Question about Toshiba E-Studio 206L Copy Machine
How do I scan to my email? - Toshiba E-Studio 206L Copy Machine
I2400 scan to email doesn't work
You must have an email program like Outlook installed on your computer. When scan to email is selected it simply opens whatever defaul email client and attaches the scanned doc to a new email message.
Sep 24, 2014 | Kodak i2400 - document scanner
How to scan pictures to email
You cannot scan pictures directly to email.
Scan the photo and save the photo as a JPG file.
Open your email program, setup the email and address to your friend and then attach the scanned JPG file to this email before sending it.
Apr 16, 2013 | Kodak ESP 5 Printer
How do i scan a picture to e-mail with HP 1350 all one
"Scan to email" feature is dependent upon the TWAIN and MAPI supported applications. TWAIN and MAPI (Message Application Programming Interface) are standards that relate to "Scanning" and "Scan to email" features respectively. Applications have to support these to make use of HP Director. Not all email accounts are MAPI supported applications. The following are the ones which satisfy the MAPI criteria.
Microsoft Outlook Express 6
Microsoft Outlook Express 5
Microsoft Outlook Express 4
Microsoft Outlook 2000
Microsoft Outlook 98
Microsoft Outlook 97
AOL E-mail Version 8
AOL E-mail Version 5
AOL E-mail Version 4
If you are not using any of the above email accounts, you need to configure your email account with Microsoft Outlook/Outlook Express to use this feature. After configuring, you can use the scan to Email feature by perfroming the following steps.
1. Open HP Director/ HP Solution Center.
2. Click Settings -->> Scan Settings & Preferences --->> Scan to... Setup.
3. Select the available destinations and add them to the front panel destinations.
4. While scanning, you will receive a window showing the scan details which contains the section "Where do you want to scan?". Select "Email".
Dec 28, 2010 | HP PSC 1350 All-In-One Thermal Printer
Scans are too large...
while scanning try reducing the DPI of the scans. this will make the image smaller in size but it will effect the picture quality very little. but do keep in mind that the dpi must be atleast 70 for better picturization
Feb 01, 2010 | HP Officejet Pro 850 InkJet Printer
Need help scanning to email
first you need to ensure the scanner facility files have been down loaded to your computer .. if you go into the web monitor by http your ip address you should have the web monitor page up there you need to entr a user with your password and email address. then when you go to the scan option on your display of the copier you have hte option of scan to foldere or scan to email there is a manual email setting enter the email address and scan as normal. if you need more info give me a reply and I can email the details..
Dec 17, 2009 | Ricoh Aficio 250 Copier
I need to scan to email using the c353 konica Minolta. I used the same settings that the copier has that is working, but this one i set up won't scan to email.
This are the the information you need to setup scan to email and maybe you know how to access the web browser to setup the network. first you need to know the smtp host name or ip address, second you must create a valid email address for the copier. To access the web browser input the ip addrress and press enter click administrator and the password is 12345678 or 8 zeros. there are tab system info print, scan and network. click the the scan tab. choose scan to email first thing you will see enable scan to email smtp ip address or host name. enter the right smtp. witch this you can get to your mail server. do not change the port # and that is 25. Input administrator email address and the machine email address and turn on the authentication enter your user id and a password iof there is any.
Jun 12, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
How do i use my scanner to scan a document and send it as email?
on the printer menu find scan to email,set email up.after function done load whatever you wanna scan and press scan to email.
Jun 12, 2009 | Office Equipment & Supplies
CF2002 Trouble Scanning to Email
scan to email can only be setup to work on a internal email server if the email server is external it will not work. also make sure you input the admin email address and the from email address when configuing the machine
May 14, 2009 | Konica Minolta Office Equipment & Supplies
How to scan to email (pdf) for a brother MFC-9840CDW
Solution #1 has nothing to do with the issue, the thread started asked how to scan a document to email via the mfc-9840cdw, not how to scan a email with antivirus.
Try opening up ports UDP:54925 on your Windows Firewall and try scanning from your computer instead of scanning directly from the printer to a email address. I tried scanning directly from the printer to send to a email and I get a error report of "poor line condition/out of memory" even though the line is fine.
Sep 03, 2008 | Computers & Internet
Toshiba E-Studio 206L Copy Machine Logo
14 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
