Question about Dell Inspiron One 2305 Desktop Computer (AMD Athlon II X2 GB3GB) (DDPCEZ1P)
Black Screen the dell screen comes up and the "starting windows" screen comes up, then all black
Start computer in safe mode with command prompt then run chkdsk /r on the C Drive.
Posted on Dec 31, 2013
Teis
  • 340 Answers
SOURCE: my sons dell e520 wont
Have you tried to put a disk in the floppy drive when it starts up?
It probably had a disk in before last close down, and is looking for it now when you start up.
Please vote if this was helpfull :-)
Posted on Nov 29, 2008
  • 18 Answers
SOURCE: trying to restore dell 4400 and cannot get to a dell screen for f-12
If you boot from the XP CD and choose the first repair option it will load to a DOS prompt. From there type "chkdsk /r" and press enter. This will run checkdisk on your hard drive and repair any problems that it finds. It will take 45 minutes or more depending on the size of your drive. Once it finishes type exit to reboot and remove the CD. Your computer should boot normally.
Posted on Dec 06, 2008
byteguy
  • 2229 Answers
SOURCE: F11 does not work for restoring my PC
This is sounding sort of like a registry failure. But first, when it first starts, press the key that puts it into setup. Gotta drag up the memory of which key that is on a Dell. I believe it's F2.
Anyway, when you get into the BIOS setup screen (if it does, in fact, work) look for a menu item that lets you set the BIOS to default and try the bootup. Also, there is probably one screen that tells the machine to halt on errors. Set that to not halt on errors.
Can't be more specific, as the manufacturers are always changing the BIOS options and I don't have access to a Dell 3000.
If you can't get into the BIOS, let me know and we'll do more stuff.
Posted on Mar 25, 2009
mrninja
  • 600 Answers
SOURCE: Dell Dimension 3000 system recovery
AH yes, Kristen very familiar with your issue, it is trying to load the primary boot record from a device it dosen't see , ( re: a floppy thats not there) you need to check the BIOS and make sure the booting sequence is correct (re:disable floopy if one dose not exist, etc) please write back if you need help doing all of these things
Posted on Apr 18, 2009
  • 489 Answers
SOURCE: Dell dimension 3000. Just Black Screen no Windows XP.
From your description, you were able to boot the machine properly in Safe Mode. While in Safe Mode, change the video resolution to the lowest possible (color depth does not matter at this point). You should also check that you are configured for single monitor operation if your video card supports multiple monitors. Reboot the machine normally. If all goes well, you can readjust your video settings for a higher resolution again.
Posted on Jul 06, 2009
Why a black screen on xps l701x w7 i7 1.73
Black screen - no flashing white cursor in the upper left corner - no picture at all, i.e. the initial Dell start-up screen doesn't show up either:
- LCD is dead or isn't getting a signal - not an easy fix; or
- the LCD isn't being sent a signal - holding down the function [Fn] key and press display Function key to toggle through its settings (LCD panel only, Rear VGA output only, both LCD and VGA output)
Black screen - flashing white cursor in the upper left corner - the screen goes black after the windows loading screens come up but before the windows login screen comes up - it is probably a windows video driver problem. Try starting in Windows Safe Mode with VGA. Press [F8] after the Dell startup screen disappears to access the windows startup menu
Oct 19, 2014 | Dell XPS Computers & Internet
Starting Windows
In that case, I would reinstall Windows. Something must corrupted in windows. Do you have your OEM Windows disk with you?
Sep 06, 2012 | Dell XPS M1530 Laptop
Black screen during log in
Try booting in safe mode by hitting F8 every second after you turn it on until the boot screen comes up. Then select "safe mode" If it loads up in safe mode then delete the graphics driver from Device Manager.
If you were able to delete the driver in Device manager then reboot and get the driver from here:
http://www.dell.com/support/drivers/us/en/04
May 15, 2012 | Dell Obsidian Black 15.6" Inspiron N5050...
Black screen with blinking cursor upon start up
You don't say what Windows are you using.
Anyways, it seems like you have a corrupted BOOT problem.
On Windows Vista and Windows 7, you can insert your Windows installation CD, and choose the "Repair my pc" option.
Windows will do it automatically fro you, and you'll be up and running in a couple of minutes.
Dont forget to rate this answer if it helps.
Jul 18, 2010 | Dell Inspiron 531s Desktop Computer
The pc starts and the Dell logo comes up but no windows boot
press the Fn Key and the power button see if the diags will run. You may have a hard drive problem or an issue with the operating system
Jul 09, 2010 | Dell Inspiron 1545 Notebook
Dell inspiron 1525 notebook will not start windows
Usually this happens when the vista boot loader fails. During boot up, keep tapping F8 and then select Disable Automatic Restart... and get the stop error code which usually starts with 0x
Jun 09, 2009 | Dell Inspiron 1525 Notebook
Windows wants to start but...
try to reinstall the OS.. ths will solve the problem...
Feb 20, 2009 | Dell Inspiron E1505 Notebook
Dell desktop running windows XP
You should be left-clicking when the option for safe mode comes up...
Dec 15, 2008 | Dell Inspiron 8500 Notebook
Dell Inspiron One 2305 Desktop Computer (AMD Athlon II X2 GB3GB) (DDPCEZ1P) Logo
69 people viewed this question
Alun Cox
