Question about FocalPrice LS-108 Mini Alloy R/C 3.5 Channels Helicopter with Built-in Gyroscope Wireless Remote Control
My helicopter is flying for few seconds ten wings hit each other and it falls down
Pilots who are afraid of heights?
i am a pilot. I flew helicopters and fixed wing aircraft. I am afraid of heights. but that means i am terrified to look down from a high building or a cliff. when i strapped into a 23,000 pound 45 foot long helicopter i feared nothing.
Jan 04, 2017 | Aircrafts
Ir helicopter only upper wing spinning
Have a SATURN-X 2CH IR and the tail and the tail rotor will not spin? What can I do?
Dec 30, 2012 | Worldtech Devices World Tech 85618 2CH...
Hello i just bought a s032g from dealextreme 032 does not start up react to transmitter is zero i folowd the start protocol but noting anny ideas thanks
0) Obviously, helicopter will operate best when fully charged... if charging light gets brighter when unplugged from helicopter, then it's not at full charge. Charge fully, then allow battery to cool for 10 minutes. Good batteries in remote also.
1) Power on helicopter.
2) Place on level surface and let gyroscopes sync. There is a red light inside the body (NOT the red/blue flasher in the nose) that will blink when you turn helicopter on, and will keep blinking until craft is level and stable for a few seconds, then will stop blinking.
3) Make sure left joystick is all the way down.
4) Power on remote.
5) Throttle up (left joystick) until blades move and then all the way back down.
This should get you flying. Let me know.
hope this helps,
r
Aug 13, 2011 | SYMA Toys industrial Syma S032 Ready to...
Syma S032 Transmitter battery lights blinks even when Brand new Alkaine Batteries are fitted
4) Power on remote.
r
Jul 30, 2011 | SYMA Toys industrial Syma S032 Ready to...
My hawkeye heli's flybar hits the wings. So when it goes up it falls back down because of it. How do i fix that?
sounds like the shaft has been jarred loose causeing the fly bar to exceed its limit. return for refund or exchange, or if you feel brave carefully crazy glue the flybar housing to the shaft so that the bar it self still operates but has no left right play in it... worked for one of the 4 i had....
Jan 04, 2011 | Air Hogs Reflex Micro Helicopter
The helicopter syma s032 not fly, noy function, not syncronize with the remote control. This charging for 90 minutes and the battery of the remote control is new. The helicopter light led is good, to...
4) Power on remote.
hope this helps,
r
Dec 28, 2010 | SYMA Toys industrial Syma S032 Ready to...
I have Brookstones silver bullet u control helicopter and have a problem. I crashed it, and when I went to fly it again it seems like the bottom blade is hit off the tail of the helicopter. Do I just...
Sometimes the metal weights fall out of the top rotating bar causing the blades to be out of balance and the bottom blade to hit the tail. Check to see if both the weights are in the top bar.
Dec 27, 2010 | Shuttle 9094 Emax Remote Control...
My rc helicopter wont fly high?
flew at first hit sealing won,t fly now hit the trim button,s but still wont fly
May 13, 2010 | Radio Shack Indoor Micro Mosquito Rc...
My john lewis mini helicopter auto stability control not flying
I had a similar problem with mine, check if the central shaft on which the blades turn hasn't become lose and is no longer engaging the gears on the underside of the helicopter.
If the whole shaft can move up and down then this probably means it has come loose, you can solve this by squeezing the lower set of blades towards the bottom gear with your fingers. You should feel the bottom blades move slightly down, if you push them too far they will stick against the main body so you might need to pull them up slightly.
Dec 30, 2009 | Toys
FocalPrice LS-108 Mini Alloy R/C 3.5 Channels Helicopter with Built-in Gyroscope Wireless Remote Control Logo
13 people viewed this question
Top FocalPrice Televison & Video Experts
john o grady
ray gallant
Are you a FocalPrice Televison and Video Expert? Answer questions, earn points and help others
