Question about Dryers
Indesit is70c hi my dryer keeps tripping the sockets downstairs out and also itself as soon as i try to start it ,it turns for a second then trips itself out and the downstairs sockets which it is plugged into...also when i dont set the drying timer,and press just the start button,it buzzes for about a second then goes quiet...take my finger off for a second or so then press it again and it does the same buzzing noise again...any ideas ..many thanks.
Its a saftey device, called a "thermodisk". It's purpose is to turn off the heating coil or stop gas flow in the event of over heating. If the thermodisk is bad, trying to over ride it (trying to get it to run) will trip the breaker. Its about 10 bucks and easy to replace.
Posted on Dec 31, 2013
Testimonial: "THANK YOU"
  • 90 Answers
SOURCE: Buzzing noise when pressing start button
does the buzzing noise sound more like a hum, if so could be a bad motor or possibly something stuck in blower wheel.
Posted on Jan 05, 2008
IFIXALL
  • 868 Answers
SOURCE: Dryer will not start when start button is pressed, makes a buzzing noise
Mode land serial number?
Posted on Jun 02, 2008
  • 3 Answers
SOURCE: Tumble dryer trips electricity
I own the same machine and this happened to me, if the internal working of the machine get wet it will cut off causing the electrics to trip. This model is a condenser dryer, at the bottom of the machine if you open up the flap you will see the condenser on the left hand side, the manufacturer recommends that you clean this unit once every month and also empty the reservoir and clean the fluff filter after every use. While this may seem like a lot of hard work there is a very good reason for this. I suspect that your problem is due to a build up of fluff and or gunge in the condenser and bottom of the machine. Remove the condenser and give it a good clean of all fluff, you can run water through it either in the sink or bath as the best way to do this it is very fiddley using just your hands. Next check to see if there is a build up of water in the back the machine where the condenser usually sits, you will have to lie on your stomach and reach into the back of the machine (OBVIOUSLY ENSURE THAT YOU HAVE UNPLUGGED FROM THE MAINS SUPPLY BEFORE YOU DO THIS!) along the floor of the machine you will feel a channel cut into the plastic which runs into the sump at the back of the machine, if you have not cleaned the machine properly this is probably blocked and is the culprit. With this blocked the water is unable to travel to the pump that takes the water from the condenser into the resevoir at the top of the machine, and therefore it stays in the machine and can get thrown about onto the electrics and could cause the machine to cut out and trip your electrics! If this is not blocked check the black rubber pipe leading from the pump to the reservoir is not blocked, failing that perhaps the pump (in the plastic case at the back of the machine) is faulty and will need to be replaced. If water has built up in the machine you will also need to check to make sure none is sitting in the heater coil compartment (it did with mine) to get at this you will have to unscrew the metal plate at the back of the machine and let any water out. Leave the machine for a few hours to make sure it is dry and then give it another go. If your machine is still under warranty though i would call indesit first as they may get a little funny if you remove any of the machine covers yourself and refuse to look at your machine.
Posted on May 28, 2009
  • 3 Answers
SOURCE: I have in indesit tumble dryer model
Hiya drodger, i had the same problem with my hotpoint dryer, (same company) if this is a condenser dryer make sure the drawer is collecting the water there is a small hole at the bottom of the drawer if you have a straw poke it in and clean it out, also at the back of the dryer there is a clear plastic pipe and a black one take them both off and clean them, your problem is exactly the same as mine so you will probably have to buy a new heating element (they are a lot cheaper from ebay) they are so easy to fit just 2 clips (i did it and im not dead yet!) hopefully you will then find the dryer will work perfectly, word of advice though clean the collecting drawer out at least once a month.
Hope this helps
Posted on Oct 04, 2009
apart4u
  • 213 Answers
SOURCE: I turn my indesit is70c tumble dryer on and after
this could be the hater or the motor but sometimes just chafed wireing
Common faults -
1 The heating elements can fail (meaning open circuit)
2 There are cut-outs (T.O.C's) that might need resetting
3 The thermostats (stats) can trip out or burn out (meaning open circuit)
4 Modern tumble dryers also have sensors and pcb's (Printed circuit boards) these have programs that can fail and circuitry although most should produce an error code showing you were the fault is.
5 Faulty connections and burned wires may also be the fault.
You-Tube video "h_WMwQ-M33A" placeholder (do not delete)
We have a full video library on appliance repair video’s
Posted on Jan 08, 2010
When you turn the dial and hit the on switch it trips the electric
sounds like heater element gone check it first its on the back
Jul 15, 2012 | Indesit IS70C Electric Dryer
My dryer trips my electric when i switch it on
this will be either the motor or control has shorted
Apr 20, 2012 | Indesit IS70C Electric Dryer
Hotpoint WDM 73 keeps tripping ringmain when powered on
I suspect that the problem is probably being caused by a fault on the dryer element or thermostat.
Remove the top cover and disconnect the heater, and see what happens..
If it does not trip, then prob is the dryer element or stat.
Hope this helps.
Jan 04, 2010 | Hotpoint Ultima WDM73 Front Load Washer /...
My electricity trips off after 5 mins on my indesit is70c condenser dryer
you must have a shorted heating element, that is about all that will cause this problem
Oct 15, 2009 | Dryers
I have in indesit tumble dryer model no;-IS70C.When i hit the start button the machine cuts out right away and trips the main socket RCD in my fuse box.Sometimes the machine starts and then cuts out again...
Hope this helps
Sep 27, 2009 | Dryers
Dryer tripped out during cycle and knocked off all downstairs sockets. Have had element tested and found no fault. Tech suggested plug dryer in without the element to see if trips (to eliminate element)...
An electric dryer must be on a circuit by itself. If you lost power to downstairs sockets, you will need an electrician to separate the 120volt side from the 240volt side. You may not have a problem at all with the dryer. If another appliance was operating at the same time as your dryer, that appliance would have overloaded your circuit and tripped the breaker. Please have this looked into by an electrician to avert a possible fire!
Your tech should have recognized this situation or maybe I have misunderstood the issue, but I gave my opinion based on the question above,
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Jul 07, 2008 | Whirlpool Dryers
Dryers Logo
Top Dryers Experts
Dan Webster
Dan Webster
