Question about MG Electronics MGT925CC Plug In Class 2 Transformer Pri 120vac 60hz
Where can I purchase a new MG Electonics MGT925CC Plug In Class 2 120vac 60hz Transformer?
My Transformer no longer works.
Is the AC adaptor OEM Model Number AD-121ANDT? Input 120VAC, 60Hz 25W, Output: 12VDC 1A, Plug-In Class 2?
According to the picture on the Amazon website of the OEM brand that is the specs for that transformer.
Nov 08, 2016 | The Audio Players & Recorders
CAN NOT GET POWER TO THE TRANSFORMWE
The unit plugs into the wall. that is the way that it gets power. If you are not getting power out of the transformer then you should replace it.
Sep 27, 2014 | MG Electronics MGT925CC Plug In Class 2...
What is this used for
It is used to power telephone equipment or security systems
Jan 24, 2014 | MG Electronics MGT925CC Plug In Class 2...
The clock on my transformer does not seem to be working. Can it be repaired or do I have to purchase a new transformer?
Copy following link to identify transformer and read troubleshoot steps, warranty coverage, tips for getting power pack to last longer etc
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html
For example Intermatic Malibu, the timer module is not sold separately, but you can plug transformer into cheap wall timer or photoeye or remote control switch.
May 26, 2013 | Hardware & Accessories
New furnace humidifiera class 2 transformer marked 24V, 12VA
The 24Va 12Vac transformer should function as well. with absolutely no problem.
Feb 01, 2010 | Desert Spring DS3200 Humidifier
I need to replace an AC transformer for harman kardon PC speakers
If you still need it, I have the Hon-Kwang Plug in Class 2 Transformer Model A15-110.
Apr 05, 2009 | Harman Kardon HK206 Computer Speakers
I need a power transformer for roland sde -3000
I need a transformer part 32 no:11-32-000 class 2 ac power transformer mod:mw48-090200a Input:120 ac 60hz output:9vac 2000ma.
(UL) US Ite powuer supply made in japan
Dec 11, 2008 | Music
HK206 speaker power supply
this is power adapter specs for HK206 found elsewhere
Made by: HON-KWANG
Plug in class 2 transformer
Model No: D12-10-1000
P/N: 66-000-118-01
INPUT: 120V 60Hz 25W
OUTPUT: 12VDC 1000mA
The polarity is negative (-) on the outside and positive (+) on the inside.
I will try RadioShack for this...
Aug 24, 2008 | Harman Kardon HK206 Computer Speakers
MG Electronics MGT925CC Plug In Class 2 Transformer Pri 120vac 60hz Logo
253 people viewed this question
Top MG Electronics Electronics - Others Experts
Are you a MG Electronics Electronics - Other Expert? Answer questions, earn points and help others
