Chemical feed does not work
SOURCE: i require a karcher hds745 pressure washer as i
hi, this can be a problem with the hds745 machine, there are a few different versions on the market.
you first need to put a piece of pipe direct to the pump and bypass the chem valve and filter.
if still no look then you will need to have a look at the brass soap hose tail and see if it has a ball bearing in and if its stuck.
some model have a valve in the head when you have taken the brass soap hose tail out.
