Question about Garden
K 7.85M Karcher repair chemical feed - Garden
Soap dispenser not working
chemical injector activates only when low pressure is utilized try this remove hose from triggergun assembly with the water turned on engine off allow water to free flow out of hose remove the chemical hose from the barb located at pump with a paperclip or needle insert it into the hole of barb and slowly separate the ball inside the barb you should here it siphon and try not to look directly at the port you may get sprayed once freed reinstall all back together and try again.;0;0
Aug 02, 2013 | Karcher Garden
Karcher 5.91 power washer troubleshoot have power but no pressure
My Karcher 5.91 has pressure and pumps perfectly but will not suck up the chemical cleaner
Jul 27, 2012 | Karcher Garden
Why want my pressure washer suction the solution while pressure washing the house?
The first problem might be that you are trying to use the wrong nozzle, see this link to read more about what nozzle to use for detergents
If you still have an issue the problem is going to be in the chemical valve on the pump, there are two different styles they have on this type of machine, look at the links below on directions on how to repair your chemical valve.
Chemical Injector 1
Chemical Injector 2
Nov 11, 2010 | Karcher 2500 PSI Pressure Washer
What do you press for the detergent
Hi Twist the nozzle on the end of the lance and submerge you chemical pipe in a barrell of chemica, It will then draw chemical at low pressure.
Apr 17, 2010 | Karcher K2.26 Electric Power Washer
How to repair chemical pickup pump
Make sure that you have adjusted the nozzle on the end of the washer so that it produces low pressure as this is the only way it will ****.
Apr 12, 2010 | Karcher K2.26 Electric Power Washer
Just bought a used karcher hds 500ci every now & again lots of smoke belches out burner is this a bad sign ? also cant seem to get the chemicals to pick up any tips
you burner assy needs to be cleaned , spark electrodes properly gapped and the fuel pump pressure set , the chemical pick up often gets clogged , and the chemical valve ( pump side becomes jammed ( a small ball bearing jams in the seat )
also clean out the diesel tank and clean or replace the fuel filter , if the smokes is white thats caused by water in the fuel , black smoke is too much fuel going to the burner assy or your ignition electrodes not igniting it
Nov 15, 2009 | Garden
Water keeps popping off t he detergent cap.. even though water is not even hook up.. guess it is detergent popping out .. what is wrong with it.. cleaning fitting is not even on
detergent non return valve stuck, allowing water to back feed into the chemical tank.
depends on what machine it is as to where the non return valve is.
Jul 17, 2009 | Karcher Garden
No pressure on certain settings
Dear Osville,
It is not clear what type of lance or nozzel you have. You said that the machine works fine with the circulating water jet(the turbo). So it seems the machine is fine. I do sometimes service variable nozzels and variable lances. But the best solution is to replace nozzels and variable nozzles and lances with new ones. Regarding the fan spray setting it could have no pressure because it might be in the chemical setting. The chemical setting lets out a fan shape flow of water, but with less pressure. The chemical system only works on low pressure in domestic washers, that is why it needs a low pressure flat spray. The pencil jet has 2 jets comming out because if it is a lance or nozzel with ball bearings, these ball bearings must have stuck in a wrong position. Also 2 jets can come out, due to a damaged nozzel hole.
Altogether, the best advice is to buy a new nozzel or lance...which ever your machine uses. All Karcher machines have their own specific nozzels, lances and high pressure hoses. You cannot change these from one model to another.
Regards,
Fulltech.
Apr 29, 2009 | Alfred Karcher K 5.93 M Electric Pressure...
Electric modelm620 karcher does not start
The bypass valve is most likley jammed. Remove the cover from the machine, then remove the chemical tank. Unscrew the micro switch cover and manually operate the micro switch. If the motor runs the bypass valve is faulty. Replace the valve along with the stem seals on the valve.
Mar 04, 2009 | Karcher Garden
Garden Logo
29 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
