend's, there's a problem with the voltage or amperage.
_______
If it's your system: It may symbolize a short life left of your PS3, not not for sure. I would still avoid plugging anything into USB you don't want to risk getting destroyed. You can still charge your controller with certain wall chargers, but only certain ones have the circuitry for a "handshake" the PS3 needs to charge.
If it's your wire: Get one from the dollar store should work.
If it's your battery: Getting one one eBay may be cheaper than replacing your controller.
If it's your controller: I prefer wired controllers personally, anyhow... for everything but the Wii, of course. You're going to need a new one for the PS3. You may want to save your battery for a later time or need.
Dec 11, 2015 | Sony Playstation 3 (PS3) Console
Dualshock 3 just blinks with all four lights when i plug it into ps3 slim. reset button does nothing but delay blinking. no way of connecting so i dont know if it is charged or charging
Hello and welcome to Fixya. From what your describing it sounds as if your DualShock3 Controller lost it's bluetooth connection with the PS3. Make sure you plug the controller to the PS3 using the USB to miniUSB cable and hold down the PS button for three seconds to see if this resyncs it. If it does not turn your controller around and you will see a small hole. You will need a paperclip or other small long object and insert it into the hole to reset the controller. Next after pressing the reset button on the controller try the same steps that I provided above again. I can tell you that the four lights blinking slowly means the controller is actively charging. I hope you found this helpful and good luck.
Apr 24, 2011 | Video Game Consoles & Games
Is it ok to charge my controller on laptop/pc
There isn;t a reason why you shouldn't charge using a laptop/pc, did a bit of resaearch and many people claim to be charging thier pads via a pc's usb,
I tried it on mine and it didn't work, it recognised the PS3 pad and installed it as a game controller, which was pretty cool but it wouldn't charge, haven't tried it on my mac yet . If it doesn't work first time try a diff. usb port on your laptop pc, as sometimes its certain usb ports on your system that carry enough juice to power a device
d:)
Jul 31, 2009 | Sony DUALSHOCK® 2 Analog Controller for...
Does any one know how to add a second controller? I have tried everything!!
hook it up to a USB cord and connect it to your PS3, then hit the PS button to turn it on. It will register itself to the PS3.
Jul 20, 2009 | Sony Wireless Controller for PS3
When i turn my ps3 on,red light goes green then red right away
Try disconnecting your PS3 and then for 10 seconds if that doesn't work, disconnect all jackets meaning all usb connection ports connected in it. Remove them, then turn on your ps3 see what happens (without using the controller), then disconnect the ps3 cord that connects to your extension cord or jacket and plug it back in. Try it again. Then again with the controller could try. Try disconnecting other ports such as other stuff like as listed, Irons,Fans, etc.           !!!!!!DON'T USE TOO MUCH POWER!!!!
The Same thing happened to me on my Wii though.
If nothing works call Customer Support (SONY)
May 30, 2009 | Sony PlayStation 3 40GB System
PS3 controller Problem
I just fixed mine. The controller itself needs to be reset. There is a reset button on the back of the controller, above the top right hand corner of the square with all on the information and barcode. Press it with a sharp tipped object while still connected to the PS3 via USB cable. Then press the PS button and you should be back on wirelessly.
Oct 16, 2007 | Sony Playstation 3 (PS3) Console
Sony Dual Shock 3 Controller for PlayStation 3 Logo
65 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
