Question about Tannoy Reveal 501a Active Studio Monitor
Fuse replacement - Tannoy Reveal 501a Active Studio Monitor
Alesis Multimix8 started smoking and now won't turn on. If it is a fuse or something how do i replace it?
A blown fuse will not produce smoke. A component failed and probably fried a resistor, which would smoke. That in turn would blow the fuse.Just replacing the fuse will not cure the problem. Your unit needs repair.
Dec 27, 2012 | Alesis Multimix 8 USB 2.0 - 8 Channel...
Fuse blown on Europower PMP 3000. Where can I find a 10 Amp 250 V ceramic replacement fuse?
You don't need to use a ceramic fuse if one's not available. You can also use a glass cartridge fuse as well. Just be sure the rating is the same. Be aware, though, that fuses seldom blow on their own. Usually it's because something else has shorted. So don't be surprised if replacing the fuse only results in another blown fuse. Behringer stuff is notoriously cheap and under-protected, so by the time the fuse blows it's usually more trouble than it's worth trying to fix. But maybe you'll be lucky and it will be something simple. Good luck, and thanks for using Fixya!
Jul 05, 2011 | Behringer Pmp3000 16 Channel Audio Mixer
MY ALESIS DM5 WAS PLUGGED TO 220V AND AFTER A WHILE STOP WORKING ( IT IS FOR 110 V ) IS ANY FUSE I CAN REPLACE?
Hi pcruzx,
Sometimes replacing the fuse alone with exact voltage and ampere ratings will cure the problem(you're lucky) but not all. Sometimes further damaged gone to other parts most especially the voltage regulator transistor/IC (mounted in heat sink) and the opened the fusible resistor in line with the supply(B+).
First check the fuse, for sure it was already blown. If you've replaced the fuse and immediately blew again after powering on the unit, this was an indication of shorted parts near the AC line. Click this LINK for more info.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
May 01, 2011 | Alesis Dm5 Drum Module 18 Bit
Does it have a fuse and if it does where is it located? Power blew and now it won't turn on.
Fuse is internal and unit needs to be repaired BEFORE replacing fuse as additional components may be damaged if fuse is replaced before repair is done.
Jan 15, 2011 | Line 6 Spider Iii 75 Guitar Combo...
How do I remove the rear panel to access the fuse? When I remove the six or seven screws, the panel still refuses to budge.
If the fuse blew, the problem causing that needs to be fixed BEFORE replacing the fuse. Replacing a fuse without fixing MAY damage further components that the fuse protected.
Often the Tolex covering makes removing panels difficult and one has to pry the panels out.
Dec 25, 2010 | Epiphone Amplifiers Valve Junior Hot Rod...
I need to replace the fuse for a used Marshall MG100HDFX that I bought. Where is the fuse located inside the head?
If the fuse is blown make sure the reason it blew is repaired before replacing the fuse. Start the amp up after replacing it with a 100 Watt light bulb in series with the hot side of the power into the unit. This will act as a current limiter to verify it is repaired and will not blow the fuse. When you open the unit the fuse will be obvious... Follow the hot side of the power cord, through the switch to the fuse.
Dec 08, 2010 | Marshall MG100HDFX 100-Watt Amplifier Head
Hello...I am an owner of the Fender Passport PD-500 Sound System
Replace the fuse only once. If it blows right away, then servicing is required as continued replacement will likely damage more inside.
Most of thes have a fuse holder that is a part of the input power socket. There is a little rectangular panel adjacent where the cord connects with a tab that you gently pry out and carries a small fuse. Replace the fuse and re-install the carrier.
These units are very hard to work on due to packaging.
May 30, 2010 | Fender Passport Deluxe 500watt Sound...
Where can I buy a fuse and fuse holder for my Behringer pmp 3000 power mixer - can anyone tell me pleas Lyn
DO NOT REPLACE A FUSE if it blows. You will do additional damage to the unit internally.
When these blow, there is damage inside that must be repaired before restoring power.
To get an exact replacement fuse holder it is best to get it from Behringer parts. This one has a switch in it depending on which way the fuse carrier is inserted.
May 12, 2010 | Behringer Pmp3000 16 Channel Audio Mixer
Power does not turn on for a marshall avt150h amp. most likely a blown fuse. got it a year ago and never had to get replace the fuse before. don't want to make a mistake. need instructions on fuse...
If the fuse blew for a reason, replacement MAY do further damage.
The way to test is to put a 150 watt light bulb in series with one of the power input wires and replace the fuse. The lamp will limit the current so further damage would not be done.
If lamp stays off and unit works, you are good to go. If lamp stays on, then service is required.
Aug 30, 2009 | Marshall Music
Is there a circuit breaker
There should be a fuse holder near the place in the back of the amp where the power cord plugs in. Also some Marshalls have fuses in fuse holders on the circuit board. Always replace with the same value and type as the original fuse. Never open up the amp when it is plugged in to the outlet. When replacing the internal fuses do not touch the capacitors as they retain a lethal charge. If the fuse continually blows it is an indication of a more serious problem which will require servicing by a qualified repair person.
Jun 25, 2009 | Marshall Amplification Marshall MG250DFX...
Tannoy Reveal 501a Active Studio Monitor Logo
24 people viewed this question
Top Tannoy Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you a Tannoy Music Expert? Answer questions, earn points and help others
